Web Content Viewer
Actions
Scan Kiosk Expansion Pack
Other Scanner Accessories
Do you want to extend the life of your imageFORMULA scanner? Additional options and accessories are available to help ensure your scanner is running at its best so you can scan without any hassle.
Select imageFORMULA scanners are bundled with third-party software applications that can easily become a part of your workflow.
Has your imageFORMULA scanner been discontinued? No worries. Service, support, and spare parts will continue to be available for five years after the date of discontinuation. We'll also recommend a new scanner replacement for your discontinued model.
Features
  • Equipped with large, easy-view 10.8 inch, high definition color touchscreen display
  • Fits comfortably on counter areas
    • Compatible imageFORMULA production scanners can be positioned on top using the scanner placement notches
  • Two adjustable positions
    • Position one for touchscreen as primary interface
    • Position two for use of optional keyboard and/or mouse
  • Touchscreen display can be stowed away conveniently when not in use
  • Optional combination cabinet and pedestal offers additional storage space
    • Scan Kiosk can fit on top through placement notches
  • Included wheels allow users to choose the location and position of the Scan Kiosk
  • uniFLOW Scan License required to activate both the Scan Kiosk and compatible imageFORMULA production document scanner to work with a uniFLOW server
    • Provides network solution without the need for dedicated PC
    • Helps reduce setup challenges in both new and existing installations
  • Activation to uniFLOW enables users to scan to multiple destinations including many third-party applications
    • Therefore™, Microsoft® SharePoint®, Box, and more
    • User identification through various login methods
      • Proximity card
      • Magnetic card
      • PIN code
      • Job Code
      • Username/password input
  • IT Administrators can access various scanner functions, user accounts, and remotely oversee all compatible production scanner devices connected to the network
    • Help to restrict user settings and control access
SYSTEM RESOURCES Quad Core Intel Atom 1.6 GHz CPU, 64 GB storage, 4 GB RAM
NETWORK COMPATIBILITY 10/100/1,000Base-T
SCANNER COMPATIBILITY1 Canon imageFORMULA DR-G1100, DR-G1130, DR-X10C Production Document Scanners
INTERFACE USB 3.0 (x3), Ethernet RJ-45 (x1)
DIMENSONS (H x W x D) 7.2” x 22.7” x 21.8”
WEIGHT 43 lbs.
SOFTWARE2 uniFLOW
OPTIONS Scan Kiosk Cabinet Component, uniFLOW Compatible Hardware Accessories
This is to make Misc appear on the page when needed.
Options & Accessories
Depending upon the scanner model, various options and accessories may be available, such as rollers, carrying cases, AC Adapter and more. The information below highlights additional options and accessories that help to maximize Canon scanner performance and ensure confidence in your investment for years to come.
Please note, the images below are generic visuals and may not necessarily be the image of the actual accessory purchased.
Scan Kiosk Networked Scan Station Expansion Pack
Brochures
Loading...
DISCLAIMERS
1Listed document scanners are sold separately and not included with the Scan Kiosk. Not all scanner options, both hardware and software are supported depending on the capture software integrated with the Scan Kiosk.
2uniFLOW software and licenses are sold separately and not included in the Scan Kiosk.
 Return to Top
