Web Content Viewer
Actions
50-inch Graphtec Cutter and Colorbyte Software Bundle
Large Format Cutters
Item Code: 4511C009AA
  • Datalink Barcode: save time and reduce the chance of production errors by using barcodes to automatically process multiple jobs at the touch of a button.
  • Contour & Die Cut: separate tool positions for contour and die cutting ensures the longevity of your blades and cutting strip when creating decals and graphics that are effortlessly popped out of sheet and roll media.
  • Arms 8.0: a new and improved Advanced Registration Mark Sensing System can easily generate barcodes as part of the design, creating a hands-free operation.
  • Network Connection: now possible through a network interface enabling the use of TCP/IP protocols to transfer cut data.
This is to make Misc appear on the page when needed.
50" Graphtec Cutter and Colorbyte Software Bundle
Blade Types
Graphtec Supersteel
Command sets
GP-GL / HP-GL™ (Set by command or auto-detect)
External dimensions
30.4” x 11.5” x 12.3” (40), 39.6” x 23” x 43” (60), 67” x 32” x 48” (130)
Interface
USB 2.0(Full Speed), Ethernet 10BASE-T/100BASE-TX
Max Cutting Length
164"
Max Cutting Width
50"
Max Feed Width
54"
Max Pressure
4.41N (450gf)
Max Speed
39 in/s, at 45 degrees direction
Max Axial Acceleration
69.6’ (40 60), 45.6’ per second (130) at 45° direction
Memory
2MB
Min Character Size
Approx. 5 mm (0.016”) alphanumeric (varies depending on character font and media)
Model Name
CE7000-130
Number of Pinch Rollers
2 (40, 60), 4 (130 model) 5 optional
Power Requirements
100V to 120V AC, 200V to 240V AC, 50/60 Hz
Resolution
0.005 mm
Roller Mechanism
Grit Roller
Voltage
100V to 120V AC
Contour Cutting
Yes - Automatic
OS Compatibility
Windows, Mac OSX
Motor Type
Servo
Supplies & Accessories
  • Teflon Mat for CE7000-130 (2 Pack)
  • CB15U Blade
  • Blade Holder
What's In The Box
What's In The Box
  • 50" Graphtec CE7000-130 Cutter
  • Stand
  • Warranty information packet
  • Packet secured to the bottom of the box under the machine that includes : Operation manual for cutter, blade holder, blade, cut off knife, USB cable, and Power cable
  • ImagePrint R.E.D. Software by ColorByte
  • Graphtec Conditions and Presets sheet
Brochures
Loading...
 Return to Top
