Web Content Viewer
Actions
LV-7285
Support LV Projectors
Features
The interface is also compliant with HDCP (High-bandwidth Digital Content Protection), ensuring a digital connection between HDCP compliant devices, such as many of today’s cable boxes, DVD and Blu-Ray players. The high quality of the DVI-I connection makes the new LV-7285 projector ideal for high definition TV, and is compatible with 1080i and 720p video signals.
Digital Image Shift
These projectors allow you to display widescreen content through high-quality compression. As a result, when widescreen content is displayed, pixels above and below the image are not used. The projectors Digital Image Shift conveniently allows you to move the projected image up or down on the screen, into these unused pixels without any further compression. This ability to "fine tune" the placement of the projected image can be useful when projecting onto a fixed screen, or when stacking projectors for increased brightness. Easy Access Lamp
An opening for replacing the lamp has been installed on the top of the projectors. Even if a projector is installed on the ceiling, the projectors lamp can be replaced without having to move the projector. In addition, a replacement counter will display a message indicating the time when lamps and filters need replacing. New Filter Design
The newly designed air-filter has the ability to significantly improve dust filtration over that of previous models. Textiles in an "accordion" construction have three times the filtering surface for a three-fold increase in dust filtration. A newly improved filter cover design further protects the internal optics of the projector by preventing intrusive dust and dirt from filling the inlet gaps.
LV-7285 Kit
LV-7285 Kit LV-7285 Projector with Lens Cover Remote Control (w/ 2 AAA batteries) VGA to VGA Computer Cable DVI to VGA Adapter Power Cable Soft Carrying Case Quick Start Guide CD ROM Warranty Card User Manual
Specifications
Projector Specifications
Imaging Device
0.63 Transmissive LCD Panels x 3
Aspect Ratio
4:3
Native Resolution
XGA (1024x768)
Brightness
2600 Lumens
Uniformity
85%
Contrast Ratio
500:1, 2000:1 with Auto Iris
Digital Keystone (Vertical)
± 30 degrees (Auto/Manual)
Digital Keystone (Horizontal)
N/A
Optics
Projection Lens
F1.7 - 2.0, f=19.8 - 23.7 mm
Lens Shift
8.4 - 1.6
Zoom
1.2x Manual
Focus
Manual
Screen Size
21 - 300 inches
Throw Distance
2.6 - 37.1 feet
Throw Ratio
1.53 - 1.84 : 1
Image Adjustments
Image Mode
Standard / Presentation / Cinema / Video / sRGB
Color Adjust
Brightness / Contrast / Sharpness / Gamma
Wall Correction
Whiteboard / Greenboard / Greenboard (gray) / Light Yellow / Light Green / Light Blue / Sky Blue / Light Rose / Pink
Mounting
Ceiling / Rear / Ceiling and Rear
Tilt Angle
Adjustable foot up to 10 degrees
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V:50 ~ 120 Hz, Dot clock: 108 MHz
Analog PC Input
UXGA / SXGA+ / SXGA / WXGA / XGA / SVGA / VGA / MAC
Digital PC Input
SXGA+ / SXGA / WXGA / XGA / SVGA / VGA / MAC, 1080i / 720p / 576p / 480p
Video/S-Video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N / PAL-60
Component Input
1080i / 720p / 576p / 576i / 480p / 480i
Terminals
(Input) DVI-I 29pin
Digital PC input (HDCP Compliant) / Analog (RGB) PC input
(Input) D-Sub 15pin
Analog RGB / Component input
(Input) RCA x1
Composite Video input
(Input) Mini DIN 4pin
S-Video Input
(Input) RJ-45
Yes
(Input) Stereo Mini Jack
Stereo audio input x2
(Output) D-Sub 15pin
Analog RGB output
(Output) Stereo Mini Jack
Stereo audio output x1
Built-in Speaker
7W (Mono)
Control Terminal
RS-232C
Lamp
Lamp Type
180W - NSHA
Lamp Life
4000 / 5000 Hours
Remote Control
Sensor
Front
Mouse Control
N/A
Ratings
Fan Noise (Quiet/Normal)
35 / 29 dB
Power Consumption (Normal/Quiet/Stand-By)
294W / 228W / 0.7W
Power Voltage
AC 100 ~ 240V, 50/60Hz
Temperature Operating
41° to 104° F (5° to 40° C), 20 ~ 80% RH
Temperature Storage
14° to 122° F (-10° to 50° C), 20 ~ 80% RH
Dimension (WxHxD)
12.48 x 4.37 x 13.23 (317 x 111 x 336 mm)
Weight
7.28 lbs. (3.3 kg)
Warranty
3 years parts and labor, 120 day lamp
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7285 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
