Web Content Viewer
Actions
LV-8225
Support LV Projectors
Features
<br/> Canon brings the best of LCD technology to the LV-8225 projector. It has been designed to deliver the brilliant image quality you expect from a Canon product. LCD technology allows the LV-8225 to be small, light and portable, while still giving it the capability to serve as a great installed unit.<br/> <br/>
<br/> The LV-8225 offers native WXGA widescreen resolution (1280 x 800) delivering clear, sharp video, diagrams and text in a 16:10 aspect ratio, meeting the increasing demand for widescreen displays. Compared to standard XGA resolution projectors, the LV-8225 offers a larger display range capable of projecting data produced on many widescreen laptops. <br/>
<br/> The LV-8225's 2500 lumens gives you the ability to deliver your presentations in a wider variety of venues in a broad range of lighting conditions. This projector will do the job in a classroom, office, boardroom or meeting room, in total darkness or through a range of moderate ambient light levels.&nbsp; Added to the brightness is a truly impressive 3000:1 contrast ratio, thanks to the projectors auto iris, resulting in deep blacks and bright whites.<br/><br/> Another major benefit of the LV-8225's AC lamp system is that it lasts up to 6,000 hours in Quiet Mode.<br/> <br/>
<br/> The 1.2x Optical Zoom lens of the LV-8225 gives you more options in where you can place the projector, based on the needs of your venue. You can also feel secure in selecting the right size screen for your room, knowing that the LV-8225's lens will give you the freedom to do so.<br/><br/> With the wide projection distance coverage of the LV-8225's lens, from 3.93 feet to 36.4 feet (screen sizes 40" to 300"), you will have outstanding flexibility in using this projector in small to moderately large spaces. <br/>
<br/> The high performance of the LV-8225 is matched with impressive durability in use and simplified maintenance. While delivering more, it costs you less in time and maintenance.<br/><br/> Longer Lamp Life<br/><br/> With up to 4,000 hours lamp life in Normal Mode and 6,000 hours in ECO Mode possible, the extended lamp life of the LV-8225 lowers operating costs and reduces maintenance.<br/><br/> &nbsp; Longer Air Filter Life<br/><br/> The high-performance three-layer hybrid filters of the LV-8225 can last up to 5,500 hours in ECO Mode. Consisting of perforated metal, urethane and metal mesh, anti-dust performance is greatly improved and filter life is dramatically lengthened over that of single layer electrostatic filters. It offers significantly reduced maintenance time.<br/><br/> <br/><br/> &nbsp; Easy Access Lamp<br/><br/> To make replacing the lamp quick and easy, the LV-8225's lamp is located on the top of the projector. There is no need to move the projector, even if it is ceiling mounted.<br/><br/> To further aid in maintenance, a replacement counter indicates when lamps and filters require changing. <br/>
<br/> Making the LV-8225 more convenient and easier to use were the goals of the Canon designers. You'll find controls and features made to let you concentrate on making better presentations.<br/><br/> Quick Start and Quick Power Off<br/><br/> Quick Start and Quick Power Off make it more convenient to operate the LV-8225 and help to lengthen lamp life. With the push of a button this projector will quickly spring into action for a spur-of-the-moment presentation, or shut down to be packed for use in another meeting room.<br/><br/> &nbsp; Auto Setup Function<br/><br/> Setting up the LV-8225 is both quick and easy with the Auto Setup function. Through a single button you can set Auto Input, Auto PC and Auto Keystone correction.<br/><br/> With the projector placed on a flat surface, the engagement of Auto Setup will employ sensors which will detect the tilt of the projector in relation to the screen, automatically correcting for any keystone distortion &mdash; up to +/- 20 degrees vertically. Of course, keystone correction can be adjusted manually as well up to +/- 30 degrees.<br/><br/> <br/><br/> &nbsp; Control Panel<br/><br/> Easy to use and clear controls for volume and menu mean that the focus of a presenter will be on the presentation, not on running the projector. The LV-8225 makes it simple to switch between input sources at the touch of a button. Buttons which are familiar in look and feel to those of printers and copy machines fall easily to hand. For added convenience, the wireless IR remote control can be used.<br/><br/> &nbsp; Tab-Style Menu<br/><br/> The clear to read, white text on black background of the LV-8225's on-screen menu is easy to navigate. For added convenience, choose from 21 languages for the menu display.<br/><br/> &nbsp; Multiple Image Modes<br/><br/> Users can select from multiple Image Modes to ensure content is optimally displayed. Presentation &ndash; bright setting that emphasizes contrast overall - most suitable for presentations (PowerPoint, etc).<br/><br/> Standard &ndash; setting that provides standard easy-to-see images.<br/><br/> High Contrast &ndash; provides clear, easy-to-see images in brighter environments.<br/><br/> Cinema &ndash; setting best suited for movie projection (DVD and HDTV) as it excels at providing gradations of dark portions of images.<br/><br/> Blackboard (Greenboard) &ndash; reproduces close hues when projecting on classroom blackboards.<br/><br/> Colorboard &ndash; reproduces close hues when projecting on colored walls. In addition, on the image quality adjustment menu users can manually perform more detailed settings such as contrast, hue and brightness and then save those settings to memory in one of 4 User Image Modes.<br/><br/> &nbsp; Built-in Speaker<br/><br/> Even if you don't have an external sound system to use, the 10W high output speaker of the LV-8225 delivers clear, well produced sound for venues of varying sizes.<br/><br/> <br/>
<br/> The LV-8225 connects to a variety of devices, including laptop and desktop computers, DVD players, and digital cameras and camcorders.<br/><br/> <br/><br/> Network-ready RJ-45 Port<br/><br/> To maximize the usability of the LV-8225, the built-in RJ-45 port enables centralized control and monitoring from a networked PC. This makes it simple for an A/V team to operate ceiling mounted installed projectors from a remote PC, allowing fewer personnel to cover a larger service area.<br/><br/> &nbsp; RS-232 Serial Port<br/><br/> Control the LV-8225 through a third-party system with the built-in RS-232 Serial Port.<br/><br/> &nbsp; Video Input &amp; Output<br/><br/> The LV-8225 has a composite video input and analog RGB output for high-definition video projection and composite video monitoring.<br/><br/> &nbsp; Multiple Audio Inputs &amp; Output<br/><br/> Two audio Mini-Jack stereo inputs and one output are found on the LV-8225 for relaying audio through external speakers. It provides the flexibility needed to play audio from a linked DVD or PC source. <br/>
Quiet Operation
Give your audience the silent treatment with the quietness of the LV-8225. In Normal mode the projector runs at 36dB and that drops to 29dB in Quiet mode, allowing all ears to be on the presentation.
Closed Captioning Closed Captioning
If you are presenting to a hearing impaired audience or in a venue with a high level of ambient noise, the LV-8225 can deliver closed captioning to make any difficult to understand dialogue perfectly clear.
<br/> Canon USA Projector and Lamp Limited Warranty<br/><br/> The LV-8225 projector is backed by Canon USA's Projector and Lamp Limited Warranty, which guarantees that it will be free from defects in workmanship and materials for 3 years from the date of original purchase, and the lamp for 120 days from the date of original purchase.<br/><br/> &nbsp; Projector Protection Program (Triple P)<br/><br/> Add to that Canon USA's Projector Protection Program* ("Triple P"), a FREE service program that provides a loaner projector of equal or greater value in the event that a qualifying unit is in need of repair. Triple P is available on all Canon projector models during the Canon USA Projector and Lamp Limited Warranty.<br/><br/> * Loaner units based on availability. Program subject to change at any time without given notice. Contact the Canon Customer Support Center at 1.800.828.4040 for complete details. <br/>
LV-8225
LV-8225 LV-8225 LCD Projector Lens Cap (with strap) AC Power Cord Remote Control (with AAA batteries) VGA to VGA Connection Cable (Mini D-sub 15-pin/Mini D-sub 15-pin) CD-ROM Quick Start Guide
Specifications
Projector Specifications
Imaging Device
0.59 Active Matrix x 3
Aspect Ratio
16 : 10
Native Resolution
WXGA (1280 x 800)
Brightness
2500 Lumens
Uniformity
85%
Contrast Ratio
3000:1
Digital Keystone (Vertical)
+/- 30 degrees (Manual); +/- 20 degrees (Auto)
Optics
Projection Lens
F2.0 - 2.15, f=18.38 - 22.06mm
Zoom
1.2x Zoom (Manual)
Focus
Manual
Screen Size
40 - 300
Throw Distance
3.93 - 36.4 ft. (1.2 - 11.1m)
Image Adjustments
Image Mode
Presentation, Standard, High Contrast, Cinema, Blackboard (Green), Colorboard, User 1-4
Wall Correction
Yes
Mounting
Ceiling, Rear, Rear-Ceiling, Upwards, Downwards
Tilt Angle
Adjusting foot up to 10 degrees
Input Signals
Scanning Frequency
H:15~100 kHz, V:50~100 Hz
Analog PC Input
WUXGA / UXGA / SXGA+ / SXGA / WXGA / XGA / SVGA / VGA / MAC
Video/S-Video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N / PAL-60
Component Input
1080i / 1035i / 720p / 575p / 575i / 480p / 480i
Terminals
(Input) D-Sub 15pin
Analog RGB / Component video / S-video input
(Input) RCA x1
Composite Video input
(Input) RJ-45
Yes
(Input) Stereo Mini Jack
Stereo Audio input x 2
(Output) D-Sub 15pin
Analog RGB output
(Output) Stereo Mini Jack
Stereo Audio output
Built-in Speaker
10W (Mono)
Control Terminal
RS-232C
Lamp
Lamp Type
215W UHP
Lamp Life
4000 / 6000 Hours (Normal / Quiet)
Remote Control
Sensor
Wireless Infrared, Front
Ratings
Fan Noise (Quiet/Normal)
29 / 36dB
Power Consumption (Normal/Quiet/Stand-By)
286W / 6.6W / 0.4W
Power Voltage
AC100 to 240V, 50/60Hz
Temperature Operating
41° to 95° F (5° to 35° C)
Temperature Storage
14° to 140° F (-10° to 60° C), 5%RH ~ 90%RH
Dimension (WxHxD)
13.13 x 3.98 x 9.72 (333 mm x 101 mm x 247 mm)
Weight
6.6 lbs
Warranty
3 Year Parts and Labor / 120 Day on Lamp
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-8225 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
