Web Content Viewer
Actions
RE-455X
Support Visualizers
Features
&#160; No matter what you need to show in the office or classroom, the RE-455X can handle it. With its versatile design, you can capture images of original documents, 3-D objects and photographs -- then project them or display them on a monitor. The RE-455X's 12X zoom lens lets you display objects or images as small as 1.2" x .9" (31.5mm x 23.7mm), as well as objects or images as large as 12.1" x 9" (306mm x 230mm). And, for convenience, the RE-455X has a one-touch button for setting the zoom to A4-size documents.<br/> <br/> You can even connect your PC to your RE-455X, then switch between the RGB input from your computer and the image from your RE-455X for a single, seamless presentation.<br/> <br/> <br/> <br/> <br/> <br/> <br/>
The RE-455X is designed to give you uncompromising optical performance.<br/> <br/> The RE-455X's 12X zoom lens combines with its 1/3" XGA (1024x768) resolution CCD to give you a sharp, clear image, while a built-in scan converter optimally outputs analog RGB signals and video signals (composite and S-video).<br/> <br/> Twin fluorescent lamps provide uniform light, which means you'll catch even the smallest detail. And 520 TV line resolution and advanced color processing system with XGA output further ensures that every presentation is displayed flawlessly.<br/> <br/> Plus, the RE-455X's Text Enhancement feature -- along with auto white balance and exposure -- ensures ultra-clear, accurate image quality when projecting white paper documents.<br/> <br/>
Don't miss a beat during your next presentation -- thanks to the RE-455X. With the press of a button, a high-quality still image can be temporarily stored in memory, and then displayed on a projector or monitor. You even get 15 frames/second capture for smooth XGA motion images.<br/> <br/> Capturing an image is easy because the RE-455X comes equipped with Auto Exposure, Auto White Balance, along with Auto Focus and Manual Focus modes. In addition, One-shot AF mode is an enhanced AF mode designed for use with many 3-D objects of varying sizes.<br/> <br/>
<br/> <br/> Because all of the RE-455X's controls are located on the front, adjustments can be made quickly and easily -- which means all your attention is on your presentation.<br/> <br/>
&#160; The RE-455X is easy to take with you because it folds into a compact package 19.13" (W) x 20.66" (H) x 7.20" (D) (48.6cm x 52.5cm x 18.3cm) and weighs an easily manageable 20.7 lbs. (9.4kg).<br/> <br/>
RE-455X Kit Contents
RE-455X Kit Contents RE-455X Visualizer VGA Computer Cable AC Cable (with Connector) Dust Cover User's Manual Warranty Card
Specifications
Visualizer Specifications
Image Device
1/3 CCD
Effective Pixels
Horizontal 1,024 pixels x Vertical 768 pixels
Synchronization
Internal synchronization only (XGA output and NTSC output are asynchronous)
Resolution
XGA output 520 horizontal TV lines or more, 450 vertical TV lines or more
Imaging Speed
XGA output 15 frames/sec.
Lens
F=5.4mm.64.8mm F1.8-F2.8 10 element, 8 group design
Range
(Maximum) 12.1 x 9.1 in. - 1.2 x 0.9 in. (306 x 230mm - 31.5 x 23.7mm)
Zoom
12x power zoom with PRESET ZOOM button for letter size
Focus
Power auto/manual
Iris Adjustment (Exposure)
Power auto/manual with WHITE PAPER button for white documents
White Balance
Auto/manual
Illumination Lamp
6W fluorescent lamp x 2, high-frequency lighting, angle-adjustable
Input Sources
Can be switched between internal camera head/external input equipment for XGA only
Input/Output terminals
RGB input/output (XGA) D-SUB 15-pin x 1, input/output impedance: 75Ω
Video output RCA pin jack x 1, output impedance: 75Ω
S-video output 4-pin mini-DIN x 1, output impedance: 75Ω
RS-232C serial interface x 1
AC input x 1
Power Source
AC100-240V 50/60Hz
Power Consumption
Approx. 23W
Dimensions
(W x D x H) Operating position: 28.5 x 20.7 x 21.9 in. (722 x 525 x 556 mm)
Folded position: 10.2 x 20.7 x 7.2 in. (486 x 525 x 183 mm)
Approx. 10.7 lbs (9.4kg)
Weight
Operating Environment
Temperature: 4°F - 95°F (+5°C - +35°C)
Relative humidity: 20% - 85% (no condensation)
Note:Weight and dimensions are approximate. Errors and omissions excepted. Specifications and design of the product are subject to change without notice. Canon is a registered trademark of Canon Inc.
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you RE-455X that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
