Web Content Viewer
Actions
LV-7220
Support LV Projectors
Features
Regularly find yourself in a tight spot? Get your message across no matter what the room size with the LV-7220's 1.6X Ultra-Wide Zoom Lens. Offering the widest zoom range around, LV-7220 will help you adjust to even the most unforgiving boardroom terrain. Even at a cramped distance of 8.2', you can impress your audience with a 100" image that's sharp, bright and beautiful.
No matter what the lighting conditions, your LV-7220 has the power to deliver a brilliant performance. An impressive 2000 ANSI Lumens lets you turn any room in your house into a home theatre, and any office into a presentation boardroom.
By delivering stunning video and text images at a 1024 X 768 resolution, the LV-7220's Native XGA Resolution gives you the ultimate in sharpness and clarity. And, that's not all. The LV-7220 also supports SXGA Resolution (1280 X 1024) through advanced, high-quality compression. And with an outstanding 350:1 Contrast Ratio, you guaranteed to get the big picture!
Find out how the LV-7220's XGA sharpness and clarity make all of your images look. With it's advanced connectivity, this projector can handle virtually all of your electronic devices. Whether it's your computer, DVD player, HDTV, VCR, digital camcorder or digital camera, the LV-7220 makes them all look better. What's more, the LV-7220 lets you convert 480i/575i interlaced signals to progressive scan, giving you the outstanding image quality you demand.
With performance like this, you might expect to have to put up with a little fan noise. But not with the LV-7220. In Silent Mode, it gives a brilliant performance while whispering along at an extremely quiet 34 dB.
With its unique Blackboard Mode, the LV-7220 is teacher's pet. That's because you no longer need a screen to project your lessons. Instead, the Blackboard Mode optimizes the color output so legibility is enhanced when projecting on a blackboard.
Thanks to the LV-7220's Digital Keystone Adjustment, you can be sure every presentation looks professional. Project at an angle of up to 40 degrees vertically and 20 degrees horizontally without any annoying keystone distortion. In a single, fast and simple adjustment your screen will be picture perfect.
Imagine all this power and XGA resolution in an ultra-portable projector. That's the LV-7220! At 6.4 lbs and a trim 11.8" X 3.7" X 9.6", you can take it wherever you need a brilliant performance.
The LV-7220 has a unique Password Lock & Function Key Lock that prevents unauthorized users from operating your projector without the proper pin number. This lets you control access to your projector - giving you one less thing to worry about.
With other features such as Wireless IR Remote, RS-232/USB Mouse Control, 3 Years Parts and Labor Warranty, and 120 Day Lamp Life Warranty, the LV-5220 is ultra-portable, ultra-easy-to-use, and ultra-convenient.
LV-7220 Projector Kit
LV-7220 Projector Kit LV-7220 Projector Wireless remote control (AA alkaline batteries included) Power cable Computer cable (DVI-VGA) Mouse control cable (USB) Lens cap Soft carrying case Warranty card User's manual
Specifications
Projector Specifications
Native Resolution
XGA
Brightness
2,000 LUMENS
Uniformity
85%
Contrast Ratio
350:1
Digital Keystone (Vertical)
(+/-) 40 deg-V; (+/-) 20 deg H
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, UXGA, HDTV, DTV
Zoom
1.6x
Screen Size
40-300
Input Signals
Analog PC Input
Video/S-Video Input
NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N
Component Input
S-video, Composite, VGA, Audio, DVI-I, USB, Component video input with optional cable
Terminals
Built-in Speaker
1 Watt Monaural
Lamp
Network
Yes
Lamp Life
200 watt UHP
Remote Control
Sensor
Yes (includes laser pointer)
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide, 270W
Weight
6.4lbs
Warranty
3 years parts and labor, 120 lamp life.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7220 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
