Web Content Viewer
Actions
REALiS SX7 Mark II D
Support REALiS Projectors
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
Features
To match the increasing demand for high resolution display technology, the REALiS SX7 Mark II D features high resolution SXGA+ resolution with LCOS technology, perfect for displaying crisp video, photographs, fine text, spreadsheets, CAD drawings, and engineering diagrams. Compared to LCD projectors using XGA (1024 x 768), it offers a significantly larger display range, capable of reproducing even the smallest details with razor sharp precision.
Supports Wide Screen Displays
The REALiS SX7 Mark II D supports WXGA (1280 x 800) resolution, allowing for the display of today's more prevalent wide screen laptops and desktop computers- including uncompressed 720p high-definition video. All wide screen data is projected as-is, with no compression- so there is no unsightly distortion.
Realistic Projection
When data produced on a computer with WXGA resolution is projected using an XGA projector- data must be reworked to match the aspect ratio to achieve an accurate display. With the REALiS SX7 Mark II D, wide screen computer data can be projected accurately, with no need for time-consuming adjustments.
The REALiS SX7 Mark II D uses LCOS technology, along with Canon's proprietary AISYS optical engine.
LCOS Technology
With Canon LCOS projectors, you get all the brilliance and image sharpness of innovative LCOS technology in an ultra-portable and affordable projector unlike any others on the market. It's the right choice for displaying bright, big-screen images without darkening the conference room or classroom.
LCOS, or Liquid Crystal On Silicon, has taken projectors to a whole new level. This new technology means higher resolution images, seamless images with no flickering or "screen door" effect, quick image response for better looking moving images, smooth rendition of fine lines, seamless photo reproduction, sharp display of small text, and crisp blacks.
AISYS Optical Engine
Only Canon realizes the full potential of LCOS technology by combining it with our proprietary AISYS Optical Engine- our patented optical light engine for achieving brightness and high contrast using LCOS panels. AISYS has three components: the illumination system; the color separation and combination system; and the LCOS panels. Only Canon's innovative, breakthrough AISYS technology achieves the right balance of contrast, brightness and compact size to maximize the performance of LCOS. Plus, our new advanced AISYS optical engine features new optical elements, redesigned polarizing beam splitters, and a reconfigured optical layout. The result is improved light efficiency, uniformity and expanded color space.
The AC lamp system used in the REALiS SX7 Mark II D projector, combined with Canon's proprietary AISYS optical system, means the images you project are brighter, with truer color. The purity of red and green is enhanced over that possible with conventional DC lamps, giving a more life like depth to the colors on the screen. In addition, the lamp system boasts an operating life up to 2000 hours in normal mode and up to 3000 hours in quiet mode.
LCOS Technology combined with our AISYS optical engine, the new AC lamp system, and 4000 lumens make the REALiS SX7 Mark II D a superb high-performance projector like no other.
The REALiS SX7 Mark II D projects with 4000 Lumens, delivering incredible image quality and brightness using the 3rd generation AISYS Optical Engine's AC lamp system. The 1000:1 contrast ratio ensures deep blacks and bright whites. Pure, high-contrast color reproduction creates images with crisp depth and dimension, ideally suited for conveying texture and materials. Colors remain crisp, with superior color balance, perfect for presentations incorporating high-quality visuals.
The high-quality Canon optics used in the REALiS SX7 Mark II D produce clear, high-resolution projected images.
Bright Images with Outstanding Color Reproduction
The lens glass has been rigorously selected for high transmittance, projecting bright images with exceptional color reproduction and ideal color balance.
Coated to Control Ghosting and Flare
Super Spectra coating, proven in Canon's EF lenses, minimizes reflection from the lens surface, producing bright, clear, high-contrast images with very little of the ghosting and flare that can degrade image quality.
Minimal Color Shift / Color Bleeding
In addition to faithful rendition of high-definition images, the projection lens minimizes color shift and color bleeding throughout the entire zoom range.
Lowered Chromatic Aberration
Chromatic aberration is a type of distortion in which there is a failure of a lens to focus all colors to the same convergence point, causing "fringes" of color to appear along boundaries that separate dark and bright parts of projected image. Incorporation of a UD (Ultra-Low Dispersion) lens significantly lowers chromatic aberration.
Flexible Projector Placement
The REALiS SX7 Mark II D's 1.7x optical zoom lens faithfully projects images while offering ease of placement, allowing you to easily change the screen size to accommodate various venues and/or applications- regardless of space limitations.
The projector's short throw distance allows you to project 100-inch images from only 9.8 feet, making the REALiS SX7 Mark II D easy to setup in large rooms. Only 7.9 feet are needed for 80-inch projections, making the it ideal for classrooms and small meeting rooms.
When displaying 16:9 content, the REALiS SX7 Mark II D allows you to move the projected images up or down the screen into unused pixels - without adding any additional compression. This ability to "fine tune" the placement of the projected image can be useful when projecting onto a fixed screen, or when stacking projectors for increased brightness.
The DICOM Simulation Mode on the REALiS SX7 Mark II D simulates the results of a device compliant with the Digital Imaging and Communications in Medicine (DICOM) Part 14 standardized display function for the display of greyscale images. When in the DICOM Simulation Mode, the REALiS SX7 Mark II D can project images such as X-ray's, CAT scans, and MRI's in a tone similar to the DICOM standard.
Project x-ray's and other medical images for educational use.
Typically, to project the image according to the DICOM standard, it requires a grayscale tone correction using a luminance meter according to the environment. In this projector, there are 21 types of tone settings for various ambient lights. You can easily calibrate the projector by displaying a test pattern image from your PACS workstation.
This flexibility is significant as calibrating in a classroom, conference room or any other environment can be challenging when ambient light varies. The option of calibrating directly on the projector also eliminates the need to purchase additional equipment like a luminance meter.
While not approved for medical diagnosis, this projector is ideal for medical educators who need to display large images to properly trained students, and to conduct lectures and conferences.
Ambient light can cause changes in the accuracy of the colors being projected. The REALiS SX7 Mark II D's Photo Mode allows you to make adjustments to the projectors color temperature and color level*. This feature makes it possible to accurately reproduce color, and provide faithful reproduction of changes in contrast- even on a large screen inside a bright room. Images projected onto the screen are as close to the actual work as possible.
Fine adjustments can also be made in accordance with various environment lights, such as incandescent lamp, fluorescent lamp, and brighter and darker room conditions. Accordingly, accurate image reproduction can be made on a large screen, with a quality similar to the image displayed on an sRGB monitor.
This feature is particularly useful when displaying photography in a studio, wedding center, art museum, or a gallery. All adjusted values can be saved in Photo Mode.
*Adjustments to color temperature and color level can not be made if the projector is set to another image mode.
Proprietary color filters incorporated into the AISYS optical system deliver exceptional accuracy and detail in both Adobe RGB and sRGB modes.
sRGB Color Space
Combined with the projector's AC lamp, this setting produces outstanding support of sRGB color space. This color space was designed to match typical home and office viewing conditions, rather than the darker environment typically used for commercial color matching.
Adobe RGB Color Space
Using a special color filter and the projector's AC lamp, this setting produces exceptional support of Adobe RGB color space. Compared to sRGB, Adobe RGB is a larger color space, capable of reproducing more colors. Professional photography studios, graphic design offices, and printers will have the ability to display images with accurate, uniform color at all stages of the production process.
The REALiS SX7 Mark II D has a variety of features and functions that allow for the projection of outstanding color.
6-Axis Color Adjustment
Your projection screen is your canvas with the REALiS SX7 Mark II D's unparalleled color control. An easy-to-use Graphical User Interface lets you adjust your palette of colors to paint the picture you want for your audience. The SX7 Mark II D's 6-axis (RGBCMY) color adjustment lets you fine-tune the hue and saturation of each of the primary and secondary colors. This high degree of control makes each projected image a masterpiece.
Color Management
Users can manually fine-tune colors and black tones for precise, customized on-screen image adjustment. Instead of having just one master control, the projector offers individual adjustment for color levels and color balance (not available for the RGB input), as well as brightness, contrast, and sharpness.
Memory Color Correction
People's memories are particularly sensitive to skin colors and blues. The memory color correction function emphasizes skin tones and blues to make images more attractive and more memorable. This function works by moving colors in the skin-tone gamut closer to standard skin tones, and processes blue regions to boost the blue component. The degree of vividness for each of the primary colors (red, green, and blue), and each of the secondary colors (cyan, magenta, and yellow) can be adjusted and set between low, medium, and high- to project the image the way you remember it.
Conventional Projector
No color adjustments can result in low saturation and color reproduction.
REALiS SX7 Mark II D Projector
Color adjustments allow for vivid color reproduction.
12-bit Digital Gamma Correction
The 12-bit digital gamma correction allows for 4,096 gradation steps for each color. While many other projectors process only 8-bit image processing, the REALiS SX7 Mark II D's wider range of gradations gives you a smoother transition between colors and tone, with intense color reproduction. Presentations and other content containing photographs display is crisp, clear detail. Video with low-contrast scenes emphasize the contrast in real time, brightening the bright portions and darkening the dark portions- so movies and videos can always be seen clearly.
All that brilliance and image quality means nothing if you don't have the right inputs. The REALiS SX7 Mark II D gives you an impressive range of input options, allowing you to connect to a variety of devices, including laptop and desktop computers, Blu-Ray players, digital cameras and camcorders.
DVI-I Interface (HDCP Compliant)
The SX7 Mark II D's DVI-I interface provides an all-digital connection between the projector and an input source. It avoids the signal conversion step required by analog connections, and thus maintains high signal integrity. This results in a clearer picture, with no flickering, blurred lines, ghost images, or coloration problems with text display. The terminal also accepts an analog signal from your laptop computer, and devices with a VGA terminal.
The interface is also compliant with HDCP (High-bandwidth Digital Content Protection), ensuring a digital connection between HDCP compliant devices, such as many of today's cable boxes, DVD and Blu-Ray players. The high quality of the DVI-I connection makes the REALiS SX7 Mark II D projector ideal for high definition TV, and is compatible with 1080i and 720p video signals - without any reduction in image quality.
Connect to an External Monitor
Many desktop PCs cannot be connected to both a projector and monitor at the same time. However the SX7 Mark II D's Monitor Output terminal allows for an external monitor to be connected to the projector- a practical feature in settings where the projector is hooked up to a desktop computer.
Auto-Synch Audio Inputs
To give your presentations the final touch in impressive audio, the REALiS SX7 Mark II D gives you the flexibility of three audio inputs. You can use one audio input for each source you may have (DVI, VGA, and Video). A variable audio output switches automatically when the input source changes. Audio can be played through the projectors built-in speaker, or can be connected to amplified speakers or a receiver for high-quality sound. All simple to install and with sound levels controllable from your projector's remote control unit.
With an array of advanced and well-designed features, the REALiS SX7 Mark II D is extremely easy to use:
Direct Power On
The REALiS SX7 Mark II D will automatically turn on the projector when the power cord is plugged into an outlet- useful for ceiling installed projectors and eliminating the need to press the power switch on the unit. In addition, the projector will automatically switch off when no input signal is received for 1 minute, saving energy and prolonging the life of the lamp.
Guidance Functions
Once the projector is set up, operating your projector is easy with the help of Guidance Functions that display operating instructions in an on-screen window. A Graphical User Interface makes for easy operation with three menus for quick access to display settings, image adjustments, and system settings. The well thought out command hierarchy means you're never more than three steps away from any adjustment or operation you need to make.
Auto Setup
The REALiS SX7 Mark II D's new Auto Setup feature is quick and accurate. With the touch of a button, it only takes seconds to set up:
  • Auto Focus - your REALiS SX7 Mark II D measures the distance to the screen and makes your projected image razor-sharp
  • Auto Input - the projector automatically detects the input port
  • Auto Keystone - vertical keystone correction is automatically applied
  • Auto Screen Color Correction - the projector automatically compensates for the color of the projection surface
Spotlight
In the classroom or office, the projector's Spotlight feature dims your image except for the area you want everyone to pay attention to. You can make sure your audience see exactly what you want them to see.
Quiet Operation
You can be sure your audience isn't distracted by fan noise. In Normal mode, the REALiS SX7 Mark II D runs at 35dB; and in Quiet mode, it runs at 31dB. You can even operate your REALiS SX7 Mark II D effortlessly with the help of the Wireless IR Remote Control with illuminated keys. The USB mouse function allows users to use the projector remote to operate the mouse of the USB connected computer.
Off and Go
This feature continues to operate the projector's fan after you turn off the projector- especially convenient when the projector is mounted on the ceiling, and can't be operated directly. If you accidentally unplug the projector, a built-in capacitor will run the cooling fan, protecting the life of the lamp.
You never have to wait for the projector to cool down before unplugging it and heading off to your next meeting.
Specifications
Projector Specifications
Basic
0.7 Reflective LCD Panels (LCOS) x 3
Aspect Ratio
4:3
Native Resolution
SXGA+ (1400 x 1050)
Brightness
4000 Lumens
Uniformity
88%
Contrast Ratio
1000:1
Digital Keystone (Vertical)
± 20 degrees (Auto/Manual)
Digital Keystone (Horizontal)
Optics
Projection Lens
F1.85 - 2.5, f=21.7 - 35.8 mm
Lens Shift
9:1, Fixed
Zoom
1.7x Powered, 12x Digital
Focus
Powered (Auto/Manual)
Screen Size
40 - 300
Throw Distance
3.9 - 29.5 ft.
Throw Ratio
1.46 - 2.43:1
Image Adjustments
Image Mode
Standard, Presentation, Movie, Photo, Adobe RGB, sRGB
Color Adjust
Dynamic Gamma, 6-Axis (RGBCMY) Color Adjustment
Wall Correction
Auto / Manual
Mounting
Ceiling / Rear / Ceiling and Rear
Tilt Angle
Adjusting feet up to 10 degrees
Input Signals
Scanning Frequency
H:15 ~ 100 kHz, V:50 ~ 100Hz, Dot clock: 170 MHz or less
Analog PC Input
UXGA / SXGA+ / SXGA / WXGA / XGA / SVGA / VGA
Digital PC Input
Video/S-Video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N
Component Input
1080i / 1035i / 720p / 576p / 576i / 480p / 480i
Digital Video Input
1080i / 1035i /720p / 576p / 480p
Terminals
(Input) DVI-I 29pin
Digital PC input / Analog PC input / Digital video input
(Input) D-Sub 15pin
Analog PC input / Component input
(Input) RCA x1
Video Input
(Input) Mini DIN 4pin
S-Video input
(Input) RJ-45
N/A
(Input) Stereo Mini Jack
Stereo audio input x3
(Output) D-Sub 15pin
Analog PC out
(Output) Stereo Mini Jack
Stereo audio output x1
Built-in Speaker
1W (Mono)
Control Terminal
D-sub 9pin
Lamp
Lamp Type
275W NSH (AC)
Lamp Life
2000 / 3000 Hours
Remote Control
Sensor
Wireless Infrared, Front / Back
Mouse Control
Mouse Control Receiver (USB)
Ratings
Fan Noise (Quiet/Normal)
35 (normal) / 31 (quiet) dB
Power Consumption (Normal/Quiet/Stand-By)
360W (normal) / 290W (quiet) / 7W (stand-by)
Power Voltage
AC 100 ~ 240V, 50/60Hz
Temperature Operating
41° to 95° F (5° to 35° C)
Temperature Storage
-22° to 104° F (-30° to 60° C), 5%RH ~ 90%RH
Dimension (WxHxD)
10.5 x 13.2 x 4.5 (226 x 336 x 114mm)
Weight
10.6 lbs. (4.8 kg)
Warranty
3 years parts and labor, 120 day lamp
REALiS SX7 Mark II Box Contents
REALiS SX7 Mark II Box Contents REALiS SX7 Mark II D Projector Remote Control (w/ 2 AAA batteries) DVI to VGA Computer Cable Component Video Adapter Cable Power Cable Soft Carrying Case Lens Cap Warranty Card
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you REALiS SX7 Mark II D that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
