Web Content Viewer
Actions
LV-7215
Support LV Projectors
Features
<br/> <br/> Whether it's precision lenses for photography, broadcast TV cameras, camcorders or projectors, the name Canon means unsurpassed optical quality. With the LV-7215's 1.6X Ultra-Wide Zoom Lens, that means superior color and stunning clarity. It also means a versatile lens with the widest zoom range around. Even at a cramped distance of 8.2', you can impress your audience with a 100" image that's as beautiful as it is big.
&#160; <br/> <br/> <br/> <br/> At a brilliant 2500 ANSI Lumens, there aren't many Canon projectors brighter than the LV-7215. Whether it's your latest business presentation or the latest DVD release, this powerhouse gives you the brightness you need -- no matter what the lighting conditions.
Combine the brilliance of 2500 ANSI Lumens with the sharpness of Native XGA Resolution (1024 X 768), and you've got a projector with few equals. That's the LV-7215. Not only that, but it even supports SXGA Resolution (1280 X 1024) through advanced, high-quality compression.
Be sure of sharp, vibrant images with the LV-7215's exceptional 350:1 Contrast Ratio
<br/> <br/> Turn your home theatre into the star attraction night after night! The LV-7215 lets you convert 480i/575i interlaced signals (conventional broadcast TV)&#160;to progressive scan, giving you the outstanding image quality you demand.
<br/> <br/> Why waste all that power and sharpness? With the LV-7215's advanced connectivity, this projector can handle virtually all of your electronic devices. Whether it's your computer, DVD player, HDTV, VCR, digital camcorder or digital camera, the LV-7215 raises their performance to a new level.
The LV-7215's DVI-I terminal lets you feed Digital or Analog RGB to your projector. Hook up two laptop computers at the same time for flexibility and versatility.
With brightness like this, you still get a quiet projector that doesn't distract your audience from your presentation. In Silent Mode, the LV-7215 purrs along at an extremely quiet 35dB.
You've got the power and the sharpness. Don't let a less-than-perfect projector set-up result in a less-than-perfect presentation. Even if you have to project at an angle, Digital Keystone Adjustment will keep your image square and undistorted. With a fast, simple adjustment, the LV-7215 can compensate for a projection angle of up to 40 degrees vertically and 20 degrees horizontally.
It's hard to believe, but we pack all that power, sharpness and versatility into a trim 6.4 lb., 11.8" X 3.7" X 9.6" projector. Good things do come in small packages!
<br/> <br/> As if that weren't enough, other features such as Wireless IR Remote with Laser Pointer, RS-232/USB Mouse Control, 3 Years Parts and Labor Warranty, and 120 Day Lamp Life Warranty make the LV-7215 a brilliant choice.
LV-7215 Projector Kit - Item Code: 9058A002
LV-7215 Projector Kit - Item Code: 9058A002 LV-7215 Projector Wireless remote control (AA alkaline batteries included) Power cable Computer cable (DVI-VGA) Mouse control cable (USB) Lens cap Soft carrying case Warranty card User's manual
Specifications
Projector Specifications
Native Resolution
XGA
Brightness
2,000 LUMENS
Uniformity
85%
Contrast Ratio
350:1
Digital Keystone (Vertical)
(+/-) 40 deg-V; (+/-) 20 deg H
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, UXGA, HDTV, DTV
Lens Shift
8:6:1.4, Fixed
Zoom
1.6x
Screen Size
40-300
Throw Distance
3.7 - 24.1ft (1.1 - 8.8m) / 100: 9.5 - 15.1ft (2.9 - 4.6m)
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V: 50 ~ 120 Hz, Dot clock: 108 MHz
Analog PC Input
Video/S-Video Input
NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N
Component Input
S-video, Composite, VGA, Audio, DVI-I, USB, Component video input with optional cable
Terminals
(Output) Stereo Mini Jack
RCA x2, Stereo mini jack
Built-in Speaker
1 Watt Monaural
Lamp
Network
Yes
Lamp Life
200 watt UHP
Remote Control
Sensor
Yes (includes laser pointer)
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide, 270W
Weight
6.4lbs
Warranty
3 years parts and labor, 120 day lamp life.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7215 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
