Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
REALiS SX80 Mark II
Support REALiS Projectors
Canon Store: $
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
REALiS SX80 Mark II
Brochures
Features
LCOS (Liquid Crystal On Silicon) has taken projectors to a whole new level. This new technology means higher resolution images, seamless images with no flickering or "screen door" effect, quick image response for better looking moving images, smooth rendition of fine lines, seamless photo reproduction, sharp display of small text, and crisp blacks.
LCD
Circuitry around each pixel causes screen door effect.
DLP
Space between micro-mirrors creates screen door effect.
LCOS
Circuitry behind panels virtually eliminates screen door effect.
Resolution is approximately 1.9x greater than conventional XGA projectors, making it possible to reproduce text as small as 5 point. Even word processor documents with small text and figures are clear and easy to read.
Conventional LCD Projector
Text is blurred and difficult to read.
LCOS/AISYS-based REALiS SX80 Mark II
Small text is clear.
High-resolution SXGA+ (1400 x 1050 pixel) projectors are compatible with current mainstream desktop computer SXGA (1280 x 1024), more prevalent wide notebook computer WXGA (1280 x 768 pixel) display images, as well as 16:9 high-definition (1280 x 720 pixel) images.
Compatible with current mainstream desktop computer screens.
Capable of displaying 16:9 high definition video images.
The REALiS SX80 Mark II can reproduce widescreen data as-is, with no unsightly distortion. When data produced on a PC with WXGA display resolution is projected using an XGA projector, data must be reworked to match the aspect ratio to achieve an accurate display. With an SXGA+ multimedia projector, PC-based data can be projected accurately, with no need for time-consuming adjustments.
AISYS-based REALiS SX80 Mark II Projector
Reproduces fine details of texture and materials.
Without 10:0 Lens Shift
Keystone correction required when angle is changed. Image obstructed by table when projector is moved back.
With 10:0 Lens Shift
No keystone correction required when projector is moved straight back. Simple positioning with image quality preserved.
The dark section looks blackish and intensity levels are not assigned accurately.
Specific details of shapes and difference in colors can be visible to the naked eye.
Conventional Projector
No color adjustments can result in low saturation and color reproduction.
Color adjustments allow for vivid color reproduction.
Control Manufacturer Logos
- Auto Focus - your REALiS SX80 Mark II measures the distance to the screen and makes your projected image razor-sharp
- Auto Keystone - vertical keystone correction is automatically applied
- Auto Input - the projector automatically detects the input port
- Auto Screen Color - the projector automatically compensates for the color of the projection surface
When the presentation finishes...
...the projector can be unplugged immediately.
Convenient for quick clean-up and transport.
REALiS SX80 Mark II
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you REALiS SX80 Mark II that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Ceiling Extension (RS-CL08)
RS-CL08 ceiling extension measures between 16 and 24 inches. It is compatible with a variety of ceiling mounts.
MSRP: 379.0
MSRP: 379.0
Ceiling Extension (RS-CL09)
RS-CL09 ceiling extension measures between 24 and 39 inches. It is compatible with a variety ceiling mounts.
MSRP: 399.0
MSRP: 399.0
Ceiling Mount (RS-CL10)
RS-CL010 Ceiling-Mounting Hanger is a sturdy mount. It can be secured to either wood ceiling beams or concrete using commercially available bolts. The adjustable base lets you pitch or rotate your projector ±10° while also rolling it up to 20°. The mount includes anti-fall wires to prevent accidents when unhitching your projector.
MSRP: 999.0
MSRP: 999.0
DVI Cable (LV-CA29)
The LV-CA29 is 6.6 foot long video cable compatible with 24-pin digital DVI connectors.
MSRP: 69.0
REALiS Rolling Projector Case
Carrying case for REALiS projectors featuring a sturdy multi-positioned telescoping handle, protective storage compartments, ball-bearing wheels,and a front pocket accessible laptop case for laptops up to 15.4 inches.
MSRP: 99.0
MSRP: 99.0
Replacement Lamp (RS-LP05)
The RS-LP05 is a 230W NSH (AC) high-pressured mercury lamp. Lamp life is 2500 hours in Quiet Mode and 2000 hours in Normal mode.
MSRP: 579.0
- ${title}${badge}
