Web Content Viewer
Actions
REALiS X700
Support REALiS Projectors
Features
<br/> <br/> <br/> <br/> &nbsp;LCOS Reflective LCD Panel<br/> <br/> With Canon LCOS projectors, you get all the brilliance and image sharpness of innovative LCOS technology, but in an ultra-portable and affordable projector unlike any others on the market. It's the right choice for displaying bright, big-screen images without darkening the conference room or classroom.<br/> <br/> LCOS - or Liquid Crystal On Silicon - has taken projectors to a whole new level. This technology means higher resolution images, seamless images with no flickering or "screen door" effect, quick image response for better-looking moving images, smooth rendition of fine lines, seamless photo reproduction, sharp display of small text, and crisp blacks.<br/><br/> But only Canon realizes the full potential of LCOS technology by combining it with our proprietary and improved AISYS Engine, our patented optical light engine for achieving brightness and high contrast using LCOS panels. AISYS has three components: the illumination system; the color separation and combination system; and the LCOS panels. Only Canon's innovative, breakthrough AISYS technology achieves the right balance of contrast, brightness and compact size to maximize the performance of LCOS. Plus, our AISYS optical engine features new optical elements, redesigned polarizing beam splitters, and a reconfigured optical layout. The result is improved light efficiency, uniformity and expanded color space.<br/> <br/> With the new AC lamp system of the X700 and the AISYS optical system, the images you project are brighter, with truer color. The purity of red and green is enhanced over that which is possible with conventional DC lamps, giving a more lifelike depth to the colors on the screen. In addition, the new lamp system boasts an extended operating life, up to 2000 hours in normal mode and up to 3000 hours in quiet mode.<br/><br/> <br/> <br/> <br/> <br/> <br/> LCOS, an AISYS optical engine, the new AC lamp system and 4000 ANSI lumens make the REALiS X700 a bright, high-performance projector like no other.<br/>
Razor-sharp images are yours with Canon's new REALiS X700 projector. The X700's XGA gives you the crispness of 1024x768 pixels of resolution. Plus, it lets you display 16:9 digital broadcast images, as well as (compressed) SXGA. It even supports UXGA (1600 x 1200) (compressed), along with WXGA (1366 x 768) which is used in today's widescreen laptops.<br/> <br/>
Project a positive image with Genuine Canon Optics. As with every camera and projector that Canon makes, the REALiS X700 comes with optics of unparalleled excellence that give you a bright, crisp, clear image.<br/> <br/> <br/> <br/> The 1.7x Ultra-Wide Zoom Lens has the widest zoom range of any of Canon's projector lenses, giving you a diagonal screen size range of 40" (at a very short projection distance of 3.9') to 300". At a short 9.8' distance, you still get a 100" screen. And if that's not enough, the Digital Zoom feature gives you an additional zoom range of 1.7x to 12x. The REALiS X700 performs in a wide range of room settings, proving that there's more to portability than projector size.<br/> <br/> In addition to this quality and flexibility, the X700 boasts an impressive 1000:1 contrast ratio for sharp images and deep, rich colors -- even with ambient light. It also gives you 88% image uniformity for an even image from corner-to-corner.<br/> <br/> The optical performance of your X700 doesn't stop there -- it's a cinematic experience that is further enhanced by the projector's 2:3 Pulldown feature on Progressive Scan images. The result is an image with the natural look of film.<br/> <br/>
With dimensions of 10.5" W x 13.2" D x 4.5" H (226 x 336 x 114mm) and a weight of only 10.6lbs (4.8kg), the X700 is an ultra-portable and compact projector that's easy to carry and set up, wherever you need it. And with an array of advanced and well-designed features, it's also extremely easy to use:<br/> <br/> Keystone Correction lets you project a perfect image by correcting for keystone distortion of +/- 20 degrees horizontally or vertically. Plus, depending on your requirements, you can use it for rear-projection, or you can mount it on the ceiling with an optional Ceiling Mount Adapter.<br/> <br/> The X700's new Auto Setup feature is quick and accurate. With the touch of a button, it only takes seconds to set up:<br/> Auto Focus -- your X700 measures the distance to the screen and makes your projected image razor-sharp<br/> Auto Input -- the projector automatically detects the input port<br/> Auto Keystone -- vertical keystone correction is automatically applied<br/> Auto Screen Color Correction -- the projector automatically compensates for the color of the projection surface<br/> <br/> <br/> Once it's set up, operating your projector is easy with the help of Guidance Functions that display operating instructions in an on-screen window. For example, it lets you know when your projector doesn't detect an input signal. A Graphical User Interface also makes for easy operation, with three menus for quick access to display settings, image adjustments and system settings. Its well thought-out command hierarchy means you're never more than three steps away from any adjustment or operation you need to make. Illuminated Input Indicators show your projector's connections and operational status at a glance. Plus, front and rear infrared sensors let you control your X700 with a wireless remote from in front of or behind the projector.<br/> <br/> In the classroom or office, the projector's Spotlight feature dims your image except for the area you want everyone to pay attention to. That way, you can make sure your audience sees exactly what you want them to see.<br/> <br/> All the while, you can be sure your audience isn't distracted by fan noise. In Normal mode, the X700 runs at 35dB; and in Quiet mode, it runs at 31dB. Plus, you won't be distracted because you can operate your X700 effortlessly with the help of the Wireless IR Remote Control with illuminated keys. And the USB mouse function allows users to use the projector remote to operate the mouse of the USB connected computer.<br/> <br/> The X700 even has features that make it simple to turn off. You never have to wait for the projector to cool down before unplugging it and heading to your next meeting - the projector's fan continues to operate, powered by an internal charging system. You can also turn the projector off simply by turning the power off with a control switch - a convenient feature when the projector is mounted on the ceiling and can't be operated directly. PIN Code Lock and Function Lock allow you to control who can make changes to the projector and prevent tampering with the settings.<br/> <br/> You can even operate your projector - and receive alerts - through a LAN with the optional Network Adapter.<br/> <br/> On top of all that, the X700 makes your life easier with its 3-year parts and labor warranty and 120-day lamp life warranty.<br/> <br/>
<br/> <br/> All that brilliance and image quality means nothing if you don't have the right inputs. The REALiS X700 gives you an impressive range of input options including:<br/> Analog PC<br/> UXGA, SXGA+, SXGA, WXGA, SVGA, VGA<br/> <br/> Digital PC<br/> XGA, SVGA, VGA<br/> <br/> DVI Video<br/> 1080i, 1035i, 720p, 575p, 480p<br/> <br/> Component Video<br/> 1080i, 1035i, 720p, 575p, 575i, 480p, 480i<br/> <br/> Composite Video and S-Audio<br/> NTSC, PAL, SECAM, NTSC 4.43, PAL-M, PAL-N<br/> <br/> Audio<br/> Three audio inputs<br/> One variable audio output<br/> The X700's DVI-I terminal gives you a true digital connection - from source to display. Since it conforms to HDCP (High Bandwidth Digital Copy Protection), you can use your X700 to project high-quality video from satellite and digital cable boxes, as well as DVD players - without any reduction in image quality. (The terminal also accepts an analog signal from your laptop computer and devices with a VGA terminal.)<br/> <br/> More audio flexibility is yours with the X700 thanks to its three inputs. You can use one audio input for each source you may have (DVI, VGA and Video). The variable audio output will switch automatically when the input source changes and can be connected to amplified speakers or a receiver for high-quality sound. All simple to install and with sound levels controllable from your projector's remote control unit.<br/> <br/>
<br/> <br/> <br/> <br/> <br/> &#160;Color Modes<br/> <br/> <br/> <br/> &#160;Complete Color Control<br/> <br/> <br/> <br/> <br/> Color Modes<br/> <br/> <br/> With the REALiS X700, you can select between four Color Modes, each one designed for a different type of projection:<br/> <br/> Standard mode gives you images closely resembling the original, with an emphasis on white areas<br/> Presentation mode increases contrast between bright and dark areas, making it easier to see detailed diagrams and text<br/> sRGB mode is optimized for sRGB images, which includes those produced by many digital cameras<br/> Movie mode emphasizes gradation to produce realistic depth and dimension - the best way to watch your favorite movie or home video<br/> <br/> <br/> <br/> sRGB Example<br/> <br/> You can also create custom settings by adjusting seven different aspects (brightness, contrast, sharpness, gamma, and more) for each of the four image modes. This means 28 different custom image modes for a perfect picture, no matter what you're viewing.<br/> <br/> Complete Color Control<br/> <br/> <br/> Your projection screen is your canvas with the X700's unparalleled color control. An easy-to-use Graphical User Interface lets you adjust your palette of colors to paint the picture you want for your audience.<br/> <br/> With Memory/Vivid Color Correction, you can adjust the degree of vividness of each of the primary colors (red, green, blue) and each of the secondary colors (cyan, magenta, yellow). Choose between low, medium, and high to project the image the way you remember it.<br/> <br/> Plus, the projector's 6-axis (RGBCMY) Color Adjustment lets you fine-tune the hue and saturation of each of the primary and secondary colors. This high degree of control makes each projected image a masterpiece.<br/>
To maximize the usability of the REALiS X700, an optional Network Adapter is available. With the adapter and the included software, it is possible to operate the X700 from a networked PC. This makes it simple for an A/V team to operate ceiling mounted or remotely installed projectors from a PC screen, allowing fewer personnel to cover a larger service area.<br/><br/> In addition, alerts can be sent to the PC to give notification of any malfunctions or service issues which may arise in a projector. Numerous projectors may be monitored and controlled from a single PC.<br/><br/> <br/>
Realis X700 Box Contents
Realis X700 Box Contents REALiS X700 Projector Remote Control (with AAA batteries) DVI-VGA Computer Cable Component Video Adapter Cable USB Cable Power Cable Soft Carrying Case Lens Cap Warranty Card
Specifications
Projector Specifications
Imaging Device
0.7 Reflective LCD Panel (LCOS) x 3
Native Resolution
XGA
Brightness
4000 Lumens
Uniformity
88%
Contrast Ratio
1000:1
Digital Keystone (Vertical)
± 20 degrees (Auto/Manual) Vertical Adjustment
± 20 degrees (Manual) Horizontal Adjustment
Optics
Projection Lens
XGA, SVGA, VGA, HDTV, DTV, SXGA (compressed), SXGA+ (compressed), WXGA (compressed), UXGA (compressed)
Lens Shift
8.6:1.4, Fixed
Zoom
1.7x powered
Screen Size
40 - 300 in.
Throw Distance
3.9 - 29.5 ft./1.2 - 9.m
Input Signals
Scanning Frequency
H:15 ~ 100 kHz , V: 50 ~ 100 Hz, Dot clock: 108 MHz
Analog PC Input
Video/S-Video Input
NTSC/PAL/SECAM/NTSC4.43/PAL-M/PAL-N
Component Input
S-Video, Composite, Component, VGA, DVI-I, Stereo Audio x3, USB, Component 5BNC (with optional accessory), RS-232 (for control systems)
Terminals
(Input) RJ-45
Optional Adapter (RS-NA01)
(Input) Stereo Mini Jack
1 Stereo Mini Audio, 1 Service Port (DIN 8 Pin)
(Output) Stereo Mini Jack
1 RGB (D-Sub 15 Pin), 1 Stereo Mini Audio
Built-in Speaker
1W, Monaural
Lamp
Network
RS232, IR
Lamp Life
275W NSH (AC)
Remote Control
Sensor
Yes
Ratings
Power Consumption (Normal/Quiet/Stand-By)
360W (Normal)/ 290W (Silent)
Power Voltage
100 to 120/200 to 240V AC, 50/60Hz
Temperature Operating
41° to 95°F (5° to 35°C)
20% to 80% humidity (non-condensing)
Temperature Storage
14° to 122°F (-10° to 50°C)
Dimension (WxHxD)
10.5 x 13.2 x 4.5 (226 x 336 x 114mm)
Weight
10.6lbs (4.8kg)
Warranty
3 Years Parts and Labor, 120 Days (Lamp)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you REALiS X700 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
