Web Content Viewer
Actions
DP-V3120
4K UHD Reference Displays
Item Code: 4274C002
Find an authorized Canon dealer or rental house for 4K UHD Reference Displays.
Features
31-inch 4K HDR Reference Display
The DP-V3120 is a 31-inch LCD panel capable of resolutions up to 4096 x 2160 pixels in 10-bit color with a peak luminance of 2,000 nits. This panel provides excellent accuracy and color fidelity with edge-to-edge consistency and minimal color shifting.
The state-of-the-art LCD panel in the DP-V3120 provides more stability than other technologies, and is a reliable piece of equipment users can depend on day after day.
2,000-nit HDR peak edge to edge luminance 0.001-nit Full-screen Black Level(2,000,000:1 Contrast Ratio)
The DP-V3120 4K Reference Display is the first in its class to output an astonishing peak 2,000-nit edge-to-edge brightness while maintaining a 0.001-nit black level. The display’s high brightness and ultra-low black level result in a remarkable 2,000,000:1 contrast ratio, making it the ideal choice for imaging professionals who want to ensure accuracy in their HDR deliverables. Bright areas are clearer and more true-to-life with virtually no color-shifting, while shadow detail is maintained without the appearance of being washed out.
Exceeds the Requirements for Dolby Vision Certified Facilities
The DP-V3120 exceeds the Dolby Vision required monitor specifications† including General Monitor Specifications and Grey Scale Reproduction to meet the requirement of a Dolby Vision certified post-production facility.
† Based on “Dolby Vision Certified Mastering Facilities Colorgrading Systems and Monitors Version 1.2” (published in November 2018) required specifications for video production workflows promoted by Dolby Laboratories, Inc.
Quiet Operation
The DP-V3120 is constructed with an aluminum frame and fan system that maintains an exceptionally quiet environment. Even when used for long hours in the editing room, users can concentrate on their work without being distracted by fan noise.
When a compatible camera is connected, the display also features a mode in which the internal fan is automatically shut down for a period of time during camera recording. Compatible cameras include the Cinema EOS system.
12G-SDI with Support for HD/4K/8K Workflows
The DP-V3120 is equipped with a 12G-SDI interface with four inputs and four pass-through outputs. This interface supports HD, 4K and 8K workflows while limiting the number of cables needed.
Each 12G terminal independently supports signals up to 4K 60P. Alternatively, all four terminals can be combined to accept signals up to 8K 60P.*
*8K signals will be downscaled to 4K
Award-winning HDR Toolkit
The DP-V3120 comes with Canon’s award-winning HDR Toolkit. The HDR Toolkit provides a suite of HDR compatible tools including waveform monitor, vectorscope, histogram, false color, frame luminance monitor, pixel value checker, out of gamut display, overrange detection and side-by-side comparison view.
These tools allow users to evaluate subject luminance and color visually on the screen using numerical values and graphs that show whether or not images are being recorded according their intentions. Users can now confidently make creative decisions based on accurate information using a single display.
The HDR Toolkit was recognized by the Hollywood Professional Association with a 2018 Engineering Excellence Award for going beyond the mere display of HDR and for creating a tool that allows filmmakers to accurately assess their images during production.
ACES Support
The DP-V3120 4K Reference Display supports the next-generation ACES standard, ACES2065-1, developed by the Academy of Motion Picture Arts and Sciences (AMPAS).
ACESproxy can be directly input into the display for plug-and-play ACES monitoring.
89° Wide Viewing Angle
The DP-V3120 4K Reference Display offers a wide viewing angle of 89°, top to bottom and left to right. The LCD panel also features an IPS panel, anti-glare coating, and unique polarizing and filtering layers to help minimize color, brightness and contrast shifts to improve on-set visibility and accuracy.
Dual Screen and Quad View
The DP-V3120 can receive up to four input signals. These signals can be displayed side-by-side in either Dual Screen or Quad View for image comparison or multi-view monitoring. Additionally, camera and image information can also be displayed alongside the images. This is useful for checking settings from multiple cameras, the look of different LUTs on the same image, the difference between SDR versus HDR, as well as other types of image comparisons.
Remote Control by Wi-Fi/LAN Connection
The DP-V3120 can be controlled remotely over Wi-Fi or LAN using a PC, tablet, or other device. During remote control operation, three windows are available. The View window can be used for display, zoom and assessing the video. The Control window can be used for accessing the menu and performing main operations. The Information window can be used for checking various information, including settings and signals.
Optimized for use with Cinema EOS System
The DP-V3120 is fully optimized to work with the Canon Cinema EOS system, including direct support for Cinema RAW and Canon Log formats.
Canon Cinema EOS digital cameras can be directly connected to the display, allowing users to check focus, angle-of-view and other picture attributes. Camera metadata can be displayed alongside the image for increased flexibility on-set or in post, including color temperature, f-value, ISO speed, shutter speed, gamma, color gamut, resolution, frame rate, I/P/PsF and camera status (shooting or playback).
Support for third party camera systems
The DP-V3120 supports metadata viewing with ARRI and Panasonic camera systems.
ARRI and Panasonic LUTs can be preloaded into the display, including support for Log C and V-Log. Additionally, HDR is also supported.
ACES 1.0.1 Support
The DP-V3120 4K Reference Display supports the latest ACES2065-1 standard, and has received the ACES logo from the Academy of Motion Picture Arts and Sciences, after review of its ACES implementation.
The DP-V3120 is capable of providing RAW format image de-bayering and ACES Input Transform, enabling the reference display to transfer RAW format images to the ACES2065-1 images. These images can be displayed by adjusting the exposure and colors using a CDL's (color decision lists) and by performing ACES Output Transform processing. In addition, by sharing the CDL data using a USB connection, the signals output by on-the-set grading and editing set-ups have the same colors and gradations, so the "look" determined on-set or at an off-site grade can be maintained throughout the postproduction workflow.
The DP-V3120 also can be used with any source input that complies with ACESproxy.
Specifications
Panel Type
IPS LCD panel
Screen Size
31.1 inch (79.0 cm)
Aspect Ratio
17:9
Resolution
4096 x 2160 (8.8 Megapixels)
Active Display Area
Approx. 27.5 x 14.5 in. (698.0 x 368.1 mm)
Pixel Pitch
132 μm/193 ppi
Brightness*
Standard: 100 cd/m2
Peak, full screen white: 2,000 cd/m2
Viewing Angle (Up, Down, Left, Right)
89° (contrast ratio 10:1 or higher)
Surface Treatment
Anti-glare coating
Backlight Type
LED, Matrix Array
Power
Rated voltage: 100 - 240 V AC
Rated Frequency: 50/60 Hz
Power Consumption
At maximum load (including change in brightness through aging): Approx. 510 W
At factory shipment: Approx. 180 W
Environmental Conditions
Operating
Temperature and humidity: 41—95°F (5—35°C) (20–85% RH no condensation)
Recommended: 59—86°F (15—30°C) (20–80% RH no condensation)
Pressure: 700—1060 hPa
Storage/Transporting
Temperature and humidity: -4—104°F (-20—40°C) (10–85% RH no condensation) 106—140°F (41—60°C) (10–30% RH no condensation)
Dimensions (Width x Height x Depth)
Including handle: Approx. 29 x 19 x 13 in. (749 x 492 x 335 mm)
Display unit only, without protruding parts: Approx. 29 x 19 x 12 in. (749 x 470 x 295 mm)
Weight
Approx. 68 lb. (31 kg)
Mounting Hole Pitch
VESA standard 7.9 x 3.9 in. (200 x 100 mm)
12G/6G/3G/HD/SD- SDI
4 (1 channel) BNC (75 Ω) receptacle terminal
HDMI
1 (1 channel) Type A terminal
Copy protection: HDCP 2.2
12G/6G/3G/HD-SDI
4 (1 pass-thru 1 channel)
Headphone
1 stereo mini-jack (supported impedance: 32—64 Ω)
USB
1 USB A terminal
Universal Serial Bus Specification Revision 2.0 compliant
LS (Low Speed)/FS (Full Speed)/HS (High Speed) mode compatible
Enhanced Host Controller Interface Specification for Universal Serial Bus Revision
1.0 compliant
LAN
1 RJ-45 terminal
IEEE802.3 10BASE-TX compliant IEEE802.3u 100BASE-TX compliant
Remote
1 RJ-45 terminal, GPI 8 pin
Brochures
Loading...
Resources
White Papers
Cinema EOS On-Set HDR/WCG Ecosystem
11/29/18
1.45 MB
Understanding High Dynamic Range (HDR): A Cinematographer Perspective
11/21/17
2.51 MB
3rd Party Cooperation
Manufacturer Product Name Collaboration Content
Light Illusion LightSpace CMS Compatible with
3D LUT Calibration
Portrait Displays Calman Compatible with
3D LUT Calibration
Pomfort LiveGrade Pro Look Adjustment by LUT
LUT Import Function
This is to make Misc appear on the page when needed.
Videos
Introducing the DP-V3120 4K Reference Display
Canon’s 31-inch DP-V3120 4K Reference Display was designed to meet the unique set of challenges that come with HDR production. Featuring an incredible peak 2000-nit edge-to-edge luminance and 0.001-nit full screen black level, the DP-V3120 exceeds the requirements for Dolby Vision™ certified facilities. It is an exceptional choice when seeking superb image quality, accuracy and reliability.
DISCLAIMERS
* Brightness values are standard values and not guaranteed values
 Return to Top
