Web Content Viewer
Actions
LE-5W BK
Support REALiS Projectors
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
Features
Let your audiences see the whole picture with the LE-5W Multimedia Projector, displayed in stunning native WXGA widescreen high resolution (1280 x 800) that delivers clear video, graphics and text in the same 16:10 aspect ratio available on widescreen laptops. WXGA provides more screen space and clarity than traditional XGA resolution (1024 x 768 resolution; 4:3 aspect ratio) so that users have more opportunities and flexibility to either engage audiences out of the office or enjoy a home entertainment viewing experience.
The LE-5W Multimedia Projector offers 500 lumens paired with a generous 3000:1 contrast ratio that enables users to display bright, crisp, high quality images to their audiences and grants the flexibility required of today's modern world to present with confidence within a wide variety of environments and lighting conditions. The projector's 3 LED lamps project incredibly vibrant and realistic colors.
The LE-5W Multimedia Projector's 3 LED lamps project incredibly vibrant and realistic colors, even supporting sRGB color space for accurate rendition of the most critical colors - helping to ensure that your presentations, photos and videos are rendered in vibrant, pure colors that are both detailed and realistic. It's the perfect projector to bring along for off-site presentations and client visits - even to share photos or movies with friends.
Simulated Images
Both on-the-go professionals and home enthusiasts alike will appreciate the incredibly lightweight, compact and rugged design of the LE-5W Multimedia Projector. The LE-5W weighs just 3.5 lbs (1.6 kg) - less than half the weight of an average laptop computer - making it incredibly easy to transport and carry.
The projector is compact (9.8" x 7.6" x 1.9") and does not have any protrusions, enabling the LE-5W to slide easily into a small briefcase or carrying bag. Portability is further enhanced with its built-in, protective lens cover, as well as its built-in power adapter, removing the need for these space-consuming, heavy peripherals. A special finish gives it a rugged, scratch-resistant and glossy outer surface to better ensure that the LE-5W remains beautiful for a long time.
When delivering critical information to an audience, minimizing distractions is an important key for retention. In Normal Mode, the LE-5W operates at 38dB, and diminishes to only 32dB in Quiet Mode.
The LE-5W Multimedia Projector offers presenters of all experience levels and technical expertise a quick and easy setup, and a host of features and controls make using the projector simple and hassle-free.
The projector's light weight (3.5 lbs / 1.6 kg) and compact dimensions (9.8" x 7.6" x 1.9") make this LE-5W a road warrior's dream come true. Whether a user stores it in a small briefcase or carrying bag, the LE-5W allows for flexible portability and transport without the packing time, the space requirements or the hassle of larger units.
The LE-5W's lightweight portability is complemented by its versatility, no matter where it is set up. With its short throw ratio, it makes a big picture in small places ? users can be confident that no matter the size of the space, the LE-5W projector will do the job. As it is also equipped with a tripod mount, you can confidently and quickly setup the projector in a wide variety of locations with ease.
When a spur of the moment presentation is needed or on those days when a presenter is running behind schedule, the LE-5W is ready to perform within just 4 seconds of turning on the power. The projector's minimalistic 2-button design (power and signal selection), allow a user to focus on presenting instead of on a needlessly complicated setup. In auto mode, the projector's sensors will identify vertical tilt in relation to the screen and simply right any resulting keystone distortion automatically up to +/- 40 degrees. Keystone correction may also be conveniently adjusted manually up to +/- 40 degrees.
No presentation screen available? No problem! With its 5-color wall projection mode, the LE-5W projector can produce stunningly vivid, beautiful and vibrant presentations, images and videos directly onto a wall by matching its color.
The LE-5W Multimedia Projector is a compact, cost-effective and powerful solution that will meet your projection requirements within a variety of environments and situations.
Projecting in small offices and home entertainment spaces with limited dimensions is made easier with the LE-5W's short throw ratio (1.2:1), making it possible to display presentations, photos and videos onto screen sizes between 20" and 120".
The LE-5W's 5-color wall projection mode further increases user flexibility in situations where a screen is not available for use or in those times when your family would like to enjoy a backyard movie night. The projector also offers 5 distinct projection modes depending on your environment, lighting conditions or content. These modes help to ensure that presentations, images and videos will be displayed with accurate coloring across the entire spectrum.
  • Presentation Mode - Default mode matches colors generally found on the screens of a PC or notebook computer
  • Standard Mode - Designed for optimal projection in rooms with a small amount of ambient light and well suited for presentations where there is minimal light for taking notes
  • Movie Mode - Delivers saturated colors and is perfect for presentations within darkened rooms
  • sRGB Mode - Optimized for colors seen in a calibrated sRGB color space. This mode is best used for graphic, AutoCAD and other computer-calibrated presentations
  • User Mode - Enables customized brightness, contrast, color, tint, temperature and sharpness settings
In presentation spaces and situations where an external sound system is not available, the built-in pair of 2.5W stereo speakers deliver crisp, beautiful sound even at a high volume.
The LE-5W Multimedia Projector offers a wide range of interconnectivity options. A variety of connection ports allows for quick and easy connections to a large number of devices, which means connecting effortlessly to PC computers, laptops, tablets, Blu-ray players and gaming consoles.
HDMI is fully supported, allowing a user to directly project uncompressed vibrant video and color rendering of images and presentations in high-definition onto a large television or similar output devices. Connectivity flexibility is enhanced further with the ability of the LE-5W to be able to connect via D-Sub, Composite (RCA) and VGA Adapter ports.
Whether making a presentation in a home office from a laptop, or watching Blu-ray movies at home, the LE-5W projector can be connected and up in a flash.
The flexibility and versatility that the LE-5W Multimedia Projector demonstrates within a myriad of environments and situations is a marvel that is enhanced by its extensive multimedia capabilities. Additionally, this projector does not require a PC or similar device in order to deliver striking images, stunning presentations or brilliant videos!
When on the road, leave your laptop at the office. You won't need it with the LE-5W. Other than the lightweight and highly portable 3.5 lbs (1.6 kg) LE-5W projector that will slip easily into your small suitcase or carrying bag, all that you will need is a power source. That's it. You won't even require a separate lens cap or a power adapter - it has been integrated into the unit to provide users with maximum flexibility and portability.
There's no need to transport a bulky, space-consuming laptop when you are on the go. PC-less projection is enhanced through the use of USB memory sticks and SD cards with the LE-5W. Additionally, the LE-5W supports a wide assortment of image, video and audio file types. Video compatibility includes: AVI, MKV, TS, DAT, VOB, MPG, MPEG, MOV, MP4. Supported audio files include: OGG, AAC, WAV (WAV supports PCM, and AD-PCM). Image and photo compatibility are found with JPEG and BMP.
Do your presentations require the use of Microsoft Word, Excel or PowerPoint documents or perhaps Adobe PDFs and/or text files? The LE-5W has pre-installed support for each of these, without the need for a PC or similar device.
The LE-5W increases its flexibility of use, multimedia capabilities and versatility by featuring 2 GB of internal memory.
Today's increasingly digital world is spread across a variety of devices and files, demanding flexibility and stronger control of how and where one is able to view digital content. Whether your digital content is stored on a mobile device, PC computer, laptop, tablet, camera or portable memory device, such as a USB memory stick or SD card, the LE-5W enables you to project this content onto a much larger screen, high-definition television or even against an office or living room wall for the ultimate in viewing flexibility.
More than ever, today's business users and home enthusiasts require high-quality, features-rich projectors that are durable and have a low cost of operation - without having to sacrifice performance.
The LE-5W Multimedia Projector minimizes the cost of operation by needing only 130W of power (Normal mode). Power consumption and the cost of operating the projector are further reduced when employing its Eco mode, which utilizes 30% less energy compared to Normal mode. In Standby mode, a mere 0.5W of power are necessary.
Often a projector's highest cost of ownership element is lamp replacement. However, the 20,000 hours of LED life the LE-5W provides its users makes this worry a thing of the past. In fact, its LED lamps can have a lifespan that is 5 times longer than conventional projector lamps, delivering extreme dependability and for a very low cost of ownership that conforms to nearly any budget.
The LE-5W Multimedia Projector is backed by Canon USA's Projector and Lamp Limited Warranty, which guarantees that the projector will be free from defects in workmanship and materials for 3 years from the date of original purchase, and the lamp for 120 days from the date of original purchase.
LE-5W Projector Kit
LE-5W Projector Kit Projector Remote Control (with Lithium battery) AC Power Cord VGA Cable Soft Carrying Case Warranty card(U) User Manual (Multi,CD-ROM) Quick Start Guide (Book) Box with UPC code
Specifications
Projector Specifications
Imaging Device
0.45 DLP Panel
Aspect Ratio
16:10
Native Resolution
WXGA equivalent
Brightness
500 Lumens
Contrast Ratio
3000:1
Digital Keystone (Vertical)
±40 degrees (Auto/Manual)
Optics
Throw Ratio
1.2:1
Image Adjustments
Mounting
Ceiling / Rear-Ceiling
Tilt Angle
0 to 6 degrees
Input Signals
Scanning Frequency
H-Sync: 31-102MHz, V-Sync: 23-120MHz
Analog PC Input
WSXGA+ / SXGA+ / WXGA+ / WXGA / SXGA / XGA / SVGA / VGA
Digital PC Input
Video/S-Video Input
NTSC / NTSC4.43 / PAL / SECAM / PAL-M / PAL-N / PAL-60
Component Input
1080p / 1080i / 720p / 576p / 576i / 480p / 480i
Digital Video Input
Terminals
(Input) RCA x1
Composite Video Input
(Input) Stereo Mini Jack
Stereo Input x1
(Output) Stereo Mini Jack
Stereo Output x1
Built-in Speaker
2.5W x2 (Stereo)
Lamp
Lamp Type
LED x3(RGB)
Lamp Life
20,000 Hours
Remote Control
Sensor
Wireless Infrared
Ratings
Fan Noise (Quiet/Normal)
38dB (Normal) / 31dB (Power Saver)
Power Consumption (Normal/Quiet/Stand-By)
130W (Normal) / 90W (Power Saver) / 0.5W (Standby)
Power Voltage
AC 100 ~ 240V, 50/60Hz
Temperature Operating
32° to 104° F (0° to 40° C)
Dimension (WxHxD)
9.8 x 2.2 x 7.6 in.(248 x 54.9 x 193mm)*including protrusion
9.8 x 1.9 x 7.6 in.(248 x 49.4 x 193mm)*not including protrusion
Weight
3.5 lbs. / 1.6 kg.
Warranty
3 years limited parts and labor
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you LE-5W BK that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
