Web Content Viewer
Actions
LV-S3
Support LV Projectors
Features
<br/> Take the LV-S3 wherever you need a sharp, brilliant presentation -- to your office or on the road. Then, take it home with you and enjoy your favorite DVD or latest digital snapshots. At 4.9 lbs., the LV-S3 is the lightest Canon projector ever. Need a projector that matches your work- and life-style? The LV-S3 is ready to go anywhere.<br/> <br/>
<br/> <br/> Canon's most portable projector is also a brilliant performer. At 1250 ANSI lumens, the LV-S3 packs enough power for a bright presentation no matter what the lighting conditions. In your home or in the office, this projector shines!
<br/> <br/> <br/> Because you can take it anywhere, the LV-S3 comes with a lens that matches it to any room. The Genuine Canon Optics, Ultra-Wide, 1.2X Zoom Lens projects an impressive 100" screen from a distance of only 10.6'. It's the perfect lens for bringing big screen magic to your office or living room. Not only that, the zoom lens lets you adjust the image size to fit the size of your room and your audience. Canon understands that there's more to portability than a lightweight projector.
You and your audience won't be distracted by fan noise -- even in the smallest room. That's because the LV-S3 operates at a super quiet 32dB. Your audience will hear every word of your presentation, and you'll hear every line of dialogue in your favorite movie.
&lt;p>&lt;img height="150" alt="" src="/CUSA/assets/app/images/projectors/connectivity.jpg" width="266" border="0">&lt;br> &lt;br> Simplify your life. Use your LV-S3 to project anything, whether it's an HDTV signal, or the input from your VCR, digital camcorder, digital camera, or computer. Whatever you've got, the LV-S3 can handle it.&lt;/p>
<br/> <br/> You won't believe such a brilliant image comes from such a compact projector. The name Canon means unsurpassed image quality, and the LV-S3's Genuine Canon Optics 1.2X Zoom Lens is no exception. There's also Progressive Scan Circuitry that converts standard&#160;A480i/575i signal (conventional broadcast TV) to progressive scan for the image quality you demand. And, Native SVGA Resolution (800 X 600) gives you sharp, clear video and text images. Not only that, the LV-S3 supports XGA Resolution (1028 X 768) through high-quality compression. With all of this going for it, it's no wonder the LV-S3 is raising eyebrows everywhere.
No need to worry that the impressive performance of your LV-S3 won't last. The projector comes with a 3-year parts and labor warranty, as well as a 120-day lamp life warranty. Your only worry will be what to show next!
Stay in control<br/> Don't distract your audience -- or yourself -- by fumbling with your computer or projector controls. Use the LV-S3's easy-to-use Presentation Remote Control Unit as a wireless mouse to control your computer. You can also use it to control select features on the projector itself.<br/> <br/> From the office, to your home...and beyond<br/> You can even take the LV-S3 with you on business trips abroad. Depending on the country you're in, you simply set the color system for the best image possible, including: PAL, SECAM, NTSC, NTSC4.43, PAL-M, and PAL-N. Now that's portability!<br/> <br/> Let the LV-S3 cover all the angles<br/> With the LV-S3's Keystone Correction, keep your presentations looking their best. You can project a square image even if you're projecting at an angle of +/- 20 degrees, by using the projectors easy-to-use controls.<br/> <br/> Project your corporate logo<br/> Make a good first impression by programming your LV-S3 to project your corporate logo when you first turn on your projector.
LV-S3 Projector Kit
LV-S3 Projector Kit LV-S3 Projector Wireless Remote Control (AAA alkaline batteries included) Presentation Kit (Remote control with USB Remote Receiver) VGA Computer Cable Lens Cap Soft Carrying Case Power Cord
Specifications
Projector Specifications
Native Resolution
SVGA
Brightness
1,250 LUMENS
Uniformity
85%
Contrast Ratio
350:1
Digital Keystone (Vertical)
(+/-) 20 deg H
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, HDTV, DTV
Lens Shift
19:1
Zoom
1.2x
Screen Size
34-200
Throw Distance
1.77 to 2.33:1
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V: 50 ~ 100 Hz, Dot clock: 108 MHz
Analog PC Input
Video/S-Video Input
NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N
Component Input
Component, S-video, Composite, VGA, Audio, USB
Terminals
(Output) Stereo Mini Jack
Yes (variable)
Built-in Speaker
0.8 Watt Monaural
Lamp
Network
Yes
Lamp Life
160 Watt UHP
Remote Control
Sensor
Yes
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide
Weight
4.9lbs
Warranty
3 years parts and labor, 120 day lamp life.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-S3 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
