Web Content Viewer
Actions
NA10 Network Adapter
Other Scanner Accessories
Do you want to extend the life of your imageFORMULA scanner? Additional options and accessories are available to help ensure your scanner is running at its best so you can scan without any hassle.
Select imageFORMULA scanners are bundled with third-party software applications that can easily become a part of your workflow.
Has your imageFORMULA scanner been discontinued? No worries. Service, support, and spare parts will continue to be available for five years after the date of discontinuation. We'll also recommend a new scanner replacement for your discontinued model.
Features
  • Creates a network connection between a compatible imageFORMULA USB scanner and Ethernet network
    • Scanner Compatibility
      • imageFORMULA DR-C230
      • imageFORMULA DR-C240
      • imageFORMULA DR-M140
      • imageFORMULA DR-M160II
      • imageFORMULA DR-M1060
      • imageFORMULA DR-M260
  • Share a scanner among multiple users for "pull" scan uses
  • "Push" scan directly from the scanner to shared folders
  • Integrated Ethernet port for simple network connections
  • Initiate a scan from a mobile device such as a tablet or smartphone
  • Easily fits next to the existing scanner, even in small spaces
  • Only one power cable necessary, the network adapter powers the document scanner
One-year advanced exchange warranty included
Type Network Adapter
Scanner Compatibility imageFORMULA DR-C230
Power Consumption 5.6W
Interface To Scanner: USB 2.0 Hi-Speed
To Network Ethernet: 10/100/1000Base-T x1 or WiFi
Product Dimensions 4.57” (H) x 3.69” (W) x 1.13” (D)
Product Weight 0.4 lb.
Box Dimensions 7.7” (H) x 5.35” (W) x 3.43" (D)
Box Weight 1.2 lb.
This is to make Misc appear on the page when needed.
What's In The Box
What's In The Box Network Adapter EULA Power Cable Packing Materials USB Cable Warranty Card Holder Cable Cover Setup Disc
Brochures
Loading...
DISCLAIMERS
  1. All listed components are sold separately and not included with the purchase of the NA10 Network Adapter.
  2. CaptureOnTouch Job tool app is available on the App Store or Google Play Store.
 Return to Top
