Web Content Viewer
Actions
LV-7320
Support LV Projectors
Features
Up to 1250 ANSI lumens (LV-7320 with Turbo Bright), Canon has given you the tools you need to communicate powerfully in any situation.
LV-7320 Multimedia Projectors have combined powerful brightness with portability, giving you literally the best of both worlds.
The LV-Series Multimedia Projectors feature a large-diameter multi-group projection lens system which provides low image distortion and exceptionally uniform brightness. This is combined with new, ultra-bright UHP lamps 150W for the LV-7320. Add to this Canon's exclusive Turbo Bright system, which boosts light output 25% more-- without increasing power consumption, lamp wear, or cost.
Each of the LV-7320 Multimedia Projectors packs a lot of brightness into a manageably-sized machine. But brightness alone doesn't make an effective presentation. That's why you'll be glad to have these other powerful features: Digital Keystone: Weird, trapezoidal images aren't effective communicators. With some projectors, that's what you get unless you can place the device at just the right angle.<br/> Inverse Projection: Inverse projection provides the flexibility to install in either top-up or top-down orientation.<br/> Versatility: Compatibility with PC, Macintosh, and workstations (including Unix) lets you plug in to the computer that's available to you. Perfect for situations where you have to move from room to room utilizing different set-ups.
Specifications
Projector Specifications
Imaging Device
0.7 p-Si TFT active-matrix with Micro Lens Array
Native Resolution
XGA
Brightness
2500 Im
Uniformity
90%
Contrast Ratio
250:1
Digital Keystone (Vertical)
(+/-) 12 degrees
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, HDTV,DTV
Lens Shift
19:1
Zoom
1.3 x
Screen Size
30.7-43mm
Throw Distance
2.4 - 35.89 ft / 0.73 - 10.9 m
Input Signals
Scanning Frequency
Horizontal: 15 kHz to 100 kHz (RGB: 24 kHz or over)Vertical: 50 Hz to 120 Hz
Analog PC Input
Video/S-Video Input
NTSC,PAL,SECAM,NTSC,4.43, PAL-M, PAL-N
Component Input
S-video, Composite, VGA, Audio
Terminals
(Input) Stereo Mini Jack
1 Stereo Mini Audio, 1 Service Port (DIN 8 Pin)
(Output) Stereo Mini Jack
1 RGB (D-Sub 15 Pin), 1 Stereo Mini Audio
Built-in Speaker
1 Watt Monaural
Lamp
Network
Yes
Lamp Life
150 watt UHP
Remote Control
Sensor
Yes ( includes laser pointer)
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide
Temperature Operating
41° to 95°F (5° to 35°C)20% to 80% humidity (non-condensing)
Temperature Storage
14° to 122°F (-10° to 50°C)20% to 80% humidity (non-condensing)
Weight
9.4lbs
Warranty
3 years parts and labor, 120 day lamp life
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7320 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
