Web Content Viewer
Actions
LV-7290
Support LV Projectors
Features
<br/> Canon brings the best of LCD technology to the LV-7290 projector. This projector has been designed and specified to deliver the impressive image quality you expect from a Canon product. LCD technology allows the LV-7290 to be small, light and portable, while still giving it the capability to serve as a great installation unit.<br/> <br/>
<br/> With XGA (1024 x 768) resolution, the LV-7290 is an optimal match for your XGA laptop computer, allowing you to see clear, sharp video, diagrams and text. As a plus, the affordable LV-7290 also supports WXGA resolution on your widescreen laptop or PC through high quality compression. <br/>
<br/> The LV-7290's 2200 lumens will produce bright, clearly visible images, and the 2000:1 contrast ratio from the built-in auto iris will ensure deep blacks and bright whites. These features combine to create images with crisp depth and dimension, making them ideal for use in a classroom, office or boardroom.<br/><br/> Another major benefit of the LV-7290's AC lamp system is that it lasts up to 6,000 hours in Quiet Mode.<br/> <br/>
<br/> It's important to be able to place your projector precisely where you want or need to and to change the screen size to best fit the space in which you are presenting. Both are easy thanks to the 1.2x optical zoom lens of the LV-7290.<br/><br/> The lens also allows you to take full advantage of the LV-7290's wide projection distance coverage, from 4.3 feet to 38.7 feet (screen sizes 40" - 300"), giving it outstanding flexibility for use in small or moderately large spaces. <br/>
<br/> Longer Lamp Life<br/><br/> The extended lamp life of the LV-7290, with up to 4,000 hours in Normal Mode and 6,000 hours in Quiet Mode possible, lowers operating costs and reduces maintenance.<br/><br/> &nbsp; Longer Air Filter Life<br/><br/> Employing three-layer hybrid filters, consisting of perforated metal, urethane and metal mesh, anti-dust performance is greatly improved and filter life is dramatically lengthened over that of single layer electrostatic filters. The filter in the LV-7290 can last up to 5,500 hours in ECO Mode, greatly reducing maintenance time.<br/><br/> <br/><br/> &nbsp; Easy Access Lamp<br/><br/> For a quick and easy replacement, the LV-7290's lamp is located on the top of the projector. There is no need to move the projector, even if it is ceiling mounted.<br/><br/> To further aid in maintenance, a replacement counter indicates when the lamp and filter require changing. <br/>
<br/> Quick Start and Quick Power Off<br/><br/> Quick Start and Quick Power Off make it more convenient to operate the LV-7290 and help to lengthen lamp life. With the push of a button this projector will quickly spring into action for a spur-of-the-moment presentation, or shut down to be packed for use in another meeting room.<br/><br/> &nbsp; Auto Setup Function<br/><br/> Setting up the LV-7290 is both quick and easy with the Auto Setup function. Through a single button you can set Auto Input, Auto PC and Auto Keystone correction.<br/><br/> With the projector placed on a flat surface, the engagement of Auto Setup will employ sensors which will detect the tilt of the projector in relation to the screen, automatically correcting for any keystone distortion &mdash; up to +/- 20 degrees vertically. Of course, keystone correction can be adjusted manually as well up to +/- 30 degrees.<br/><br/> <br/><br/> &nbsp; Control Panel<br/><br/> The focus of a presenter should be on the presentation, not on running the projector. The LV-7290 makes it easy to do so with simple and clear controls for volume and menu selections. It is simple to switch between a choice of input sources at the touch of a button. Buttons which are familiar in look and feel to those of printers and copy machines fall to hand easily. For added convenience, the wireless IR remote control can be used.<br/><br/> &nbsp; Tab-Style Menu<br/><br/> Navigate with ease through the LV-7290's on-screen menu to find the setting right for your needs. It's easy to read, as the white text on black background display is clear and sharp. Choose from 21 languages for the menu display.<br/><br/> &nbsp; Multiple Image Modes<br/><br/> Users can select from multiple Image Modes to ensure content is optimally displayed. Presentation &ndash; bright setting that emphasizes contrast overall - most suitable for presentations (PowerPoint, etc).<br/><br/> Standard &ndash; setting that provides standard easy-to-see images.<br/><br/> High Contrast &ndash; provides clear, easy-to-see images in brighter environments.<br/><br/> Cinema &ndash; setting best suited for movie projection (DVD and HDTV) as it excels at providing gradations of dark portions of images.<br/><br/> Blackboard (Greenboard) &ndash; reproduces close hues when projecting on classroom blackboards.<br/><br/> Colorboard &ndash; reproduces close hues when projecting on colored walls. In addition, on the image quality adjustment menu users can manually perform more detailed settings such as contrast, hue and brightness and then save those settings to memory in one of 4 User Image Modes.<br/><br/> &nbsp; Built-in Speaker<br/><br/> Even if you don't have an external sound system to use, the 10W high output speaker of the LV-7290 delivers clear, well produced sound for venues of varying sizes.<br/><br/> <br/>
<br/> The LV-7290 connects to a variety of devices, including laptop and desktop computers, DVD players, and digital cameras and camcorders.<br/><br/> <br/><br/> &nbsp; Network-ready RJ-45 Port<br/><br/> To maximize the usability of the LV-7290, the built-in RJ-45 port enables centralized control and monitoring from a networked PC. This makes it simple for an A/V team to operate ceiling mounted installed projectors from a remote PC, allowing fewer personnel to cover a larger service area.<br/><br/> &nbsp; RS-232 Serial Port<br/><br/> The LV-7290's RS-232 Serial Port allows for local control of the LV-7290 through a third-party control system.<br/><br/> &nbsp; Multiple Audio Inputs & Output<br/><br/> Two audio Mini-Jack stereo inputs and one output are found on the LV-7290 for relaying audio through external speakers. It provides the flexibility needed to play audio from a linked DVD or PC source. <br/>
Quiet Operation
Enjoy near silence during a presentation with the quiet operation of the LV-7290. Your audience won't be distracted by fan noise: in Normal mode the LV-7290 runs at 36dB and in Quiet mode the level is reduced to 29dB.
Closed Captioning Closed Captioning
When giving a presentation in a noisy environment or for a hearing impaired audience, the closed captioning option of LV-7290 makes it even more effective. Your audience will be able to easily understand difficult dialogue.
<br/> Canon USA Projector and Lamp Limited Warranty<br/><br/> This new projector comes with Canon USA's Projector and Lamp Limited Warranty, which guarantees that the projector will be free from defects in workmanship and materials for 3&nbsp;years from the date of original purchase, and the lamp for 120 days from the date of original purchase.<br/> &nbsp; Projector Protection Program (Triple P)<br/><br/> The LV-7290 is also backed by Canon USA's Projector Protection Program* ("Triple P"). Triple P is a FREE service program that provides a loaner projector of equal or greater value in the event that a qualifying unit is in need of repair. Triple P is available on all Canon projector models during the Canon USA Projector and Lamp Limited Warranty.<br/><br/> * Loaner units based on availability. Program subject to change at any time without given notice. Contact the Canon Customer Support Center at 1.800.828.4040 for complete details. <br/>
LV-7290
LV-7290 LV-7290 LCD Projector Lens Cap (with strap) AC Power Cord Remote Control (with AAA batteries) VGA to VGA Connection Cable (Mini D-sub 15-pin/Mini D-sub 15-pin) CD-ROM Quick Start Guide
Specifications
Projector Specifications
Imaging Device
0.55 Active Matrix x 3
Aspect Ratio
4:3
Native Resolution
XGA (1024 x 768)
Brightness
2200 Lumens
Uniformity
85%
Contrast Ratio
2000:1
Digital Keystone (Vertical)
+/- 30 degrees (Manual); +/- 20 degrees (Auto)
Optics
Projection Lens
F2.0 - 2.15, f=18.38 - 22.06mm
Zoom
1.2x Zoom (Manual)
Focus
Manual
Screen Size
40 - 300
Throw Distance
4.3 - 38.7 ft. (1.3 - 11.8m)
Image Adjustments
Image Mode
Presentation, Standard, High Contrast, Cinema, Blackboard (Green), Colorboard, User 1-4
Wall Correction
Yes
Mounting
Ceiling, Rear, Rear-Ceiling, Upwards, Downwards
Tilt Angle
Adjusting foot up to 10 degrees
Input Signals
Scanning Frequency
H:15~100 kHz, V:50~100 Hz
Analog PC Input
WUXGA / UXGA / SXGA+ / SXGA / WXGA / XGA / SVGA / VGA / MAC
Video/S-Video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N / PAL-60
Component Input
1080i / 1035i / 720p / 575p / 575i / 480p / 480i
Terminals
(Input) D-Sub 15pin
Analog RGB / Component video / S-video input
(Input) RCA x1
Composite Video input
(Input) RJ-45
Yes
(Input) Stereo Mini Jack
Stereo Audio input x 2
(Output) D-Sub 15pin
Analog RGB output
(Output) Stereo Mini Jack
Stereo Audio output
Built-in Speaker
10W (Mono)
Control Terminal
RS-232C
Lamp
Lamp Type
215W UHP
Lamp Life
4000 / 6000 Hours (Normal / Quiet)
Remote Control
Sensor
Wireless Infrared, Front
Ratings
Fan Noise (Quiet/Normal)
29 / 36dB
Power Consumption (Normal/Quiet/Stand-By)
266W / 6.6W / 0.4W
Power Voltage
AC100 to 240V, 50/60Hz
Temperature Operating
41° to 95° F (5° to 35° C)
Temperature Storage
14° to 140° F (-10° to 60° C), 5%RH ~ 90%RH
Dimension (WxHxD)
13.13 x 3.98 x 9.72 (333 mm x 101 mm x 247 mm)
Weight
6.6 lbs
Warranty
3 Year Parts and Labor / 120 Day on Lamp
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7290 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
