Web Content Viewer
Actions
LV-X6
Support LV Projectors
Features
The LV-X6 features a 1500 ANSI lumens lamp with native XGA resolution projection. You'll enjoy brilliant images in a variety of environments, including those with high levels of ambient light. Whether presenting to small or large audiences, the LV-X6 delivers all the presentation power you'll need.<br/> <br/>
A perfect match for your laptop computer, the LV-X6 offers native XGA (1024x768) resolution for your images. In addition, the LV-X6 supports both UXGA and SXGA resolution through high-quality compression.<br/> <br/>
Superior clarity and color are the hallmarks of Genuine Canon projection lenses. And now with a 1.6x wide-angle zoom lens, the new LV-X6 lets you project an impressive 80-inch image from as close as 92 inches (2.3 m/7.7 ft.), while less than 3 meters are needed for a 100-inch projection.<br/> <br/> The LV-X6 also features five automatic image modes, which can be further customized through a &quot;Detail Settings&quot; menu:<br/> Presentation -- Ideal for presentations using PowerPoint<br/> Video -- For projecting standard video, such as TV broadcasts<br/> Cinema -- For projecting film-based video, such as movies (DVD or HDTV)<br/> Standard -- When maximum color accuracy is desired for viewing graphics<br/> sRGB -- For reproducing color adapted to the sRGB color space; suitable for sRGB content<br/> Precise control over color appearance can also be achieved through the LV-X6's Color Management System. Instead of having just one master control, the projector offers individual adjustment for color levels and color balance (not available for RGB input), as well as brightness, contrast, and sharpness.<br/> <br/> The LV-X6 even features enhanced Wall Color Correction, allowing you to project onto non-white surfaces, such as a chalkboard or wall. Select from several wall color options, including the new Greenboard (Gray) mode, for quick adaptive color correction so that images are closer in appearance to how they would look when projected on a white background.<br/> <br/>
Both lightweight and versatile, the LV-X6 weighs in at approximately 6.4lbs (2.9kg) and measures a mere 12.2&quot;w x 10.4&quot;d x 4.3&quot;h (310mm x 265mm x 109mm).<br/> <br/> The LV-X6 gives you further flexibility with Manual Keystone Adjustment controls, which allow you to correct vertical distortion of your projected image through the projector's on-screen menu. Your adjustments can then be saved for quick recall.<br/> <br/> The LV-X6 can operate as a front or rear-screen projector and can be mounted on the ceiling.<br/> <br/> For enhanced Wall Color Correction, the Greenboard mode lets you project onto non-white surfaces, such as a chalkboard. Select from several wall color options, including the new Greenboard (Gray) mode, for quick adaptive color correction so that images are closer in appearance to how they would look when projected on a white background.<br/> <br/> To ensure your audience hears every word of your presentation, the LV-X6 runs at a mere 32dB in normal mode and 25dB in quiet mode. It also boasts a rapid start-up time of a mere 8 seconds, cools down within 30 seconds and offers an Automatic Power Off Timer with eight selectable presets.<br/> <br/> During your presentation, you'll be able to stay focused as well thanks to the LV-X6's Wireless IR Remote Control, redesigned on-screen menus and user-friendly control panel.<br/> <br/> The newly designed wireless remote gives you control over a range of functions, including:<br/> Auto PC Adjustment for optimizing the image quality of an RGB source<br/> Source Select for choosing between 4 different input sources<br/> Mouse Control for full control of a connected computer (with the addition of a remote mouse receiver in your PC's USB port)<br/> Buttons are grouped and arranged in a smooth flow from top to bottom in order of each main function, making projector and presentation control simpler than ever.<br/> <br/> The user-friendly control panel, meanwhile, lets you control volume, make menu selections and easily switch between 4 different input sources with the touch of a button. The LV-X6 also gives you a new, easy to use on-screen menu for flexible projector control.<br/> <br/> Lastly, your LV-X6 makes your life even easier with:<br/> Built-in audio speaker<br/> 3-year parts and labor limited warranty<br/> 120-day Lamp Life warranty<br/> Password protection and control panel key lock<br/> Attachable carrying handle<br/> <br/>
<br/> <br/> Always ready for diverse input sources, the new LV projectors offer you effortless connection to laptops and desktop computers, DVD players, digital cameras and camcorders, VCRs, and other devices. In particular, thanks to the high-quality component video connection, the new LV projectors are ideal for DVD and HDTV (1080i, 720p, 575p, 575i, 480p, and 480i).<br/> <br/> For projecting video, the LV-X6 eliminates distracting, noise-like interference (caused, for example, by pinstriped clothing or intricate line patterns). Subtle flickering of subtitles is also prevented.<br/> <br/> The projector's Analog VGA Out terminal further allows users to connect the projector to an external monitor-a practical feature in settings where the projector is hooked up to a desktop PC, not a laptop.<br/> <br/>
Specifications
Projector Specifications
Imaging Device
0.7 p-Si TFT active-matrix with Micro Lens Array
Native Resolution
XGA
Brightness
1500 ANSI Lumens
Uniformity
85%
Contrast Ratio
500:1
Digital Keystone (Vertical)
+/- 30 degrees (Manual)
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, HDTV,DTV
Lens Shift
8.6:1.4, Fixed
Zoom
1.6x manual
Screen Size
25 - 300
Throw Distance
3.6 - 28.9ft (1.1 - 8.8m) / 100: 9.5 - 15.1ft (2.9 - 4.6m)Throw Ratio: 1.44-2.25:1
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V: 50 ~ 100 Hz, Dot clock: 108 MHz
Analog PC Input
Video/S-Video Input
NTSC, NTSC4.43, PAL, PAL-60, PAL-N, PAL-M, SECAMHDTV: 1080i, 1080i/50Hz, 720p, 576p, 480p, 480i/60Hz
Component Input
S-video, Composite, VGA, Audio, Component
Terminals
(Input) Stereo Mini Jack
1 Stereo Mini Audio, 1 Service Port (DIN 8 Pin)
(Output) Stereo Mini Jack
1 RGB (D-Sub 15 Pin), 1 Stereo Mini Audio
Built-in Speaker
36 dB
Lamp
Network
RS232, IR
Lamp Life
150W NSH
Remote Control
Sensor
Yes
Ratings
Power Voltage
100-240V, 50-60 Hz Worldwide
Temperature Operating
41° to 95°F (5° to 35°C)20% to 80% humidity (non-condensing)
Temperature Storage
14° to 122°F (-10° to 50°C)20% to 80% humidity (non-condensing)
Weight
6.4 lbs (2.9kg)
Warranty
3 Years Parts & Labor, 120 Day Lamp Life
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-X6 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
