Web Content Viewer
Actions
LV-X7
Support LV Projectors
Features
With its 1500 ANSI lumens lamp and native XGA resolution, brilliant images can be projected in a wide variety of environments. Even in a classroom or office with high levels of ambient light, your audience will be sure to see every brilliant detail of your presentation. And you'll be able to use that brightness longer, thanks to a Long Life Lamp which delivers up to 4000 hours of use in Quiet Mode.<br/> <br/>
The LV-X7 offers native XGA (1024x768) resolution for your images, making it a perfect match for your laptop computer. In addition, the LV-X7 supports both UXGA and SXGA resolution through high-quality compression.<br/> <br/>
<br/> <br/> <br/> <br/> Superior clarity and color are the hallmarks of Genuine Canon projection lenses. And with a 1.6x Zoom, the new LV-X7 is perfect for small rooms, allowing you to project bigger images from shorter distances. The LV-X7's short throw distance means you can project that crisp image on a 100" screen that's as close as 9'6" away from the projector.<br/> <br/> The LV-X7 also features five automatic image modes:<br/> Presentation &#8212; Ideal for presentations using PowerPoint<br/> Video &#8212; For projecting standard video, such as TV broadcasts<br/> Cinema &#8212; For projecting film-based video, such as movies (DVD or HDTV)<br/> Standard &#8212; When maximum color accuracy is desired for viewing graphics<br/> sRGB &#8212; For reproducing color adapted to the sRGB color space; suitable for sRGB content<br/> The LV-X7 features enhanced Wall Color Correction, allowing you to project onto non-white surfaces such as a chalkboard or wall. Select from several wall color options including greenboard, greenboard gray, light yellow, light green, light blue, sky blue, light rose and pink for quick adaptive color correction. The image you project will be closer in appearance to how it would look when projected on a white background.<br/> <br/> Projected on Yellow Wall<br/> <br/> Projected on a Green Blackboard<br/> <br/> OFF<br/> <br/> <br/> Light Yellow Mode<br/> <br/> <br/> OFF<br/> <br/> <br/> Greenboard Mode<br/>
Weighing in at only 6.4 lbs. (2.9 kg) and measuring only 12.2"w x 10.4"d x 4.3"h (310mm x 265mm x 109mm), the LV-X7 is both lightweight and versatile, making it a preferred choice for those on the go.<br/> <br/> Once at your destination, the LV-X7 gives you further flexibility by adapting to the environment. Adjust and correct for keystone distortion &#8212; up to +/- 30 degrees vertically with simple controls.<br/> <br/> <br/> <br/> The LV-X7 can operate as a front- or rear-screen projector and can be mounted on the ceiling.<br/> <br/> For enhanced Wall Color Correction, the greenboard mode lets you project onto non-white surfaces, such as a chalkboard. Select from eight different wall color options for quick adaptive color correction, making the projected images closer in appearance to how they would look when projected on a white background.<br/> <br/> Naturally, your LV-X7 does all this while still running at a low 32dB in Normal Mode and 25dB in Quiet Mode. It also boasts Quick Start and Quick Cooling, starting up in about eight seconds and cooling down within 30 seconds. The Automatic Power Off Timer gives you eight selectable presets with timing between 30 minutes and 16 hours.<br/> <br/> During your presentation, you'll also be able to stay focused thanks to the LV-X7's Wireless IR Remote Control, intuitive on-screen menus and user-friendly control panel.<br/> <br/> The newly-designed wireless remote gives you control over a range of functions, including:<br/> Auto PC Adjustment for optimizing the image quality of an RGB source<br/> Source Select for choosing between four different input sources<br/> Buttons are grouped and arranged in a smooth flow from top to bottom in order of each main function, making projector and presentation control more simple than ever.<br/> <br/> The user-friendly control panel, meanwhile, lets you control volume, make menu selections and easily switch between four different input sources with the touch of a button and displays settings on-screen with clearly labeled adjustments.<br/> <br/> Lastly, your LV-X7 makes your life even easier with:<br/> A built-in audio speaker<br/> Three-year parts and labor limited warranty<br/> 120-day Lamp Life warranty<br/> Password protection and control panel key lock<br/> Attachable carrying handle<br/> <br/> <br/> <br/> <br/> <br/>
Always ready for diverse input sources, the new LV projectors offer you effortless connection to laptops and desktop computers, DVD players, digital cameras and camcorders, VCRs, and other devices. In particular, thanks to the high-quality component video connection, the new LV projectors are ideal for DVD and HDTV (1080i, 720p, 575p, 575i, 480p, and 480i).<br/> <br/> <br/> <br/> For projecting video, the LV-X7 eliminates distracting, noise-like interference (caused, for example, by pinstriped clothing or intricate line patterns). Subtle flickering of subtitles is also prevented.<br/> <br/> The projector's Analog VGA Out terminal further allows users to connect the projector to an external monitor &#8212; a practical feature in settings where the projector is hooked up to a desktop PC, not a laptop.<br/> <br/>
LV-X7 Kit Contents
LV-X7 Kit Contents LV-X7 Projector Wireless Remote Control VGA Computer Cable Lens Cap Soft Carrying Case Power Cable Warranty Card CD-ROM User's Manual
Specifications
Projector Specifications
Native Resolution
XGA
Brightness
1500 Lumens
Uniformity
85%
Contrast Ratio
600:1
Digital Keystone (Vertical)
+/- 30 degrees (Manual)
Optics
Projection Lens
VGA, SVGA, XGA, SXGA, HDTV,DTV
Lens Shift
8:6:1.4, Fixed
Zoom
1.6x manual
Screen Size
25 - 300
Throw Distance
3.7 - 24.1ft (1.1 - 8.8m) / 100: 9.5 - 15.1ft (2.9 - 4.6m)
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V: 50 ~ 120 Hz, Dot clock: 108 MHz
Analog PC Input
Video/S-Video Input
NTSC/PAL/SECAM/NTSC4.43/PAL-M/PAL-N/PAL-60
Component Input
Mini D-sub 15pin, RCA x1, RCA x2, Mini DIN 4pin, Stereo mini jack VGA Computer Support (PC/MAC) UXGA/SXGA/XGA/SVGA/VGA
Terminals
(Output) Stereo Mini Jack
RCA x2, Stereo mini jack
Built-in Speaker
1 Watt Monaural
Lamp
Network
Yes
Lamp Life
200 watt UHP
Remote Control
Sensor
Yes ( includes laser pointer)
Ratings
Power Consumption (Normal/Quiet/Stand-By)
(Normal/Quiet/Stand-by): 205W / 170W / 9W
Power Voltage
100-240V, 50-60 Hz Worldwide
Dimension (WxHxD)
13.05 x 3.52 x 9.12 in.
Weight
8.8 lbs
Warranty
3 years Parts & Labor; 120 day Lamp Life
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LV-X7 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
