Web Content Viewer
Actions
LV-7225
Support LV Projectors
Features
With the LV-7225's 1.6X Ultra-Wide Zoom Lens, you get the widest zoom range around. Which means that even at a cramped distance of 8.2', you can impress your audience with a 100" image of superior color and stunning clarity. It's hard to believe, but we pack all that power, sharpness and versatility into a trim 6.4 lb, 11.8" X 3.7" X 9.6" projector. After all, when it's business on the go, size does matter.
Whether it's your latest business presentation or the latest DVD release, the LV-7225 gives you the brightness you need - no matter what the lighting conditions. This powerhouse delivers a brilliant 2500 ANSI Lumens, which makes it one of the brightest Canon projectors available.
Even if you're fuzzy on the presentation details, your projector won't be. That's because the LV-7225 combines brilliant 2500 ANSI Lumens power with the sharpness of Native XGA Resolution (1024 X 768). Not only that, but it even supports SXGA Resolution (1280 X 1024) through advanced, high-quality compression, giving you the largest on-screen real estate possible. And with the LV-7225's exceptional 350:1 Contrast Ratio, you can be sure every presentation delivers sharp, vibrant images.
That's right with the LV-7225 you can bring home the theatre experience night after night. It's all thanks to the LV-7225's Progressive Scan Technology capable of converting 480i/575i interlaced signals to progressive scan, giving you the outstanding image quality you demand.
Why waste all that power and sharpness? With the LV-7225's advanced connectivity, this projector can handle virtually all of your electronic devices. Whether it's your computer, DVD player, HDTV, VCR, digital camcorder or digital camera, the LV-7225's DVI-I terminal lets you feed Digital or Analog RGB to your projector. Hook up two laptop computers at the same time for flexibility and versatility.
In Silent Mode, the LV-7225 purrs along at an extremely quiet 34dB, ensuring your audience is focused on your presentation... not the projector.
Don't make your job any tougher than it already is. With its unique Blackboard Mode, the LV-7225 gives you one less thing to worry about in the classroom. That's because you no longer need a screen to project your lessons. Instead, the Blackboard Mode optimizes the color output so legibility is enhanced when projecting on a blackboard.
You've got the power and the sharpness. Don't let a less-than-perfect projector set-up result in a less-than-perfect presentation. Even if you have to project at an angle, Digital Keystone Adjustment will keep your image square and undistorted. With a fast, simple adjustment, the LV-7225 can compensate for a projection angle of up to 40 degrees vertically and 20 degrees horizontally.
With the LV-7225's unique Password Lock & Function Key Lock, you can prevent unauthorized use of your projector, thereby reducing the possibility of damage and lamp usage. You're in control, because users must enter the proper pin number before being able to operate the LV-7225.
As if that weren't enough, other features such as Wireless IR Remote with Laser Pointer, RS-232/USB Mouse Control, 3 Years Parts and Labor Warranty, and 120 Day Lamp Life Warranty make the LV-7225 a brilliant choice.
LV-7225 Projector Kit
LV-7225 Projector Kit LV-7225 Projector Wireless remote control (AA alkaline batteries included) Power cable Computer cable (DVI-VGA) Mouse control cable (USB) Lens cap Soft carrying case Warranty card User's manual
Specifications
Projector Specifications
Native Resolution
XGA
Brightness
2,000 LUMENS
Uniformity
85%
Contrast Ratio
350:1
Digital Keystone (Vertical)
(+/-) 40 deg-V; (+/-) 20 deg H
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, UXGA, HDTV, DTV
Zoom
1.6x
Screen Size
40-300
Input Signals
Analog PC Input
Video/S-Video Input
NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N
Component Input
S-video, Composite, VGA, Audio, DVI-I, USB, Component video input with optional cable
Terminals
Built-in Speaker
1 Watt Monaural
Lamp
Network
Yes
Lamp Life
200 watt UHP
Remote Control
Sensor
Yes (includes laser pointer)
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide, 270W
Weight
6.4lbs
Warranty
3 years parts and labor, 120 day lamp life.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7225 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
