Web Content Viewer
Actions
LV-7210
Support LV Projectors
Features
<br/> <br/> Whether it's precision lenses for photography, broadcast TV cameras, camcorders or projectors, the name Canon means unsurpassed optical quality. With the LV-7210's 1.6X Ultra-Wide Optical Zoom Lens, you get superior color and stunning clarity. You also get a versatile lens with the widest zoom range around. Even at a cramped distance of 8.2', you can impress your audience with a 100" image that's sharp, bright and beautiful.
&#160; <br/> <br/> <br/> <br/> No matter what the lighting conditions, your LV-7210 has the power to deliver a brilliant performance. An impressive 2000 ANSI Lumens lets you turn any room in your house into a home theatre, and any office into a presentation boardroom.
Sharpness and clarity are yours with the LV-7210's Native XGA Resolution. Video and text images are full of stunning, 1024 X 768 detail. And, that's not all. The LV-7210 also supports SXGA Resolution (1280 X 1024) through advanced, high-quality compression. Turn down the lights and prepare to be amazed!<br/>
You can be sure of sharp, vibrant images with the LV-7210's outstanding 350:1 Contrast Ratio.
<br/> <br/> Turn your home theatre into the star attraction night after night! The LV-7210 lets you convert 480i/575i interlaced signals to progressive scan, giving you the outstanding image quality you demand.
<br/> <br/> Find out how the LV-7210's XGA sharpness and clarity make all of your images look. With it's advanced connectivity, this projector can handle virtually all of your electronic devices. Whether it's your computer, DVD player, HDTV, VCR, digital camcorder or digital camera, the LV-7210 makes them all look better.
The LV-7210's DVI-I terminal lets you feed Digital or Analog RGB to your projector. Hook up two laptop computers at the same time for flexibility and versatility.
In Silent Mode, it gives a brilliant performance while whispering along at an extremely quiet 35 dB.<br/>
Digital Keystone Adjustment is the key to a masterful and professional presentation. With the LV-7210, you can project at an angle of up to 40 degrees vertically and 20 degrees horizontally without keystone distortion. A fast, simple adjustment and your screen is picture perfect.
Imagine all this power and XGA resolution in an ultra-portable projector. That's the LV-7210! At 6.4 lbs and a trim 11.8" X 3.7" X 9.6", you can take it wherever you need a brilliant performance.
<br/> <br/> With other features such as Wireless IR Remote with Laser Pointer, RS-232/USB Mouse Control, 3 Years Parts and Labor Warranty, and 120 Day Lamp Life Warranty, the LV-7210 is the bright, sharp, portable projector for you.
LV-7210 Projector Kit - Item Code: 9059A002
LV-7210 Projector Kit - Item Code: 9059A002 LV-7210 Projector Wireless remote control (AA alkaline batteries included) Power cable Computer cable (DVI-VGA) Mouse control cable (USB) Lens cap Soft carrying case Warranty card User's manual
Specifications
Projector Specifications
Native Resolution
XGA
Brightness
2,000 LUMENS
Uniformity
85%
Contrast Ratio
350:1
Digital Keystone (Vertical)
(+/-) 40 deg-V; (+/-) 20 deg H
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, UXGA, HDTV, DTV
Lens Shift
8:6:1.4, Fixed
Zoom
1.6x
Screen Size
40-300
Throw Distance
3.7 - 24.1ft (1.1 - 8.8m) / 100: 9.5 - 15.1ft (2.9 - 4.6m)
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V: 50 ~ 120 Hz, Dot clock: 108 MHz
Analog PC Input
Video/S-Video Input
NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N
Component Input
S-video, Composite, VGA, Audio, DVI-I, USB, Component video input with optional cable
Terminals
(Output) Stereo Mini Jack
RCA x2, Stereo mini jack
Built-in Speaker
1 Watt Monaural
Lamp
Network
Yes
Lamp Life
200 watt UHP
Remote Control
Sensor
Yes (includes laser pointer)
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide, 270W
Weight
6.4lbs
Warranty
3 years parts and labor, 120 lamp life.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7210 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
