Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
RP10 Thermal Receipt Printer
Other Scanner Accessories
Canon Store: $
Do you want to extend the life of your imageFORMULA scanner? Additional options and accessories are available to help ensure your scanner is running at its best so you can scan without any hassle.
Select imageFORMULA scanners are bundled with third-party software applications that can easily become a part of your workflow.
Has your imageFORMULA scanner been discontinued? No worries. Service, support, and spare parts will continue to be available for five years after the date of discontinuation. We'll also recommend a new scanner replacement for your discontinued model.
The RP10 uses advanced thermal printing technology to help increase
productivity and efficiency in any teller station all while lowering
costs. Combined with Canon imageFORMULA
CR-120 and CR-150 check scanners the RP10 is well suited for financial
services with its compact design, high speed thermal printing, no noise
output, and single footprint functions. The RP10 also features
front-load, front-exit convenience for superior teller ergonomics.
Ultimately, this printer provides an efficient and inexpensive solution
to streamline the many responsibilities involved in teller
station/point-of-service.
Features
- Ideal for environments looking to improve productivity, without sacrificing much work space, through a simple USB connection
- Teller counters at banks or travel agencies
- Ability to stack check scanner on top
- Compatible with imageFORMULA scanners: CR-120, CR-150
- Combines teller functions into a single footprint
- When combined with the check scanner it streamlines teller activity by bringing together the multiple devices needed to run a teller station
- Ability to scan cards, checks, print receipts and can carry out many other additional daily tasks
- High Speed with Minimal Noise Output
- Silent printing
- Minimal noise output from dot matrix printing
- High speed thermal printing
- Prints up to 5.9in/sec (150 mm/sec)
- Prints receipts in less than one second
- Easy to maintain and less expensive than traditional printing.
- Does not require replacing consumables such as inkjet cartridges, traditional paper and printer ribbon, etc.
- One year warranty included - Advanced Exchange Service
- Optional eCarePAK extended service available
- Meets ENERGY STAR guidelines
RP-10 Thermal Printer |
TYPE | Receipt printer |
PRINT METHOD | Thermal Line-dot Printing |
PRINTING DIRECTION1 | Unidirectional with friction feed |
DOT DENSITY | 8 dot/mm |
PAPER FEEDING PITCH | 0.125 mm |
CUTTER METHOD | Full cut/ Partial cut |
MAX PRINT WIDTH | About 2.8” (72 mm) |
PRINT SPEED | Up to 5.9in/sec (150 mm/sec) |
INTERFACE | USB 2.0 full speed (12Mbps) |
OPERATING TEMPERATURE | 0-40oC (32-104 oF) |
OPERATING HUMIDITY | 30 to 85% RH (no dew condensation) |
STORAGE TEMPERATURE | -30 to 50oC (-21 to 122 oF) |
STORAGE HUMMIDITY | 10 to 90% RH (no dew condensation) |
DIMENSIONS | 5.3”(H) x 6.7”(W) x 11” (D) |
WEIGHT | 4.08 lb |
POWER SUPPLY | AC 100-240V 50/60Hz |
POWER CONSUMPTION | Printing: Maximum 55W
Sleep mode 0.7W With power switch OFF: 0.4W |
What's In The Box
Brochures
- ${title}${badge}
