Web Content Viewer
Actions
24-inch Graphtec Cutter and Colorbyte Software Bundle
Large Format Cutters
Item Code: 4511C007AA
  • Datalink Barcode: save time and reduce the chance of production errors by using barcodes to automatically process multiple jobs at the touch of a button.
  • Contour Cut: separate tool positions ensure the longevity of your blades and cutting strip when creating decals and graphics that are effortlessly popped out of sheet and roll media.
  • Arms 8.0: a new and improved Advanced Registration Mark Sensing System can easily generate barcodes as part of the design, creating a hands-free operation.
  • Network Connection: now possible through a network interface enabling the use of TCP/IP protocols to transfer cut data.
This is to make Misc appear on the page when needed.
24" Graphtec Cutter and Colorbyte Software Bundle
Configuration
Grit roller with digital servo drive system
Maximum cutting area (W x L)
24" x 164'
Cutting area of guaranteed accuracy (W x L) (when using the basket)
23" x 79"
Mountable media width
2" and 28"
Number of push rollers
2 rollers
Maximum cutting speed
36"/s, at 45º direction
Maximum acceleration
69.6' (21.2 m/s2), at 45º direction
Maximum cutting force
4.41 N (450 gf) in 38 steps
Minimum character size
Approx. 5 mm (0.016") alphanumeric (varies depending on character font and type of media)
Programmable resolution
GP-GL: 0.1 / 0.05 / 0.025 / 0.01 mm, HP-GL™: 0.025 mm
Repeat-ability
Max. 0.1 mm in plot up to 2 m (*1)
Mountable number of tools
1 tool
Blade type
Supersteel
Pen type
Oil-based ballpoint, Water-based fiber-tip pen
Media type
Self-adhesive marking film (vinyl, fluorescent, reflective) excluding high-intensity reflective film, up to 25 mil (.63mm) cutting Graphtec Rhinestone Stencil material GRS1510-m
Interface
USB 2.0 (Full Speed), Ethernet 10BASE-T/100BASE-TX
Buffer memory
2 MB
Command sets
GP-GL / HP-GL™ (Set by command or auto-detect)
Display
Graphic type LCD with back-light (240dots x 128dots), supports 10 languages
Registration mark sensing system
Marks are scanned by an optical sensor (ARMS8.0), Segment area and Multiple marks compensation, 4-points axis alignment, Auto mark detect
Alignment accuracy
Maximum 0.3 mm with printed image (when reading registration marks specified by this machine)
Power source
100 to 120, 200 to 240 V AC (Auto switch), 50 / 60 Hz
Power consumption
120 VA
Operating environment
10 to 35 ºC, 35 to 75 % R.H. (non-condensing)
Guaranteed accuracy environment
16 to 32 ºC, 35 to 70 % R.H. (non-condensing)
External dimensions (W x D x H)
Approx. 39.6" x 23" x 43"
(with Basket): (39.6" x 36.9" x 43")
Weight (Approx.)
51 lbs (23 kg)
(with Basket): 55.6 lbs (25.2 kg)
Compatible OS (*2)
Windows 10 / 8.1 / 7
Mac OSX 10.6 - 10.11 - 10.12 - 10.15
Included software
Cutting Master 4, Graphtec Pro Studio (for Windows), Graphtec Studio (for Mac), Windows driver
Compatibility Standards
Safety: PSE, UL/cUL, CE mark
EMC: VCCI Class A, FCC Class A, CE mark
  • CE7000-60 Plus stand (optional 24” stand)
  • Teflon Mat for CE7000-60 (2 Pack)
  • CB15U Blade
  • Blade Holder
What's In The Box
What's In The Box
  • 24" Graphtec CE-7000 60 Plus Cutter (No Stand)
  • Warranty information packet
  • Packet secured to the bottom of the box under the machine that includes: Operation manual for cutter, blade holder, blade, cut off knife, USB cable, and Power cable
  • IMAGEPRINT R.E.D. Software by Colorbyte
  • Graphtec Conditions and Presets sheet
Brochures
Loading...
 Return to Top
