Web Content Viewer
Actions
LV-7370
Support LV Projectors
Features
The interface is also compliant with HDCP (High-bandwidth Digital Content Protection), ensuring a digital connection between HDCP compliant devices, such as many of today's cable boxes, DVD and Blu-Ray players. The high quality of the DVI-I connection makes the new LV-7370 projector ideal for high definition TV, and is compatible with 1080i and 720p video signals.
In addition, a "Detail Settings" menu allows you to further customize the projection mode. Select any image mode and make desired adjustments, such as for brightness, contrast, and sharpness. The size of your projections can also be changed to match the type of image desired, by making adjustments to the various aspect ratio settings.
Newly-Designed Lens Cover
The newly-designed lens cover protects the entire area around the lens, protecting the lens from dust that can penetrate into gaps of the zoom lever and focus ring. Easy Access Lamp
An opening for replacing the lamp has been installed on the top of the projector. Even if the projector is installed on the ceiling, the LV-7370's lamp can be replaced without having to move the projector. In addition, a replacement counter will display a message indicating the time when lamps and filters need replacing.
Weighing only 7.3 lbs. (3.3 kg) and measuring only 12.5"w x 13.2"d x 4.4"h (317mm x 336mm x 111mm), the LV-7370 is both lightweight and versatile, making it a preferred choice for those on the go. The LV-7370 can also operate as a front or rear screen projector, and can be mounted on the ceiling. Boasting Quick Start and Quick Cooling, the LV-7370 will start up in about eight seconds and cool down within only 30 seconds. No matter where you decide to use your projector, the LV-7370 will operate at a low 35dB in Normal Mode and 29dB in Quiet Mode. The new LV-7370 has a variety of additional features that make setting up and operating the projector simple and straight-forward:Automatic Keystone Adjustment
The LV-7370 gives you further flexibility by adapting to the environment with the automatic keystone adjustment. Simply place your projector on a flat surface, and keystone will correct automatically- with no buttons to push, making setup a breeze! Built-in sensors detect the tilt of the projector and automatically correct for keystone distortion - up to +/- 30 degrees vertically. Of course, you can still adjust keystone correction manually. New User-Friendly Control Panel
During your presentation, you will be able to stay focused thanks to the LV-7370's new user-friendly control panel. Easily control the volume, make menu selections and switch between four different input sources with the touch of a button. With buttons resembling those of simple-to-understand printers and copy machines, the projector's control panel operations are a cinch. If you prefer, you also have the option to control the projector using the wireless IR remote control. New Tab-Style Menu
The LV-7370's intuitive new tab-style on-screen menu makes it easier than ever to navigate through projector settings. Simple tabs of white text on a black background allow clear visibility to select the appropriate settings at a glance. All menu options are available in 21 different languages. Closed Captioning
Unlike many projectors, the LV-7370 is now able to display closed captioning information. This new feature will clearly benefit those in your audience with hearing impairments, making it easier for them to understand difficult dialog. User Security
The LV-7370 is equipped with a Key Lock function, used to disable the keys on the projector's control panel, making the projector operable only from the remote control. This feature is helpful in preventing interruptions due to someone accidentally touching the control panel. In addition, the projector's built-in password protection ensures that only authorized users are able to start and operate the projector. At startup, a display will appear and prompt the user to enter a password set in advance by the projector's owner. Users cannot get past this screen until the password is correctly entered.
LV-7370 Projector
LV-7370 Projector LV-7370 Projector Remote Control (w/ 2 AAA batteries) VGA to VGA Computer Cable DVI to VGA Adapter Power Cable Soft Carrying Case Lens Cap Warranty Card
Specifications
Projector Specifications
Imaging Device
Transmissive LCD Panels x 3
Aspect Ratio
0.63, 4:3
Native Resolution
XGA (1024 x 768)
Brightness
3000 Lumens
Uniformity
85%
Contrast Ratio
500:1
Digital Keystone (Vertical)
± 30 degrees (Auto/Manual)
Digital Keystone (Horizontal)
N/A
Optics
Projection Lens
F1.7 - 2.0, f= 19.8 - 23.7mm
Lens Shift
8.4 : 1.6
Zoom
1.2x Manual
Focus
Manual
Screen Size
21 - 300 inches
Throw Distance
2.62 - 37.0 ft. (0.8 - 11.3 m)
Throw Ratio
1.53 - 1.84 : 1
Image Adjustments
Image Mode
Standard / Presentation / Cinema / Video / sRGB
Color Adjust
Brightness / Contrast / Sharpness / Gamma
Wall Correction
Whiteboard / Greenboard / Greenboard (gray) / Light Yellow / Light Green / Light Blue / Sky Blue / Light Rose / Pink
Mounting
Ceiling / Rear / Ceiling and Rear
Tilt Angle
Adjustable foot up to 10 degrees
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V:50 ~ 120 Hz, Dot clock: 108 MHz
Analog PC Input
UXGA / SXGA+ / SXGA / WXGA / XGA / SVGA / VGA
Digital PC Input
SXGA+ / SXGA / WXGA / XGA / SVGA / VGA /MAC, 1080i / 720p / 576p / 480p
Video/S-Video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N / PAL-60
Component Input
1080i / 720p / 576p / 576i / 480p / 480i
Terminals
(Input) DVI-I 29pin
Digital PC input (HDCP Compliant) / Analog (RGB) PC input
(Input) D-Sub 15pin
Analog RGB / Component input
(Input) RCA x1
Composite Video input
(Input) Mini DIN 4pin
S-Video Input
(Input) RJ-45
Network Input x1
(Input) Stereo Mini Jack
Stereo audio input x2
(Output) D-Sub 15pin
Analog RGB output
(Output) Stereo Mini Jack
Stereo audio output x1
Built-in Speaker
7W (Mono)
Control Terminal
RS-232C
Lamp
Lamp Type
230W - NSHA
Lamp Life
4000 / 3000 Hours
Remote Control
Sensor
Front
Mouse Control
N/A
Ratings
Fan Noise (Quiet/Normal)
35 / 29 dB
Power Consumption (Normal/Quiet/Stand-By)
295W / 240W / TBD
Power Voltage
AC 100 ~ 240V, 50/60Hz
Temperature Operating
41° to 104° F (5° to 40° C), 20 ~ 80% RH
Temperature Storage
14° to 122° F (-10° to 50° C), 20 ~ 80% RH
Dimension (WxHxD)
12.48 x 4.37 x 13.23 (317 x 111 x 336 mm)
Weight
7.28 lbs. (3.3 kg)
Warranty
3 years parts and labor, 120 day lamp
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7370 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
