imageRUNNER 1643P
- Print up to 45 ppm (BW)
- Print up to 8-1/2” x 14”
- 2,300-sheet maximum paper capacity
- Black-and-White
- Compact
- User-Friendly
Return Policy
Enterprise Multifunction Printers
From small workgroups and offices to large departments, the imageRUNNER, imageRUNNER ADVANCE DX and imagePRESS Lite platform offers a wide range of models and integrated solutions with proven technology to help address the document workflow challenges of evolving work environments.
Simplify, Control, Evolve
imageRUNNER and imageRUNNER ADVANCE DX can help Simplify the end-user experience and management of technology, better Control sensitive information and print-related costs, and help ensure that technology investments proactively Evolve with changing needs.
Security
The imageRUNNER, imageRUNNER ADVANCE DX and imagePRESS Lite platforms offers a range of security capabilities to help facilitate the confidentiality, accessibility and availability of your data. For added peace of mind, imageRUNNER, imageRUNNER ADVANCE DX and imagePRESS Lite models support McAfee Embedded Control.
Awards
Canon's imageRUNNER and imageRUNNER ADVANCE DX platform has earned numerous awards and recognition from leading industry analysts for its innovation, design, and environmental features.
imageRUNNER 1643 Series Brochure
imageRUNNER 1643P | |
MAIN UNIT | |
| TYPE | Monochrome Laser Printer |
| CORE FUNCTIONS | Print |
| PROCESSOR | Canon Dual Custom Processor2 (Shared) |
| OPERATION PANEL | 5-Line LCD Panel |
| MEMORY | 1.0 GB RAM |
| INTERFACE CONNECTION2 | 1000Base-T/100Base-TX/10-Base-T Others (Standard): USB 2.0 (Host) x3, USB 2.0 (Device) x1 |
| PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass Optional: 550-sheet PAPER FEEDER PF-C1 (up to 3) Maximum: 2,300 Sheets |
| PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Maximum: 150 Sheets |
SUPPORTED MEDIA SIZES | Cassette: Letter, Legal, Statement, Executive Bypass: Letter, Legal, Statement, Executive, Custom size (3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch) |
| SUPPORTED MEDIA WEIGHTS | Cassette: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) Bypass: 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2) |
| PRINT SPEED (BW AND COLOR) | Up to 45 ppm (Letter); Up to 36 ppm (Legal) |
| WARM-UP TIME | From Power On: 30 Seconds or Less3 From Sleep Mode: 3 Seconds or Less |
| DIMENSIONS (W x D x H) | 16-1/8” x 14-13/16” x 10-13/16” (409 mm x 376 mm x 275 mm) |
| INSTALLATION SPACE (W x D x H) | 24-5/16” x 43-7/16” (617 mm x 1104 mm) |
| WEIGHT4 | Approx. 25.3 lb. (11.5 kg) |
PRINT SPECIFICATIONS | |
| FIRST-PRINT-OUT TIME (LTR) | Approx. 5.7 Seconds |
| PRINT RESOLUTION (dpi) | 600 × 600 |
| STANDARD PAGE DESCRIPTION LANGUAGES | UFR II LT, PCL®5e/6, Adobe® PS® 3 (Standard on 1643iF/1643P, optional on 1643i) Optional: Barcode Printing Kit |
| DIRECT PRINT | Supported File Types: TIFF, JPEG, PDF and XPS (only LPR) Available from USB memory, LPR |
| OPERATING SYSTEM | Windows 10/8.1/7 (32/64 bit), Windows Server (2019/2016/2012 R2 (64 bit)/2012 (64 bit)/ 2008 R2 (64 bit) /2008 (32/64 bit), Mac® (OS X 10.6 and later => 10.9 ~ 10/14) Linux (Web Distribution) |
| PRINT FEATURES | Suspend Job Timeout, Profile Settings, Secure Print, Header/ Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Front/ Back Covers, Toner Reduction, Poster Printing |
STORE SPECIFICATIONS | |
| MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
| AUTHENTICATION | Standard: Department ID Optional: uniFLOW and uniFLOW Online |
| NETWORK | Standard: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6 |
| DOCUMENT | Standard: Secure Print |
ENVIRONMENTAL SPECIFICATIONS | |
| POWER REQUIREMENTS | 120-127 V, 60 Hz, 7.1 A |
| PLUG (MAIN UNIT) | NEMA 5-15P |
| POWER CONSUMPTION | Maximum: Approx. 1370W Sleep Mode: 1.9 W5 Typical Electricity Consumption (TEC) Rating6 0.50 kWh |
| STANDARDS | ENERGY STAR® Certified Rated EPEAT® Silver1 |
CONSUMABLES | |
| TONER | Toner T06 Black |
| TONER YIELD (ESTIMATED @ 5% COVERAGE) | 20,500 Images (Estimated Yield @ ISO 19752 Coverage) |
FOOTNOTES | |
RESOURCES
imageRUNNER 1643 Series Environmental Profile Sheet
07.18.22
2.2 MB
imageRUNNER 1643P Series Brochure
12.26.24
1.6 MB
Cloud Connector Brochure
11.05.25
2.5 MB
