Web Content Viewer
Actions
LV-X1
Support LV Projectors
Features
Canon developed lens for optics with that extra edge of sharpness:<br/> The Canon quality precision optics provide awesome sharpness-even with the newer information-rich HDTV and signals from other digital media.
Color accuracy with enough firepower to get your message across:<br/> To please the most discriminating audiences, the short-arc lamp puts out 1100 ANSI-lumens of accurate color that gives companies trademarks their due, and artists their language.
The price and weight of this compact and lightweight projector means it moves around easy, is easy to set up and use, too. Weighing about six pounds, the LV-X1 comes with all sorts of easy-to-use smart features and details&#8211; because you need to concentrate on bringing your message to your audience &#8211; not on your abilities rigging equipment.<br/> This microportable connects and autodetects!<br/> It auto tracks and adjusts the image position.<br/> Digital keystone correction.<br/> It can zoom and even enlarge portions of the screen.
The projector circuits know how to handle a wide variety of video and computer inputs right out of the box. A well thought-out graphic interface presents custom controls for you to customize, too.
This fan is quiet and unobtrusive, and not only that, it changes speed on the fly to reduce operating noise to a minimum.
Sales, graphics and marketing people will love the color quality and resolution of this projectors.
With image uniformity of 85%, your audiences won&#8217;t be tired of looking at the screen.
Everyone will love that the LV-X1 is MAC and PC friendly. And you can use the best and most powerful source material in your presentations because the LV-X1 knows how to handle and display formats of both video and digital files.<br/> VGA (640x480)<br/> SVGA (800x600)<br/> XGA (1024x768) -- Native<br/> SXGA (1280x1024)<br/> DVD & VCR<br/> HDTV & DTV
Use this control by feel and maintain contact with your audience. The handy and easy to use remote control has logically placed well-shaped rockers and buttons for volume, zoom and more. It lets you concentrate and stay in contact with your viewers while you operate and adjust your presentation.
Specifications
Projector Specifications
Imaging Device
0.7 p-Si TFT active-matrix with Micro Lens Array
Native Resolution
SVGA
Brightness
1,500 ANSI lumens
Uniformity
80%
Contrast Ratio
300:1
Digital Keystone (Vertical)
(+/-) 20 degrees
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, HDTV,DTV
Lens Shift
19:1
Zoom
1.2 x
Screen Size
34-200
Throw Distance
3.6 - 28.9ft (1.1 - 8.8m) / 100: 9.5 - 15.1ft (2.9 - 4.6m)Throw Ratio: 1.44-2.25:1
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V: 50 ~ 100 Hz, Dot clock: 108 MHz
Analog PC Input
Video/S-Video Input
NTSC,PAL,SECAM,NTSC,4.43, PAL-M, PAL-N
Component Input
S-video, Composite, VGA, Audio, Component
Terminals
(Input) Stereo Mini Jack
RCA x2
(Output) Stereo Mini Jack
1 RGB (D-Sub 15 Pin), 1 Stereo Mini Audio
Built-in Speaker
1 Watt Monaural
Lamp
Network
Yes
Lamp Life
150 watt UHP
Remote Control
Sensor
Yes
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide
Temperature Operating
41° to 95°F (5° to 35°C)20% to 80% humidity (non-condensing)
Temperature Storage
14° to 122°F (-10° to 50°C)20% to 80% humidity (non-condensing)
Weight
5.95lbs
Warranty
3-years parts and labor, 120 day lamp life
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-X1 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
