Color imageCLASS LBP674Cdw
IC LBP674CDW
Discontinued
The Color imageCLASS LBP674Cdw is no longer available, but you can find similar products below.
  • Wireless, Duplex Printer
  • Print up to 35 Pages Per Minute (BW and Color)
  • Uses Toner 069 / 069 High Capacity Toner
  • 250-sheet Standard Cassette, 50-sheet Multipurpose Tray, Expandable Paper Capacity of up to 850-sheets Using Optional Cassette PF-K1
  • Auto 2-sided Printing
  • ENERGY STAR®, EPEAT Silver
  • 3 Year Warranty
Show more
Overview
Color imageCLASS LBP674Cdw - Front View
imageCLASS LBP674Cdw Logo
Wireless, 2-Sided Color Laser Printer
The imageCLASS LBP674Cdw model balances speedy performance and minimal maintenance.
imageCLASS LBP674Cdw - 5 Main Features
  1. Customizable, 5-Inch Color Touchscreen
  2. USB Device Printing Slot
  3. Print Speed Up To 35 PPM
  4. 50-Sheet Multipurpose Tray
  1. 250-Sheet Paper Tray
  2. Cartridge 069 / 069 H:
    Black - Prints Up To 2,100 / 7,600 Sheets
    Color - Prints Up To 1,900 / 5,500 Sheets
Features
Easy WiFi Setup
Connect your printer to a wireless network in four simple steps:
STEP 1 – Press WIRELESS LAN
Actual display screen may vary.
Easy WiFi Setup
STEP 2 – Select NETWORK
Easy WiFi Setup
STEP 3 – Enter ENCRYPTION KEY / PASSWORD
Easy WiFi Setup
STEP 4 – FINALIZE
imageCLASS LBP674Cdw - WiFi Setup Step 1
imageCLASS LBP674Cdw - WiFi Setup Step 2
imageCLASS LBP674Cdw - WiFi Setup Step 3
imageCLASS LBP674Cdw - WiFi Setup Step 4
LBP674Cdw uses Canon Genuine Toner 069 / 069 H
High capacity toner option keeps up with your printing needs and limits toner replacement interruptions.
Canon Genuine Toner 069: Up to 2,100 black / 1,900 color pages
Optional Canon Genuine Toner 069 H: Up to 7,600 black / 5,500 color pages
Toner Cartridge 069 / 069 H
5" Color Touchscreen
Navigate through all the features with the customizable, 5" Color Touchscreen.
imageCLASS LBP674Cdw - LCP Panel
Standard paper capacity provides up to 250 sheets in the cassette and 50 sheets in the multipurpose tray. Optional cassette PF-K1 provides up to 550 sheets, giving you up to 850 sheets of paper capacity.
imageCLASS LBP674Cdw - Extra Paper Tray
Compact Design
Consider how your device will fit in your workplace.
imageCLASS LBP674Cdw - Dimensions
Get Connected
WiFi® Direct Connection enables easy connection to mobile devices without a router.
imageCLASS LBP674Cdw - Person Printing
Mobile Connectivity
Print on-the-go with Canon PRINT Business, Apple AirPrint® and Mopria® Print Service1.
imageCLASS LBP674Cdw - Printing from Phone
Compatible with Windows, Mac, Chromebook
Main Unit Specifications
Model Name
Model Description
Wireless, Duplex Color Laser Printer
Functions
Print
Print Speed
Up to 35 ppm (Letter)
Document Feeder
No Document Feeder
First Print Out Time
Approx. 7 Seconds (Black / Color, Letter)
Print Resolution
Up to 1200 x 1200 dpi
Print Memory
1 GB (Shared)
Printer Language
UFR II
Network Security
IP/MAC Address Filtering, IPSEC, TLS 1.3, SNMP V3.0, IEEE 802.1X, IPv4/IPv6, SMTP Authentication, POP3
Connectivity
USB 2.0 High‐Speed, 10/100/1000Base‐T/TX Ethernet (Network), Wi‐Fi 802.11b/g/n, Wi‐Fi® Direct Connection
Operating Systems
Windows® 11 / 10 / 8.1 / Windows®Server2012 / 2012 R2 / 2016 / 2019 / 2022, Mac OS X (10.11 or later)
Paper Capacity
250‐Sheet Standard Cassette, 50‐Sheet Multipurpose Tray
Min / Max Paper Size
Standard Cassette 3.9" x 5.8" to 8.5" x 14" / Multipurpose Tray: 3" x 5" to 8.5" x 14"
USB Direct Print
JPG, TIFF, PDF
Display Panel
5 inch, Color Touch LCD
Print Volumes
750 ‐ 4,000 Pages
Energy Consumption
Approx: 1610 W (Max.), 24 W (Standby), 1 W (Sleep Mode)
ENERGY STAR
Yes
EPEAT
Silver
Box Dimensions
21.6" (W) x 17" (D) x 22" (H)
Box Weight
45.5 lbs.
Unit Dimensions
16.8" (W) x 16.9" (D) x 15" (H)
Unit Weight
35.5 lbs.
Reviews
Brochures
File Name
imageCLASS LBP674Cdw Brochure
Date
03.18.25
File Size
3 MB
Color imageCLASS LBP674Cdw Compatible Products
Paper
Paper
Product Disclaimer
  1. Mopria® Print Service, available for free at the Google Play Store, requires a compatible Android 4.4 or later smartphone and tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network. Learn more.
