Web Content Viewer
Actions
LV-7565
Support LV Projectors
Features
When it's brightness you're looking for, look no further than the LV-7565. Perfect for theatres and big boardrooms, Canon's most powerful portable XGA projector is one of the brightest projectors you'll find anywhere. In True Color Mode, it packs a stunning 4400 ANSI lumens. Better yet, when you need even more brilliance, the LV-7565's Brighter Mode gives you a remarkable 5100 ANSI lumens. With power like this, buying the LV-7565 could be your brightest idea yet!
Big and bright is nothing without the sharpness and clarity of the LV-7565. The projector's Native XGA resolution (1024 x 768) means impressive video and text images. The LV-7565 even supports SXGA (1280 x 1024) through advanced, high-quality compression, giving you brilliance that matches the brightness. The result is the image quality you've come to expect from Canon.
Don't let anything distract your audience. Despite its power, the LV-7565 is a super quiet performer. On top of that, Silent Mode reduces fan noise to an ultra-quiet 35dB - perfect for smaller rooms and situations that require even less noise.
Combine Canon's brightest projector with a wide array of lenses, and you have a combination that will work in every situation imaginable. Of course, your LV-7565 comes with a sharp, versatile Genuine Canon Optics, 1.3X Optical Zoom. With a projection distance of 1.4 to 14.7 meters, the lens gives you a diagonal screen as compact as 31" and as big as 400". But the LV-7565 can also be paired with optional lenses: an Ultra Wide Angle, a Wide Angle Zoom, a Long Focus Zoom, or an Ultra Long Focus Zoom. The Wide Angle lenses give you big screen performance even with short projection distances, while the Long Focus lenses let you maintain a manageable screen size over long distances. The zooms allow you to set the perfect screen size. No matter what your needs, there's an LV-7565 and lens combination that's right for you.
Canon means uncompromised image quality. Start with Genuine Canon Optics, add unparalleled image control and our newly developed Image Circuitry, and you get nothing short of perfection. The LV-7565's Color Management tool lets you fine-tune a single color without affecting other colors. Intelligent Image Sharpness lets you sharpen parts of your image while avoiding text (which can be deteriorated by correction). Auto Picture Control automatically optimizes your images, while 3D Noise Reduction gets rid of brightness and color noise, leaving a clear, clean picture. Plus, the LV-7565 boasts an impressive 1000:1 Contrast Ratio. The result? Stunning images that audiences won't forget.
What's the use of all that power, if you can't connect it to the right source? With the LV-7565, you don't have to worry. With the projector's advanced connection options, you can hook it up to your notebook or desktop PC, digital camera, digital video camcorder, VCR, or HDTV. Not only that, the Progressive Scan Converter feature lets you input any interlaced signal - including 1080i HDTV. Plus, when you hook up your LV-7565 with your DVD player, the projector's 2-3 Pulldown minimizes motion artifacts on DVDs that were transferred from film. Whether it's a business presentation, holiday snapshots or videos, or your favorite HDTV show - there's nothing this projector can't handle!
With the LV-7565, there isn't a bad seat in the house. Everyone has a good view of the screen because the Power Lens Shift lets you raise the screen position to the perfect height - quickly and easily - without tilting the projector.
With Digital Keystone Correction, you can quickly eliminate distracting keystone distortion and project a perfectly square image. Tilt the projector 40 degrees up or down, or 10 degrees from side to side, and keystone correction gives you a perfectly square screen effortlessly.
Operate your LV-7565 projector from any computer on your company's network thanks to the optional Network Imager. Through an easy-to-use, graphic user interface, you can turn your projector on and off, switch inputs, or adjust the picture. You even can program it to operate on daily or weekly schedules. Because it's part of your network, you can transfer images to it from any computer on your system. When a lamp needs replacement or you would like a system status update, you receive messages via e-mail from the projector. You can even manage more than one LV-7565 from a single computer. It's a lot of projector - but with the Network Imager, you'll manage.
Canon's most powerful performer is also a portable one. Despite its stunning 5100 ANSI lumens (Brighter Mode), the LV-7565 still weighs in at under 21 lbs. Plus, all that power fits into a body that is a surprising 12.6" x 6.6" x 18.3" (319mm x 168mm x 465.2mm).
Canon's brightest projector is made all the better with a long list of features that enhance its performance and versatility. With RS-232/USB Mouse Control, Wireless IR/Wireless Remote, Stereo Audio Output, 3 Year Parts and Labor Warranty, and a 120 Day Lamp Life Warranty, the LV-7565 is a multimedia projector that shines above the rest.
LV-7565 Projector Kit Contents
LV-7565 Projector Kit Contents LV-7565 Projector Wireless/Wired Remote Control (w/AA Batteries) Wired Remote Cable VGA Computer Cable Mouse Control Cable (USB, Serial) Lens Cap Dust Cover Power Cable Warranty Card User's Manual
Specifications
Projector Specifications
Native Resolution
XGA
Brightness
4400 ANSI Lumens (5100 - Bright Mode)
Uniformity
90%
Contrast Ratio
1000:1
Digital Keystone (Vertical)
+/- 40 degrees vertical, +/- 10 degrees horizontal
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, HDTV, DTV
Lens Shift
10:1
Zoom
1.3 X
Screen Size
31-400
Throw Distance
3.0 - 24.9ft (0.9 - 7.6m) / 100: 8.2 - 12.8ft (2.5 - 3.9m)Throw Ratio: 1.23-1.93:1
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V: 50 ~ 100 Hz, Dot clock: 108 MHz
Analog PC Input
Video/S-Video Input
NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N
Component Input
Component, S-video, Composite, VGA, DVI (supports HDCP), USB
Terminals
(Output) Stereo Mini Jack
RCA x2, Stereo Mini Jack
Built-in Speaker
2 Watt Stereo
Lamp
Network
Yes
Lamp Life
300 Watt NSH
Remote Control
Sensor
Yes
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide, 450W
Weight
20.5lbs
Warranty
3 years parts and labor, 120 day lamp life
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-7565 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
