Web Content Viewer
Actions
LV-8300
Support LV Projectors
Features
The interface is also compliant with HDCP (High-bandwidth Digital Content Protection), ensuring a digital connection between HDCP compliant devices, such as many of today's cable boxes, DVD and Blu-Ray players. The high quality of the DVI-I connection makes the new LV-8300 projector ideal for high definition TV, and is compatible with 1080i and 720p video signals.
In addition, a "Detail Settings" menu allows you to further customize the projection mode. Select any image mode and make desired adjustments, such as for brightness, contrast, and sharpness. The size of your projections can also be changed to match the type of image desired, by making adjustments to the various aspect ratio settings.
Newly-Designed Lens Cover
The newly-designed lens cover protects the entire area around the lens, protecting the lens from dust that can penetrate into gaps of the zoom lever and focus ring. Easy Access Lamp
An opening for replacing the lamp has been installed on the top of the projector. Even if the projector is installed on the ceiling, the LV-8300's lamp can be replaced without having to move the projector. In addition, a replacement counter will display a message indicating the time when lamps and filters need replacing.
LV-8300 Projector
LV-8300 Projector LV-8300 Projector Remote Control (w/ 2 AAA batteries) VGA to VGA Computer Cable DVI to VGA Adapter Power Cable Soft Carrying Case Lens Cap Warranty Card
Specifications
Projector Specifications
Imaging Device
Transmissive LCD Panels x 3
Aspect Ratio
0.59, 16:10
Native Resolution
WXGA (1280 x 800)
Brightness
3000 Lumens
Uniformity
85%
Contrast Ratio
500:1
Digital Keystone (Vertical)
± 30 degrees (Auto/Manual)
Digital Keystone (Horizontal)
N/A
Optics
Projection Lens
F1.7 - 1.9, f= 17.7 - 21.2mm
Lens Shift
8.5 : 1.5
Zoom
1.2x Manual
Focus
Manual
Screen Size
21 - 300 inches
Throw Distance
2.3 - 35.1ft. (0.7 - 10.7m)
Throw Ratio
1.44 - 1.74 : 1
Image Adjustments
Image Mode
Standard / Presentation / Cinema / Video / sRGB
Color Adjust
Brightness / Contrast / Sharpness / Gamma
Wall Correction
Whiteboard / Greenboard / Greenboard (gray) / Light Yellow / Light Green / Light Blue / Sky Blue / Light Rose / Pink
Mounting
Ceiling / Rear / Ceiling and Rear
Tilt Angle
Adjustable foot up to 10 degrees
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V:50 ~ 120 Hz, Dot clock: 108 MHz
Analog PC Input
UXGA / SXGA+ / SXGA / WXGA / XGA / SVGA / VGA
Digital PC Input
SXGA+ / SXGA / WXGA / XGA / SVGA / VGA /MAC, 1080i / 720p / 576p / 480p
Video/S-Video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N / PAL-60
Component Input
1080i / 720p / 576p / 576i / 480p / 480i
Terminals
(Input) DVI-I 29pin
Digital PC input (HDCP Compliant) / Analog (RGB) PC input
(Input) D-Sub 15pin
Analog RGB / Component input
(Input) RCA x1
Composite Video input
(Input) Mini DIN 4pin
S-Video Input
(Input) RJ-45
Network input x1
(Input) Stereo Mini Jack
Stereo audio input x2
(Output) D-Sub 15pin
Analog RGB output
(Output) Stereo Mini Jack
Stereo audio output x1
Built-in Speaker
7W (Mono)
Control Terminal
RS-232C
Lamp
Lamp Type
230W - NSHA
Lamp Life
4000 / 3000 Hours
Remote Control
Sensor
Front
Mouse Control
N/A
Ratings
Fan Noise (Quiet/Normal)
35/29 dB
Power Consumption (Normal/Quiet/Stand-By)
325W / 240W / 11W
Power Voltage
AC 100 ~ 240V, 50/60Hz
Temperature Operating
41° to 104° F (5° to 40° C), 20 ~ 80% RH
Temperature Storage
14° to 122° F (-10° to 50° C), 20 ~ 80% RH
Dimension (WxHxD)
12.48 x 4.37 x 13.23 (317 x 111 x 336mm)
Weight
7.28 lbs. (3.3 kg)
Warranty
3 years parts and labor, 120 day lamp
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-8300 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
