Web Content Viewer
Actions
LV-7297M
Support LV Projectors
Features
<br/> With the current demand for high resolution display&nbsp;applications, the native XGA (1024 X 768) resolution of the LV-7297M delivers clear, sharp video, diagrams and text in a 4:3 aspect ratio. Compared to standard SVGA&nbsp;resolution&nbsp;projectors, the LV-7297M offers a far more detailed image, with more source information displayed on the screen. This is especially important when displaying graphs, charts and spreadsheets. <br/>
<br/> The 2600 Lumens of the LV-7297M gives you expanded choice in choosing your venue, allowing clear, crisp display in what might be less than ideal rooms. Adding to the usefulness is the long-life lamp of the LV-7297M, which can last up to 6,000 hours in Eco Mode. <br/>
<br/> The 1.2x Optical Zoom lens of the LV-7297M allows you to have more choice over where you place the projector in your venue. You will also enjoy the choice of a wide range of screen sizes on which to show your presentation, further tailoring your presentation to the room and making it more immediate for your audience. The lens of the LV-7297M has a very useful range in projection distance coverage, from 4.27 feet to 38.71 feet (screen sizes 40" to 300"). It adds to the flexibility you'll have in using this projector in smaller to moderately large spaces. <br/>
<br/> The range of input and output terminals with which the LV-7297M is equipped makes it a versatile partner of a wide variety of external sources. HDMI Input<br/> The HDMI input on the LV-7297M allows you to connect the projector directly to a high-definition input source, including satellite or digital cable boxes and Blu-ray players, to project uncompressed video images and deliver true 1080p high-definition. RS-232C Serial Port<br/> A third-party system can be used to control the LV-7297M through the built-in RS-232C Serial Port. Video Input & Output<br/> The LV-7297M has a composite video input for high-definition video projection. Multiple Audio Inputs & Output<br/> Two audio Mini-Jack stereo inputs and one output are found on the LV-7297M for relaying audio through external speakers. This provides the flexibility needed to play audio from a linked DVD or PC source. A&nbsp;microphone input also gives the user the ability to narrate a presentation making use of the LV-7297M's built-in 1W speaker. <br/>
<br/> The high performance of the LV-7297M is matched with impressive durability in use and simplified maintenance. While delivering more, it costs you less in time and maintenance. Longer Lamp Life<br/> With up to 4,000 hours lamp life in Normal Mode and 6,000 hours in Eco Mode possible, maintenance is reduced and operating costs are lowered. Longer Air Filter Life<br/> The high performance three layer hybrid filters of the LV-7297M can last up to 5,500 hours in Eco Mode. Since they consist of perforated metal, urethane and metal mesh, anti-dust performance is greatly improved and filter life is dramatically lengthened over that of single layer electrostatic filters. This offers significantly reduced maintenance time. To further aid in maintenance, replacement counters indicate when lamps and filters require changing. <br/>
<br/> The latest in LCD technology allows the LV-7297M to be small, light and portable, while still giving you the option to utilize it as an installed unit. Convenience and ease of use were among the main goals of Canon's designers when they created the LV-7297M, in order to allow you to concentrate on the presentation and your audience rather than projector operation. Direct Power On/Off<br/> The direct power on/off feature of the LV-7297M allows for more flexible installation on ceilings or walls. It will automatically turn on the projector when the power cord is plugged into an outlet and off when the plug is removed. There is no need to press the power button on the projector, which might be difficult in certain installation situations. Auto Setup Function<br/> Setting up the LV-7297M is both quick and easy with the Auto Setup function. Through a single button you can set Auto Input, Auto PC and Auto Keystone correction. With the projector placed on a flat surface, the engagement of Auto Setup will employ sensors which will detect the tilt of the projector in relation to the screen, automatically correcting for any keystone distortion &mdash; up to +/- 20 degrees vertically. Of course, keystone correction can be adjusted manually as well up to +/- 30 degrees. Control Panel<br/> Easy to use and clear controls for volume and menu mean that the focus of a presenter will be on the presentation, not on running the projector. The LV-7297M makes it simple to switch between input sources at the touch of a button. For added convenience, the wireless IR remote control can be used. Tab-Style Menu<br/> The clear navigation of the LV-7297M's on-screen menu is easy to use. For added convenience, choose from 20 languages for the menu display.&nbsp; Available are English, German, French, Italian, Spanish, Portuguese, Dutch, Swedish, Finnish, Polish, Hungarian, Romanian, Russian, Turkish, Kazakh, Vietnamese, Chinese, Korean, Japanese and Thai. Built-in 1W Speaker<br/> Even if you don't have an external sound system to use, the 1W speaker of the LV-7297M delivers well produced sound for venues of varying sizes, faithfully reproducing music or voice. <br/>
<br/> Give your audience the silent treatment with the quietness of the LV-7297M. In Normal Mode the projector runs at 36.4dB and drops to 29dB in Eco Mode, allowing all ears to be on the presentation. <br/> Closed Captioning Closed Captioning<br/> When you are presenting to a hearing impaired audience or find yourself in a venue with a high level of ambient noise, the LV-7297M can deliver closed captioning to make any difficult to understand dialogue perfectly clear. <br/>
<br/> Canon USA Projector and Lamp Limited Warranty<br/> The LV-7297M projector is backed by Canon USA's Projector and Lamp Limited Warranty, which guarantees that it will be free from defects in workmanship and materials for 3&nbsp;years from the date of original purchase, and the lamp for 120 days from the date of original purchase. Projector Protection Program<br/> Canon's Projector Protection Program (Triple P) is a FREE service program that provides a loaner projector of equal or greater value in the event that a qualifying unit is in need of repair. Triple P is available on all Canon projector models. <br/>
LV-7297M
LV-7297M LV-7297M LCD Projector with Lens Cap Remote Control (with 2 AAA batteries) VGA cable Power cable Quick Start guide(Book) Users Manual (CD-ROM) Warranty card
Specifications
Projector Specifications
Imaging Device
0.55 TFT
Aspect Ratio
4:3
Native Resolution
XGA (1024 x 768)
Brightness
2600 Lumens
Uniformity
85%
Contrast Ratio
500:1
Digital Keystone (Vertical)
+/- 30° (Manual); +/- 20° (Auto)
Optics
Projection Lens
F2.0 - 2.15, f=18.38 - 22.06mm
Zoom
1.2x Zoom (Manual)
Focus
Manual
Screen Size
40 - 300
Throw Distance
4.3 - 38.7 ft. (1.3 - 11.8m) 100: 10.8 - 12.8 ft. (3.3 - 3.9m)
Throw Ratio
1.6 - 1.93:1 (at 100)
Image Adjustments
Image Mode
Presentation, Standard, High Contrast, Cinema, Blackboard, Greenboard, Colorboard
Color Adjust
Yes
Wall Correction
Red, Blue, Yellow, Green, Blackboard, Greenboard
Mounting
Ceiling, Rear, Rear-Ceiling, Upwards, Downwards, Wall
Tilt Angle
Front Foot, 10°
Input Signals
Scanning Frequency
H:15 - 93 kHz, V:50 - 120 Hz
Analog PC Input
WUXGA / UXGA / SXGA+ / SXGA / WXGA / XGA / SVGA / VGA / MAC
Digital PC Input
WSXGA+ / SXGA+ / SXGA / WXGA+ / WXGA / XGA / SVGA / VGA
Video/S-Video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N
Component Input
1080i / 720p / 576p / 576i / 480p / 480i
Digital Video Input
1080p / 1080i / 720p / 576p / 576i / 480p
Terminals
(Input) D-Sub 15pin
Analog RGB / Component video input
(Input) RCA x1
Composite Video input
(Input) Stereo Mini Jack
3.5mm (Stereo Minijack) x2 / RCA x2 (Stereo)
(Output) Stereo Mini Jack
3.5mm (Stereo) x1
Built-in Speaker
1W (Mono)
Control Terminal
RS-232C
Lamp
Lamp Type
215-UHP
Lamp Life
4000 (Normal) / 6000 (Eco) Hours
Remote Control
Sensor
Infrared
Ratings
Fan Noise (Quiet/Normal)
29dB (Eco) / 36.4dB (Normal)
Power Voltage
AC 100 - 240V, 50/60 Hz
Temperature Operating
41° to 95° F (5° to 35° C), 20-80%RH
Temperature Storage
14° to 140° F (-10° to 60° C), 5% - 80%RH
Dimension (WxHxD)
13.01 x 3.94 x 9.63 (333.5 mm x 101 mm x 247 mm); not including protrusions
Warranty
3 Year Parts and Labor / 120 Days Lamp Life
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7297M that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
