Web Content Viewer
Actions
LV-7240
Support LV Projectors
Features
At 2100 ANSI lumens, the LV-7240 is bright enough for a classroom or office setting with high levels of ambient light, or for your conference room or boardroom presentations in front of a large audience. No matter where you use it, you can be confident the affordable LV-7240 has the power to perform.<br/> <br/>
&#160; The LV-7240's native XGA (1024x768) resolution is the perfect resolution match for your laptop computer. Not only that, the LV-7240 also supports SXGA (1280x1024) resolution through high-quality scaling.<br/> <br/>
At the heart of the LV-7240's optical performance is its high quality 1.2x zoom lens. It's the only lens you'll need because the wide focal length range gives you the flexibility to project a screen from 21" to 300" in (diagonal) size. It also lets you use the projector in cramped quarters and still get a 100" (diagonal) screen with a short 9.8' throw. That means you're covered for a wide range of room sizes and projection distances.<br/> <br/> In addition to this performance, the LV-7240 boasts an 85% image uniformity for an even image from corner-to-corner.<br/> <br/> The LV-7240's optical performance is also enhanced through 5 pre-set projection modes, plus a custom mode that you adjust yourself.<br/> Standard mode emphasizes the reproduction of white, for standard viewing<br/> Presentation mode gives you higher contrast and brightness for brilliant presentations<br/> Cinema mode ensures the accurate projection of dark scenes, perfect for watching movies in darkened rooms<br/> Video mode is designed for projecting images of people for general TV broadcasts and video<br/> sRGB reproduces color adapted to the sRGB color space, making it suitable for sRGB images<br/> Custom mode lets you adjust gamma, white balance, brightness, contrast, sharpness, color, and hue<br/> Plus, you get precise color control with the LV-7240's Color Management System. Manually adjust color, hue (except with RGB input), brightness, contrast and sharpness for brilliant results.<br/> <br/>
Even with 2100 ANSI lumens of brilliance, the LV-7240 still weighs in at only 7.0lbs and measures only 11.6" x 10.2" x 3.7". So, no matter where you need its power, you can take the LV-7240 there with ease.<br/> <br/> And, no matter what the location, a variety of features make the LV-7240 easy to use. With Automatic Keystone Adjustment, you simply place your projector on a flat surface. Built-in sensors detect the tilt of the projector and automatically correct for keystone distortion -- up to +/- 30 degrees (vertical). (In addition, you can still adjust keystone correction manually.)<br/> <br/> In the classroom, the Greenboard mode lets you project onto a chalkboard -- the projector adjusts the projected image to maximize legibility and image quality. You can also project on walls and other non-white surfaces -- the LV-7240 lets you compensate for the color of the wall.<br/> <br/> All the while, you can be sure your audience isn't distracted by fan noise because the LV-7240 runs at a quiet 35dB in normal mode, and 30dB in quiet mode.<br/> <br/> Plus, you won't be distracted because you can operate your LV-7240 effortlessly with the help of the Wireless IR Remote Control and user-friendly control panel. The newly designed wireless remote gives you control over a range of functions, including: Auto PC Adjustment for optimizing the image quality of an RGB source; Source Select for choosing between 4 different input sources; Mouse Control for full control of a connected computer (with the addition of a remote mouse receiver in your PC's USB port). The user-friendly control panel on the projector lets you control volume, make menu selections and easily switch between 4 different input sources with the touch of a button.<br/> <br/> Plus, your LV-7240 is easy to operate because it requires a mere 9 seconds to start up. And it takes just 30 seconds to shut down, so you don't have to wait long to take it with you or put it away.<br/> <br/> Your LV-7240 also makes your life easier with:<br/> Audio speaker<br/> 3-year parts and labor warranty<br/> 120-day lamp life warranty<br/> Password protection and control panel key lock<br/> Attachable carrying handle<br/> <br/>
<br/> <br/> Find out how the LV-7240's XGA sharpness and clarity make all of your images look. With its advanced connectivity, this projector can handle virtually all of your electronic devices. Whether it's your computer, DVD player, HDTV, VCR, digital camcorder or digital camera, the LV-7240 makes them all look better. What's more, the LV-7240 lets you convert 480i/575i interlaced signals to progressive scan, giving you the outstanding image quality you demand.<br/> <br/> Not only that, but the LV-7240 is also compatible with NTSC, PAL, SECAM, NTSC 4.43, PAL-M and PAL-N signals for global portability.<br/> <br/>
LV-7240 Projector Kit
LV-7240 Projector Kit LV-7240 Body Wireless Remote Control (w/AAA batteries) VGA Computer Cable Lens Cap Soft Carrying Case Power Cable Remote Mouse Receiver Carrying Handle (w/screws and screwdriver)
Specifications
Projector Specifications
Imaging Device
0.7 p-Si TFT active-matrix with Micro Lens Array
Native Resolution
XGA
Brightness
2100 Im
Uniformity
85%
Contrast Ratio
380:1
Digital Keystone (Vertical)
+/- 30° Vertical (auto)
Optics
Projection Lens
VGA, SVGA, SXGA (through high-quality scaling), HDTV
Lens Shift
12:1
Zoom
1.6x Ultra-Wide Zoom Lens
Screen Size
40 - 300
Throw Distance
2.4 - 35.89 ft / 0.73 - 10.9 m
Input Signals
Scanning Frequency
Horizontal: 15 kHz to 100 kHz (RGB: 24 kHz or over)Vertical: 50 Hz to 120 Hz
Analog PC Input
Video/S-Video Input
NTSC, NTSC4.43, PAL, PAL-60, PAL-N, PAL-M, SECAMHDTV: 1080i, 1080i/50Hz, 720p, 576p, 480p, 480i/60Hz
Component Input
S-video, Composite, VGA, Audio, USB, Component*
Terminals
(Input) Stereo Mini Jack
1 Stereo Mini Audio, 1 Service Port (DIN 8 Pin)
(Output) Stereo Mini Jack
1 RGB (D-Sub 15 Pin), 1 Stereo Mini Audio
Built-in Speaker
1 Watt Monaural
Lamp
Network
RS232, IR
Lamp Life
200 watt UHP
Remote Control
Sensor
Yes
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide
Temperature Operating
41° to 95°F (5° to 35°C)20% to 80% humidity (non-condensing)
Temperature Storage
14° to 122°F (-10° to 50°C)20% to 80% humidity (non-condensing)
Weight
approx. 6.6 lbs / 3 kg
Warranty
3 years parts and labor, 120 day lamp life
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7240 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
