Web Content Viewer
Actions
LV-7295
Support LV Projectors
Features
<br/> Designed to deliver impressive image quality, the LV-7295 has the best of LCD technology, which allows it to be small, light and portable, but still have the performance to serve as a very capable installation projector.<br/> <br/>
<br/> For clear, sharp video, diagrams and text, the LV-7295's native XGA (1024 x 768) resolution delivers. It is perfect when paired up with your XGA laptop computer, and through high quality compression will also support a widescreen WXGA resolution computer. <br/>
<br/> You will see bright, clearly visible images with the to the LV-7295's 2600 lumens. Adding to the quality is a 2000:1 contrast ratio, thanks to the projector's built-in auto iris, which produces deep blacks and bright whites.<br/><br/> Another major benefit of the LV-7295's AC lamp system is that it lasts up to 6,000 hours in Quiet Mode.<br/> <br/>
<br/> With the LV-7295's 1.2x optical zoom lens, you can pick the spot you want to place the projector in the room and choose just the right screen size, secure in knowing that the LV-7295's lens will fit your needs.<br/><br/> You'll have the benefit of the LV-7295's impressive distance coverage, from 4.3 feet to 38.7 feet (screen sizes 40" - 300"). It's just the kind of flexibility you'll need in small or moderately large spaces. <br/>
<br/> Longer Lamp Life<br/><br/> You'll experience lower operating costs and reduced maintenance time thanks to the extended lamp life of the LV-7295. It's possible to go up to 4,000 hours in Normal Mode and 6,000 hours in Quiet Mode before changing the lamp.<br/><br/> &nbsp; Longer Air Filter Life<br/><br/> Employing three-layer hybrid filters, consisting of perforated metal, urethane and metal mesh, anti-dust performance is greatly improved and filter life is dramatically lengthened over that of single layer electrostatic filters. The filter in the LV-7295 can last up to 5,500 hours in ECO Mode, significantly reducing maintenance time.<br/><br/> <br/><br/> &nbsp; Easy Access Lamp<br/><br/> For a quick and easy replacement, the LV-7295's lamp is located on the top of the projector. Even if it's mounted on the ceiling, there's no need to move the projector to change the lamp.<br/><br/> To further aid in maintenance, a replacement counter indicates when the lamp and filter require changing. <br/>
<br/> To make the LV-7295 as user friendly as possible, it's been loaded with features and controls tailored to enhance convenience and make it easier to operate.<br/><br/> Quick Start and Quick Power Off<br/><br/> Quick Start and Quick Power Off make it more convenient to operate the LV-7295 and help to lengthen lamp life. With the push of a button this projector will quickly spring into action for a spur-of-the-moment presentation, or shut down to be packed for use in another meeting room.<br/><br/> &nbsp; Auto Setup Function<br/><br/> Setting up the LV-7295 is both quick and easy with the Auto Setup function. Through a single button you can set Auto Input, Auto PC and Auto Keystone correction.<br/><br/> With the projector placed on a flat surface, the engagement of Auto Setup will employ sensors which will detect the tilt of the projector in relation to the screen, automatically correcting for any keystone distortion &mdash; up to +/- 20 degrees vertically. Of course, keystone correction can be adjusted manually as well up to +/- 30 degrees.<br/><br/> <br/><br/> &nbsp; Control Panel<br/><br/> The focus of a presenter should be on the presentation, not on running the projector. The LV-7295 makes it easy to do so with simple and clear controls for volume and menu selections. It is simple to switch between input sources at the touch of a button. Buttons which are familiar in look and feel to those of printers and copy machines fall easily to hand. For added convenience, the wireless IR remote control can be used.<br/><br/> &nbsp; Tab-Style Menu<br/><br/> Navigate with ease through the LV-7295's on-screen menu to find the right setting for your needs. It's easy to read, as the white text on black background display is clear and sharp. Choose from 21 languages for the menu display.<br/><br/> &nbsp; Multiple Image Modes<br/><br/> Users can select from multiple Image Modes to ensure content is optimally displayed. Presentation &ndash; bright setting that emphasizes contrast overall - most suitable for presentations (PowerPoint, etc).<br/><br/> Standard &ndash; setting that provides standard easy-to-see images.<br/><br/> High Contrast &ndash; provides clear, easy-to-see images in brighter environments.<br/><br/> Cinema &ndash; setting best suited for movie projection (DVD and HDTV) as it excels at providing gradations of dark portions of images.<br/><br/> Blackboard (Greenboard) &ndash; reproduces close hues when projecting on classroom blackboards.<br/><br/> Colorboard &ndash; reproduces close hues when projecting on colored walls. In addition, on the image quality adjustment menu users can manually perform more detailed settings such as contrast, hue and brightness and then save those settings to memory in one of 4 User Image Modes.<br/><br/> &nbsp; Built-in Speaker<br/><br/> Even if you don't have an external sound system to use, the 10W high output speaker of the LV-7295 delivers clear, well produced sound for venues of varying sizes.<br/><br/> <br/>
<br/> The LV-7295 connects to a variety of devices, including laptop and desktop computers, DVD players, and digital cameras and camcorders.<br/><br/> <br/><br/> Network-ready RJ-45 Port<br/><br/> The built-in RJ-45 port enables a networked PC to provide centralized control and monitoring of the projector. It's especially useful for A/V teams which need to operate ceiling mounted installed projectors from a single remote location. You will need less in resources to accomplish more.<br/><br/> &nbsp; RS-232 Serial Port<br/><br/> The LV-7295's RS-232 Serial Port allows for local control of the LV-7295 through a third-party control system.<br/><br/> &nbsp; Multiple Audio Inputs & Output<br/><br/> If you need to use a linked DVD or PC source for audio, the LV-7295 is equipped with two audio Mini-Jack stereo inputs and one output for relaying audio through external speakers. <br/>
Quiet Operation
The LV-7295 runs quietly, with ratings of only 36dB in Normal mode and a mere 29dB in Quiet mode. Neither you nor your audience will be distracted by unwanted fan noise.
Closed Captioning Closed Captioning
A closed captioning capability comes in handy when delivering a presentation to a hearing impaired audience or presenting in an environment with too much ambient noise. In either case, your audience will be able to easily understand difficult dialogue.
<br/> Canon USA Projector and Lamp Limited Warranty<br/><br/> This new projector comes with Canon USA's Projector and Lamp Limited Warranty, which guarantees that the projector will be free from defects in workmanship and materials for 3&nbsp;years from the date of original purchase, and the lamp for 120 days from the date of original purchase.<br/><br/> &nbsp; Projector Protection Program (Triple P)<br/><br/> The LV-7295 is also backed by Canon USA's Projector Protection Program* ("Triple P"). Triple P is a FREE service program that provides a loaner projector of equal or greater value in the event that a qualifying unit is in need of repair. Triple P is available on all Canon projector models during the Canon USA Projector and Lamp Limited Warranty.<br/><br/> * Loaner units based on availability. Program subject to change at any time without given notice. Contact the Canon Customer Support Center at 1.800.828.4040 for complete details. <br/>
LV-7295
LV-7295 LV-7295 LCD Projector Lens Cap (with strap) AC Power Cord Remote Control (with AAA batteries) VGA to VGA Connection Cable (Mini D-sub 15-pin/Mini D-sub 15-pin) CD-ROM Quick Start Guide
Specifications
Projector Specifications
Imaging Device
0.55 Active Matrix x 3
Aspect Ratio
4:3
Native Resolution
XGA (1024 x 768)
Brightness
2600 Lumens
Uniformity
85%
Contrast Ratio
2000:1
Digital Keystone (Vertical)
+/- 30 degrees (Manual); +/- 20 degrees (Auto)
Optics
Projection Lens
F2.0 - 2.15, f=18.38 - 22.06mm
Zoom
1.2x Zoom (Manual)
Focus
Manual
Screen Size
40 - 300
Throw Distance
4.3 - 38.7 ft. (1.3 - 11.8m)
Image Adjustments
Image Mode
Presentation, Standard, High Contrast, Cinema, Blackboard (Green), Colorboard, User 1-4
Wall Correction
Yes
Mounting
Ceiling, Rear, Rear-Ceiling, Upwards, Downwards
Tilt Angle
Adjusting foot up to 10 degrees
Input Signals
Scanning Frequency
H:15~100 kHz, V:50~100 Hz
Analog PC Input
WUXGA / UXGA / SXGA+ / SXGA / WXGA / XGA / SVGA / VGA / MAC
Video/S-Video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N / PAL-60
Component Input
1080i / 1035i / 720p / 575p / 575i / 480p / 480i
Terminals
(Input) D-Sub 15pin
Analog RGB / Component video / S-video input
(Input) RCA x1
Composite Video input
(Input) RJ-45
Yes
(Input) Stereo Mini Jack
Stereo Audio input x 2
(Output) D-Sub 15pin
Analog RGB output
(Output) Stereo Mini Jack
Stereo Audio output
Built-in Speaker
10W (Mono)
Control Terminal
RS-232C
Lamp
Lamp Type
215W UHP
Lamp Life
4000 / 6000 Hours (Normal / Quiet)
Remote Control
Sensor
Wireless Infrared, Front
Ratings
Fan Noise (Quiet/Normal)
29 / 36dB
Power Consumption (Normal/Quiet/Stand-By)
286W / 6.6W / 0.4W
Power Voltage
AC100 to 240V, 50/60Hz
Temperature Operating
41° to 95° F (5° to 35° C)
Temperature Storage
14° to 140° F (-10° to 60° C), 5%RH ~ 90%RH
Dimension (WxHxD)
13.13 x 3.98 x 9.72 (333 mm x 101 mm x 247 mm)
Weight
6.6 lbs.
Warranty
3 Year Parts and Labor / 120 Day on Lamp
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7295 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
