Web Content Viewer
Actions
REALiS SX80 Mark II D
Support REALiS Projectors
Calculate projection distance and screen size using the on-screen icons or entering numerical values.
Speed. Quality. Excellence. Learn about our award-winning Service & Support.
Features
The REALiS SX80 Mark II D features high resolution SXGA+, ideal for displaying the fine detail required when viewing X-rays, CAT scans, and MRIs from your PACS workstation. Compared to XGA, it offers a significantly larger display range, capable of reproducing even the smallest details with razor-sharp precision. In addition, the REALiS SX80 Mark II D allows for the medical education data produced on your widescreen laptop to be projected accurately, displaying the entire screen in its true proportions, just as it appears on your laptop.
Better Resolution: Crisp, clear display of text and diagrams.
Resolution is approximately 1.9x greater than conventional XGA projectors, making it possible to reproduce text as small as 5 point. Even word processor documents with small text and figures are clear and easy to read.
XGA
Conventional LCD Projector
Text is blurred and difficult to read.
SXGA+
LCOS/AISYS-based REALiS SX80 Mark II D
Small text is clear.
Expanded Display Area: A trend of the future.
High-resolution SXGA+ (1400 x 1050 pixel) projectors are compatible with current mainstream desktop computer SXGA (1280 x 1024), more prevalent wide notebook computer WXGA (1280 x 768 pixel) display images, as well as 16:9 high-definition (1280 x 720 pixel) images.
Compatible with current mainstream desktop computer screens.
Capable of displaying 16:9 high definition video images.
Widescreen Views
The REALiS SX80 Mark II D can reproduce widescreen data as-is, with no unsightly distortion. When data produced on a PC with WXGA display resolution is projected using an XGA projector, data must be reworked to match the aspect ratio to achieve an accurate display. With an SXGA+ multimedia projector, PC-based data can be projected accurately, with no need for time-consuming adjustments.
With Canon LCOS projectors, you get all the brilliance and image sharpness of innovative LCOS technology, but in an ultra-portable and affordable projector unlike any others on the market. It's the right choice for displaying bright, big-screen images without darkening the conference room or classroom.
LCOS (Liquid Crystal On Silicon) has taken projectors to a whole new level. This new technology means higher resolution images, seamless images with no flickering or "screen door" effect, quick image response for better looking moving images, smooth rendition of fine lines, seamless photo reproduction, sharp display of small text, and crisp blacks.
LCD
Circuitry around each pixel causes screen door effect.
DLP
Space between micro-mirrors creates screen door effect.
LCOS
Circuitry behind panels virtually eliminates screen door effect.
But only Canon realizes the full potential of LCOS technology by combining it with our proprietary and improved 3rd generation AISYS Engine; our patented optical light engine for achieving brightness and high contrast using LCOS panels. AISYS has three components: the illumination system; the color separation and combination system; and the LCOS panels. Only Canon's innovative, breakthrough AISYS technology achieves the right balance of contrast, brightness and compact size to maximize the performance of LCOS. Plus, our new advanced AISYS optical engine features new optical elements, redesigned polarizing beam splitters, and a reconfigured optical layout. The result is improved light efficiency, uniformity and expanded color space.
LCD
Grid-like pixel pattern known as the "Screen Door Effect".
LCOS
Lattice-free, seamless image when LCOS is combined with AISYS.
DLP
Color appears blurred and broken.
LCOS
Color appears crisp and sharp.
With the new AC lamp system of the REALiS SX80 Mark II D and the AISYS optical system the images you project are brighter, with truer color. The purity of red and green is enhanced over that which is possible with conventional DC lamps, giving a more life-like depth to the colors on the screen. In addition, the new lamp system boasts an extended operating life, up to 2,000 hours in normal mode and up to 2,500 hours in quiet mode.
LCOS technology combined with an improved 3rd generation AISYS optical engine, the new AC lamp system, and 3000 lumens make the REALiS SX80 Mark II D a superb high-performance projector like no other.
The REALiS SX80 Mark II D projects with 3000 Lumens, delivering incredible image quality and brightness using the 3rd generation AISYS Optical Engine's new AC lamp system. The 900:1 contrast ratio ensures deep blacks and bright whites. Pure, high-contrast color reproduction creates images with crisp depth and dimension, ideally suited for conveying texture and materials. Colors remain crisp, with superior color balance, perfect for presentations incorporating high-quality visuals.
AISYS-based REALiS SX80 Mark II D Projector
Reproduces fine details of texture and materials.
The REALiS SX80 Mark II D's new 1.5x zoom lens suppresses the distortion of images to the maximum extent. Made possible by a lens design technology Canon has accumulated in the past, the new REALiS SX80 Mark II D is able to project images more faithfully.
The lens also features a 10:0 lens offset, which maintains the lower edge of projected images. The lower edge of the projected image matches the optical axis of the lens. This permits projection of high-quality images without the deterioration in image quality caused by keystone correction.
You can easily change the screen size to accommodate various venues and/or applications. It is now easier to set up the projector perpendicular to the screen without having to tilt the projector, or use the keystone correction.
Without 10:0 Lens Shift
Keystone correction required when angle is changed. Image obstructed by table when projector is moved back.
With 10:0 Lens Shift
No keystone correction required when projector is moved straight back. Simple positioning with image quality preserved.
The new REALiS SX80 Mark II D features a new DICOM Simulation image mode setting, that allows the projector to be calibrated to the DICOM14 standard- a grayscale standard display function used by virtually every medical professional that utilizes images within the medical education industry. Images such as X-rays, CAT scans, and MRIs that are typically displayed on DICOM compliant monitors can now be projected with the REALiS SX80 Mark II D- using the same DICOM standard. This feature is recommended for use in medical schools for training and educational use only.
Project x-rays and other medical images using the DICOM14 standard.
A built-in, easy to use calibration tool allows you to configure the projector to match the brightness of the environment that the image is being displayed. With 21 steps of preset gamma adjustments, the new REALiS SX80 Mark II D gives you greater flexibility when calibrating the projector in the variable lighting conditions of your conference or classroom setting.
Built-in calibration tool has 21 steps of preset gamma adjustments.
The REALiS SX80 Mark II D's Photo Mode allows you to make precise adjustments to the projectors color temperature and color level.
Ambient light can cause changes in the accuracy of the colors being projected. The photo mode allows you to make adjustments to the projector based on the lighting condition of the room to ensure optimum color accuracy. This feature is particularly useful when displaying photography in a studio, wedding center, art museum, or gallery. Adjusted value can be saved in Photo Mode. Adjustments to color temperature and color level can not be made if the projector is set to DICOM or another image mode.
Your projection screen is your canvas with the REALiS SX80 Mark II D's unparalleled color control. An easy-to-use Graphical User Interface lets you adjust your palette of colors to paint the picture you want for your audience. The REALiS SX80 Mark II D's 6-axis (RGBCMY) color adjustment lets you fine-tune the hue and saturation of each of the primary and secondary colors. This high degree of control makes each projected image a masterpiece.
With Memory/Vivid Color Correction, you can adjust the degree of vividness of each of the primary colors (red, green, and blue) and each of the secondary colors (cyan, magenta, and yellow). Choose between low, medium, and high to project the image the way you remember it.
Conventional Projector
No color adjustments can result in low saturation and color reproduction.
Color adjustments allow for vivid color reproduction.
The REALiS SX80 Mark II D is the first Canon projector equipped with an HDMI terminal (version 1.3 deep color), supporting full HD 1080p signals provided by HDTV capable satellite and cable boxes, as well as Blu-Ray players. Connect an HD capable satellite or cable box, digital camcorder or Blu-Ray player to the HDMI terminal for instant display of high-definition video.
The REALiS SX80 Mark II D is designed to accommodate new styles of presentations. The built-in USB port allows for connection of various media sources, such as USB flash drives or PictBridge compatible cameras. Just plug in your flash drive or camera, and JPEG images are automatically re-sized and displayed.
To maximize the usability of the REALiS SX80 Mark II D, the new built-in network interface (RJ-45) enables centralized control and monitoring of multiple projector units from a networked pc. This makes it simple for an A/V team to operate ceiling mounted or remotely installed projectors from a PC screen, allowing fewer personnel to cover a larger service area.
The REALiS SX80 Mark II D is compatible with industry-standard AMX, Crestron, and Extron controllers, making it possible to construct a sophisticated AV system. In addition, email alerts can be sent to the central PC to give notification of any malfunctions or service issues which may arise in a projector. The SX80 Mark II D can also be externally operated through its RS-232 port.
Control Manufacturer Logos
With dimensions of 13.0" W x 13.4" D x 4.8" H (332 x 340 x 121 mm) and a weight of only 11.5lbs (5.2 kg), the REALiS SX80 Mark II D is an ultra-portable and compact projector that's easy to carry and set up, wherever you need it. And with an array of advanced and well-designed features, it's also extremely easy to use:
Automatic Vertical Keystone Correction lets you project a perfect image by correcting for keystone distortion of +/- 20 degrees. Plus, depending on your requirements, you can use it for rear-projection, or you can mount it on the ceiling with an optional Ceiling Mount Adapter.
The REALiS SX80 Mark II D's Auto Setup feature is quick and accurate. With the touch of a button, it only takes seconds to setup:
  • Auto Focus - your REALiS SX80 Mark II D measures the distance to the screen and makes your projected image razor-sharp
  • Auto Keystone - vertical keystone correction is automatically applied
  • Auto Input - the projector automatically detects the input port
  • Auto Screen Color - the projector automatically compensates for the color of the projection surface
The Auto Set-up function performs four vital set-up configurations at the touch of a single button. This convenient function ensures optimum settings, even if you've never operated a projector before.
Once it's set up, operating your projector is easy with the help of Guidance Functions that display operating instructions in an on-screen window. A Graphical User Interface makes for easy operation, with three menus for quick access to display settings, image adjustments and system settings. You're never more than three steps away from any adjustment you need to make! Plus, front and rear infrared sensors let you control your REALiS SX80 Mark II D with a wireless remote from in front of or behind the projector.
In the classroom or office, the projector's Spotlight feature dims your image except for the area you want everyone to pay attention to. That way, you can make sure your audience sees exactly what you want them to see. All the while, you can be sure your audience isn't distracted by fan noise. In Normal mode, the REALiS SX80 Mark II D runs at 35dB; and in Quiet mode, it runs at 31dB.
The REALiS SX80 Mark II D even has features that make it simple to turn off. You never have to wait for the projector to cool down before unplugging it and heading to your next meeting - the projector's fan continues to operate, powered by an internal charging system. You can also turn the projector off simply by unplugging it - a convenient feature when the projector is mounted on the ceiling and can't be operated directly.
When the presentation finishes...
...the projector can be unplugged immediately.
Convenient for quick clean-up and transport.
Finally, when you're finished using your REALiS SX80 Mark II D, you can use the Pin Code Lock and Function Key Lock to control its use. On top of all of that, the REALiS SX80 Mark II D makes your life easier with its 3-year parts and labor warranty and 120-day lamp life warranty.
Specifications
Projector Specifications
Imaging Device
0.55 Reflective LCD Panels (LCOS) x 3
Aspect Ratio
4:3
Native Resolution
SXGA+ (1400 x 1050)
Brightness
3000 Lumens
Uniformity
88%
Contrast Ratio
900:1
Digital Keystone (Vertical)
± 20 degrees (Auto/Manual)
Digital Keystone (Horizontal)
N/A
Optics
Projection Lens
F1.95 - 2.6, f=16.6 - 24.8 mm
Lens Shift
10:0; Fixed
Zoom
1.5x Powered, 12x Digital
Focus
Powered (Auto/Manual)
Screen Size
40-300
Throw Distance
3.9 - 29.9 ft.
Throw Ratio
1.48 - 2.18:1
Image Adjustments
Image Mode
Standard, Presentation, Movie, sRGB, Photo, DICOM
Color Adjust
Dynamic Gamma, 6-Axis (RGBCMY) Color Adjustment
Wall Correction
Auto / Manual
Mounting
Ceiling / Rear / Ceiling and Rear
Tilt Angle
Adjusting feet up to 10 degrees
Input Signals
Scanning Frequency
H:15~75 kHz , V:50~85 Hz Dot clock: 170 MHz or less
Analog PC Input
UXGA / SXGA+ / WXGA / SXGA / XGA / SVGA / VGA
Digital PC Input
SXGA+ / SXGA / WXGA / XGA / SVGA / VGA
Video/S-Video Input
NTSC / PAL / SECAM / NTSC4.43 / PAL-M / PAL-N
Component Input
1080p / 1080i / 1035i / 720p / 576p / 480p / 576i / 480i
Digital Video Input
HDMI: 1080p / 1080i / 720p / 576p / 480p
Terminals
(Input) DVI-I 29pin
Digital PC input / Analog PC input / Digital video input
(Input) D-Sub 15pin
Analog PC input / Component input
(Input) RCA x1
Video Input
(Input) Mini DIN 4pin
S-Video input
(Input) 5BNC
(Input) RJ-45
Yes
(Input) Stereo Mini Jack
Stereo audio output x3
(Output) D-Sub 15pin
Analog PC out
(Output) Stereo Mini Jack
Stereo audio output x1
Built-in Speaker
1W (Mono)
Control Terminal
D-sub 9pin
Lamp
Lamp Type
230W NSH (AC)
Lamp Life
2000 / 2500 Hours (Normal/Quiet)
Remote Control
Sensor
Wireless Infrared, Front / Back
Mouse Control
N/A
Ratings
Fan Noise (Quiet/Normal)
31 (quiet) / 35 (normal) dB
Power Consumption (Normal/Quiet/Stand-By)
330W (normal) / 270W (quiet) / 15W (stand-by)
Power Voltage
AC 100 ~ 240V, 50/60Hz
Temperature Operating
41° to 95° F (5° to 35° C)
Temperature Storage
104° to -22° F (60° to -30° C), 5%RH ~ 90%RH
Dimension (WxHxD)
13.3 x 4.8 x 13.6 (332 x 121 x 340mm)
Weight
11.5 lbs (5.2 kg)
Warranty
3 years parts and labor, 120 day lamp
REALiS SX80 Mark II D REALiS SX80 Mark II D Projector Remote Control (w/ two AAA batteries) DVI to VGA Computer Cable Component Video Adapter Cable Power Cable Lens Cap Soft Carrying Case Quick Start Guide Warranty Card
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you REALiS SX80 Mark II D that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
DISCLAIMERS
The REALiS SX80 Mark II D projector is not cleared or approved for medical diagnosis and should not be used for these purposes. DICOM is the registered trademark of the National Electrical Manufacturers Association for its standards publications relating to digital communications of medical information.
 Return to Top
