Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
LV-8215
With spectacular widescreen performance, Canon's LV-8215 projector features native WXGA (1280 x 800) resolution, making it easy to display today's wide format computers and laptops with incredible clarity. This value-driven, portable projector delivers astonishingly bright images and high contrast, and is the perfect solution for users in corporate or educational environments. Featuring network capability, easy-to-use controls, and advanced security features, the LV-8215 was designed with a high-efficiency power supply, and other energy-saving features such as sleep timer, quick startup and a carbon meter. In addition, the projector's improved lamp lighting system can now deliver up to 5000 hours of lamp life. Compact and lightweight, the LV-8215's built-in carrying handle makes for easy transportation to wherever presentations are needed.
Features
These projectors allow you to display widescreen content through high-quality compression. As a result, when widescreen content is displayed, pixels above and below the image are not used. The projectors Digital Image Shift conveniently allows you to move the projected image up or down on the screen, into these unused pixels without any further compression. This ability to "fine tune" the placement of the projected image can be useful when projecting onto a fixed screen, or when stacking projectors for increased brightness. Easy Access Lamp
An opening for replacing the lamp has been installed on the top of the projectors. Even if a projector is installed on the ceiling, the projectors lamp can be replaced without having to move the projector. In addition, a replacement counter will display a message indicating the time when lamps and filters need replacing. New Filter Design
The newly designed air-filter has the ability to significantly improve dust filtration over that of previous models. Textiles in an "accordion" construction have three times the filtering surface for a three-fold increase in dust filtration. A newly improved filter cover design further protects the internal optics of the projector by preventing intrusive dust and dirt from filling the inlet gaps.
LV-8215 Kit
Specifications
Projector Specifications
Imaging Device
Aspect Ratio
Native Resolution
Brightness
Uniformity
Contrast Ratio
Digital Keystone (Vertical)
Digital Keystone (Horizontal)
Optics
Projection Lens
Lens Shift
Zoom
Focus
Screen Size
Throw Distance
Throw Ratio
Image Adjustments
Image Mode
Color Adjust
Wall Correction
Mounting
Tilt Angle
Input Signals
Scanning Frequency
Analog PC Input
Digital PC Input
Video/S-Video Input
Component Input
Terminals
(Input) DVI-I 29pin
(Input) D-Sub 15pin
(Input) RCA x1
(Input) Mini DIN 4pin
(Input) RJ-45
(Input) Stereo Mini Jack
(Output) D-Sub 15pin
(Output) Stereo Mini Jack
Built-in Speaker
Control Terminal
Lamp
Lamp Type
Lamp Life
Remote Control
Sensor
Mouse Control
Ratings
Fan Noise (Quiet/Normal)
Power Consumption (Normal/Quiet/Stand-By)
Power Voltage
Temperature Operating
Temperature Storage
Dimension (WxHxD)
Weight
Warranty
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-8215 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Component Video Cable LV-CA32
The LV-CA32 component cable connects various video components, and transmits analog video signals. 3RCA (female)-Dsub15 connectors.
MSRP: 60.0
DVI Cable (LV-CA29)
The LV-CA29 is 6.6 foot long video cable compatible with 24-pin digital DVI connectors.
MSRP: 69.0
LV-CL15 Ceiling Mount
The LV-CL15 ceiling mount can be secured to either wood ceiling beams or concrete using commercially available bolts. Comes with an anti-fall wire. Consult a building professional before attempting to mount the projector to a ceiling.
MSRP: 549.0
LV-LP31 Replacement Lamp
The LV-LP31 replacement lamp is a 210W NSHA (AC) high-pressured mercury lamp. Lamp life is 4000 hours in Quiet Mode and 3000 hours in Normal mode.
MSRP: 449.0
Projector: CarePAK PLUS (4YR)
CarePAK PLUS offers protection from accidental damage such as drops, spills, power surges, and more, including normal wear and tear, beyond the standard warranty period. It also includes Image Recovery (included with Cameras, Camcorders, and Printers with a memory card slot only), priority repair service, free return shipping, $0 deductible, genuine Canon factory service with only genuine Canon parts, and is transferable if you sell or gift your product. With a CarePAK PLUS, a damaged product will be repaired to good working condition or replaced with an equivalent product.
MSRP: 399.99
Brochures
- ${title}${badge}
