Web Content Viewer
Actions
LV-7230
Support LV Projectors
Features
Canon's LV-7230 is a great addition to our line-up of bright projectors. At 2000 ANSI lumens, the LV-7230 is bright enough for a classroom or office setting with high levels of ambient light, or for your conference room or boardroom presentations in front of a large audience. No matter where you use it, you can be confident the LV-7230 has the power to perform.
The LV-7230's native XGA (1024 X 768) resolution, is the perfect resolution match for your laptop computer. (It also supports SXGA resolution (1280 X 1024) through high-quality scaling.) In addition to this performance, the LV-7230 boasts a 380:1 contrast ratio for sharp images and deep, rich colors - even with ambient light. It also features 85% image uniformity for an even image from corner-to-corner. You also get a steady, film-like image from digital TV and high-end DVD players, as the projector's Progressive Scan circuitry converts 480i/575i signals to Progressive. And, of course, none of this advanced technology would matter without the LV-7230's Genuine Canon Optics.
LV-7230 offers both power and portability. Even with 2000 ANSI lumen brilliance, this projector still weighs in at only 6.4lbs. So, no matter where you need its power, you can take the LV-7230 there without getting tired.
The more sources of images you have, the more you need a single projector that can handle those sources. The LV-7230 covers all the bases, through compatibility and connectivity with HDTV, VGA (RGB Analog), Component, S-Video and Composite signals. Whether it's the latest educational broadcast or the latest presentation from your laptop, the LV-7230 is all the projector you need.
The LV-7230 comes with 1.6X Ultra-Wide Zoom lens - a Canon Genuine Optics lens, so you know the optical quality is outstanding. It's the only lens you'll need because the ultra-wide focal length range lets you use the projector in cramped quarters and still get a 100" (diagonal) screen with a short 8.2' throw. Plus, the zoom range gives you the flexibility to project a screen from 40" to 300" in (diagonal) size. That means you're covered for a wide range of room sizes and projection distances.
Simply set it up and use the Digital Keystone Correction to compensate for projecting at a vertical angle of up to 20 degrees. Then, if you want to ensure your audience isn't distracted by fan noise, switch the projector from Normal Mode (38.5 dB) to whisper-quiet Silent Mode (34dB). If you're in a classroom without a projection screen, simply use the Greenboard Mode to project onto a chalkboard - the projector adjusts the projected image to maximize legibility and image quality. Then, effortlessly operate your LV-7230 with the help of the Wireless IR Remote Control.<br/> <br/> When you're finished, use the Pin Code Lock and Function Key Lock to control the use of your projector. Depending on your requirements, you can also use the LV-7230 for rear-projection; you can even mount it on the ceiling with an optional Ceiling Mount Adapter.
Your LV-7230 also makes your life easier with: Customizable logo display<br/> Audio speaker<br/> 3-year parts and labor warranty<br/> 120-day lamp life warranty<br/>
LV-7230 Kit Contents
LV-7230 Kit Contents LV-7230 Body Wireless Remote Control (w/ AA Batteries VGA Computer Cable Component Video Adapter Cable Mouse Control Cable Lens Cap Soft Carrying Case Power Cable Warranty Card
Specifications
Projector Specifications
Imaging Device
0.8 TFT Active Matrix type, 3 panels
Native Resolution
XGA
Brightness
2,000 LUMENS
Uniformity
85%
Contrast Ratio
380:1
Digital Keystone (Vertical)
+/- 20 (vertical) degrees
Optics
Projection Lens
VGA, SVGA, SXGA (through high-quality scaling), HDTV
Lens Shift
12:1
Zoom
1.6x Ultra-Wide Zoom Lens
Screen Size
40 - 300
Throw Distance
3.6' ~ 31.8' (1.1 m ~ 9.7 m)
Input Signals
Scanning Frequency
H-sync. 15 ~ 80 KHz, V-sync. 50 ~ 100 Hz
Analog PC Input
Video/S-Video Input
NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N
Component Input
S-video, Composite, VGA, Audio, USB, Component*
Terminals
(Input) Stereo Mini Jack
Mini Jack (stereo) x 1
(Output) Stereo Mini Jack
Built-in Speaker
1 Watt Monaural
Lamp
Network
Yes
Lamp Life
200 watt UHP
Remote Control
Sensor
Yes
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide
Temperature Operating
41º F ~ 95º F (5º C ~ 35º C)
Temperature Storage
14º F ~ 140º F (-10º C ~ 60º C)
Weight
6.4lbs
Warranty
3 years parts and labor, 120 day lamp life
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7230 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
