Web Content Viewer
Actions
LV-7365
Support LV Projectors
Features
<br/> With its more powerful 3000 ANSI lumens lamp, the LV-7365 is among the brightest of Canon's portable XGA resolution projectors. Even in a classroom or office with high levels of ambient light, your audience will be sure to see every brilliant detail of your presentation. You can even use your LV-7365 to present in front of large audiences in conference and boardroom environments.<br/> <br/>And you'll be able to use that brightness longer, thanks to a Long Life Lamp which delivers up to 3000 hours of use in Quiet Mode.<br/> <br/>
The LV-7365 offers native XGA (1024x768) resolution for your images, making it a perfect match for your laptop computer. In addition, the LV-7365 supports both UXGA and SXGA resolution through high-quality compression. You can also project digital input with no loss in quality thanks to the LV-7365's available DVI interface. It enables you to have an all-digital connection between the projector and your input source. With no signal conversion to analog RGB, what you send to the LV-7365 is what you see on the screen in front of you.<br/> <br/>
Superior clarity and color are the hallmarks of Genuine Canon projection lenses. And with a 1.6x wide-angle zoom, the new LV-7365 is perfect for small rooms, allowing you to project bigger images from shorter distances. The LV-7365's short throw distance means you can project that crisp image on a 100" screen that's as close as 9'2" away from the projector.<br/> <br/> <br/> <br/> The LV-7365 also features five automatic image modes and one User (custom) mode: Presentation -- Ideal for presentations using PowerPoint Video -- For projecting standard video, such as TV broadcasts Cinema -- For projecting film-based video, such as movies (DVD or HDTV) Standard -- When maximum color accuracy is desired for viewing graphics sRGB -- For reproducing color adapted to the sRGB color space; suitable for sRGB content User (custom) -- A customizable mode that allows users to modify gamma and other settings. Gamma adjustment is useful for images that are too dark or too bright. The LV-7365 features enhanced Wall Color Correction, allowing you to project onto non-white surfaces such as a chalkboard or wall. Select from several wall color options including greenboard, greenboard gray, light yellow, light green, light blue, sky blue, light rose and pink for quick adaptive color correction. The image you project will be closer in appearance to how it would look when projected on a white background.<br/> <br/>
Weighing in at only 7.3 lbs. (3.3 kg) and measuring only 12.2"w x 10.4"d x 4.3"h (310mm x 265mm x 109mm), the LV-7365 is both lightweight and versatile, making it a preferred choice for those on the go.<br/><br/> Once at your destination, the LV-7365 gives you further flexibility by adapting to the environment. With Automatic Keystone Adjustment, for example, you simply place your projector on a flat surface. Built-in sensors detect the tilt of the projector and automatically correct for keystone distortion -- up to +/- 30 degrees vertically (of course, you can still adjust keystone correction manually).<br/><br/> The LV-7365 can operate as a front- or rear-screen projector and can be mounted on the ceiling.<br/><br/> For enhanced Wall Color Correction, the greenboard mode lets you project onto non-white surfaces, such as a chalkboard. Select from eight different wall color options for quick adaptive color correction, making the projected images closer in appearance to how they would look when projected on a white background.<br/><br/> Naturally, your LV-7365 does all this while still running at a low 35dB in normal mode and 29dB in Quiet Mode. It also boasts Quick Start and Quick Cooling, starting up in about eight seconds and cooling down within 30 seconds. The Automatic Power Off Timer gives you eight selectable presets with timing between 30 minutes and 16 hours.<br/><br/> During your presentation, you'll also be also able to stay focused thanks to the LV-7365's Wireless IR Remote Control, intuitive on-screen menus and user-friendly control panel.<br/><br/> The newly-designed wireless remote gives you control over a range of functions, including: Auto PC Adjustment for optimizing the image quality of an RGB source Source Select for choosing between four different input sources Mouse Control for full control of a connected computer (with the addition of a remote mouse receiver in your PC's USB port) Buttons are grouped and arranged in a smooth flow from top to bottom in order of each main function, making projector and presentation control more simple than ever.<br/><br/> On LV-7365 projectors, the remote control can also be paired with the supplied remote mouse receiver, allowing you to wirelessly control your computer from across a room. Mouse control is enabled by connecting the projector's remote mouse receiver to your PC's USB port and a drag-and-drop feature makes it easier than ever to use.<br/><br/> The user-friendly control panel, meanwhile, lets you control volume, make menu selections and easily switch between four different input sources with the touch of a button and displays settings on-screen with clearly labeled adjustments.<br/><br/> Lastly, your LV-7365 makes your life even easier with: A built-in 5W Mono audio speaker Three-year parts and labor limited warranty 120-day Lamp Life warranty Password protection and control panel key lock Attachable carrying handle <br/>
The LV-7365's versatile<br/> connectivity options <br/> <br/> Always ready for diverse input sources, the LV-7365 projector offers you effortless connection to laptops and desktop computers, DVD players, digital cameras and camcorders, VCRs, and other devices. In particular, thanks to the high-quality component video connection, the LV-7365 is ideal for DVD and HDTV (1080i, 720p, 575p, 575i, 480p, and 480i).<br/><br/> For projecting video, the LV-7365 eliminates distracting, noise-like interference (caused, for example, by pinstriped clothing or intricate line patterns). Subtle flickering of subtitles is also prevented.<br/><br/> The projector's Analog VGA Out terminal further allows users to connect the projector to an external monitor - a practical feature in settings where the projector is hooked up to a desktop PC rather than a laptop.<br/><br/> Recognizing the need to project digital output with the highest possible quality, the LV-7365 also boasts a DVI interface. This DVI-I high-speed interface allows you to keep an all-digital connection between your source and the projector. By avoiding the conversion needed by an analog RGB interface, high signal integrity is maintained and your projected images are as sharp as they leave your source.<br/> <br/>
LV-7365 Kit Contents
LV-7365 Kit Contents LV-7365 Projector Wireless Remote Control VGA Computer Cable DVI to VGA Adapter Lens Cap Remote Mouse Receiver Soft Carrying Case Power Cable Warranty Card CD-ROM User's Manual
Specifications
Projector Specifications
Imaging Device
0.63 p-Si TFT LCD X3
Aspect Ratio
4:3
Native Resolution
(1024 x 768) XGA
Brightness
3000
Uniformity
85%
Contrast Ratio
500:1
Digital Keystone (Vertical)
+/- 30 Degree (Auto)
Optics
Projection Lens
F1.6 - 2.5, f=17.7 - 28.3 mm
Lens Shift
8.4:1.6, Fixed
Zoom
1.6x Manual
Focus
Manual
Screen Size
25 - 300
Throw Distance
3.5-27.7ft. / 100:9.2-14.3 ft.
Throw Ratio
1.37-2.14:1
Image Adjustments
Image Mode
Presentation, Video, Cinema, Standard, sRGB, Custom
Color Adjust
RGB Manual
Wall Correction
Auto
Mounting
Ceiling / Rear / Ceiling and Rear
Tilt Angle
Adjusting Feet up to 100 degrees
Input Signals
Scanning Frequency
H:15~100kHz, V:50~120kHz, Dot Clock 108MHz
Terminals
Built-in Speaker
5W Mono
Control Terminal
RS-232C (8pin Mini-DIN)
Lamp
Lamp Type
210W NSH
Lamp Life
3000 / 2000 Hours (Normal / Quiet)
Remote Control
Sensor
Wireless Infrared, Front / Back
Mouse Control
Mouse Control Receiver (USB) w/ Drag and Drop
Ratings
Fan Noise (Quiet/Normal)
35/29 bB
Power Consumption (Normal/Quiet/Stand-By)
295W / 240W / 9W
Power Voltage
AC 100 to 240V, 50/60Hz
Temperature Operating
41° to 95°F (5° to 35°C)
Temperature Storage
-14° to 104°F (5° to 60°C), 20%RH ~ 80%RH
Dimension (WxHxD)
12.2 x 10.4 x 4.3 in.
Weight
7.3 lbs
Warranty
3 years parts and labor; 120 days lamp
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7365 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
