imagePROGRAF TC-20M
TC-20M
As low as $995.00
Out Of Stock
Estimated ship date
  • Print | Scan | Copy
  • 24" desktop roll & cut sheet printer
  • Copy & enlarge smaller originals
  • Scan to cloud or USB drive
  • 4-Color pigment bottle ink system
  • Ships standard with 280ml of ink
  • ENERGY STAR®, EPEAT Gold
  • Chromebook Compatible
  • 1 Year Warranty
Show more
Return Policy
Overview
24" Large Format Wireless Multifunction Printer
Whatever Your Environment – School, Restaurant, Retail Shop, Home… Canon’s Got You Covered.
Compatible Inks
Features
imagePROGRAF TC-20M Printing
24” Large Format Multifunction Printer
Enlarge or repeat copy directly from a letter / A4 flatbed scanner.
imagePROGRAF TC-20M with USB
USB Flash Drive Port
Easily print in large format by just inserting a USB Flash Drive.
imagePROGRAF TC-20M Person Printing
Cloud Printing & Scanning
Easily print to or scan from the cloud directly from the printer.
imagePROGRAF TC-20M Operating Panel
2.7” Touch Screen LCD Display
Get the job done with an easy to use 2.7” touch screen LCD.
ENLARGE COPY
No Computer Needed
Make enlargements of smaller originals directly from the printer in a few simple steps.
Create. Scan. Print.
Person Holding Poster
Person Using a Marker on a Poster
STEP 1 - Create
Create letter-size originals such as flyers, drawings, diagrams, or handwritten markups.
imagePROGRAF TC-20M Scanning Poster
STEP 2 - Scan
Scan your original on the printer flatbed.
imagePROGRAF TC-20M Printing Scanned Poster
STEP 3 - Print
Super-size it up to 24” poster-size.
Automatic Sheet Feeder
Automatically load up to 100 sheets of letter size paper or up to 50 sheets of 11” x 17” paper for greater print flexibility.
imagePROGRAF TC-20M Person Feeding a Paper to a Printer
Media Handling
From roll-fed to cut-sheet paper, you get the versatility to print 24”-wide output as well as letter, 11” x 17”, and more.
Print More
The imagePROGRAF TC-20M ships with 280 ml of ink – 70 ml per ink bottle – the most in its class!
Ink Bottles on top of Scattered Posters
Easy to Fill
Ink bottles are keyed so they only fit and fill the intended color ink tank. The design helps to create a spill-free process that makes refilling a breeze.
imagePROGRAF TC-20M Ink Being Refilled
Two People on a Laptop Next to imagePROGRAF TC-20M
RESTAURANTS – Unique functions that can benefit your restaurant.
Copy/scan menus and special signs into large poster size for window display or as menu boards placed outside.
Person Holding a Poster
EDUCATION – Unique functions that can benefit the classroom.
Create teaching materials, worksheets, drawings and more, and enlarge them into poster-sized visual aids and classroom masterpieces.
Two People Holding a Poster
RETAIL – Unique functions that can benefit your retail shop.
Enlarge smaller original printed or hand-written flyers to quickly promote clearance sales and new arrival items to help maximize store revenue.
PosterArtist
Easily create posters and flyers from a free, web-based, template-driven poster creation application.
Bring Your Ideas To life
EPEAT® Gold Registered Product
This product is EPEAT® Gold registered in the U.S.A. EPEAT is the world’s premier ecolabel for electronics. EPEAT is owned and operated by the Global Electronics Council® (GEC), a mission-driven non-profit that seeks to create a world with only sustainable electronics. Manufacturers can register products under EPEAT based upon the device’s ability to meet required and optional EPEAT criteria that address impacts across the full product life cycle.
EPEAT Gold Logo
Main Unit Specs
Printer Type
4-Color 24-inch Printer
Printing Technology
FINE: Full-Photolithography Inkjet Nozzle Engineering
Head Configuration
4-Color Integrated Type x 1 print head
Number of Nozzles
Total: 4,352 nozzles(BK 1,280 nozzles, C/M/Y 1,024 nozzles each)
Nozzle Pitch
1200 dpi
Print Resolution (Up to)
2400×1200dpi (Max)
OS Compatibility
Computer Operating Systems:
32-bit: Windows® 7/8.1/10
64-bit: Windows 7/8.1/10/11, Windows Server
2008 R2, 2012, 2012 R2, 2016, 2019, 2022
Mac: mac0S v10.14.6 - macOS v12.x
Print Software
imagePROGRAF Printer Driver for TC-20M Windows/Mac
Apple Air Print
Mopria® Print Service*
Canon PRINT Inkjet/SELPHY
PIXMA Cloud Link
PosterArtist Online
Free Layout Plus
Direct Print Plus
Media Configuration Tool
Quick Utility Toolbox
WiFi Connection Assistant
Printer Update Utility2
Scan Software
Scan Utility Lite
PIXUS/PIXMA Cloud Link
Printer Language
SGRaster
Standard Interfaces
Hi-Speed USB
Wi-Fi® IEEE802.11n/IEEE802.11g/IEEE802.11b
Wired LAN IEEE802.3u (100BASE-TX)/IEEE802.3(10BASE-T)
Ink Capacity
70 ml per color
Ink Types
Pigment Ink
Color Set
Pigment: Black, Cyan, Magenta, Yellow
Scanner Type
Flatbed
Scanning Method
Contact Image Sensors
Maximum Scan Resolution
Up to 2400 x 1200 dpi
Maximum Scan Document Size
A4/Letter
Media Handling
Roll: One Roll, Top-loading, Front Output
Cut Sheet: Automatic Sheet Feeder, Top-loading, Front Output
Media Width
Roll Feed: 12"- 24” (297 mm - 610 mm)
Cut Sheet: 8.3" - 12" (210 mm - 297 mm)
Maximum Print Length
Roll Feed: 13.1’ (4 m)1
Cut Sheet: 17" (432 mm)1
Media Thickness
0.08 mm - 0.28 mm
Media Core Size
2” Core
Maximum Media Roll Diameter
4.3” (110 mm)
Printable Margins
Roll Feed: All Sides - 0.19” (5 mm)
Acoustic Noise
Operation Approx. 41.5dB
35dB or Less Acoustic Power Approx. 6.0 Bels
Power Supply
AC 100–240 V (50-60 Hz)
Power Consumption
Maximum 26W or Less Standby
0.3W or Less Power Off
Operating Environment
Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
Environmental Certifications
ENERGY STAR®, EPEAT GOLD
Physical Dimensions
38.1 x 21.4 x 16 (W x D x H)
Weight
72.8lbs
User-replaceable items
Print Head (PF-08)
Maintenance Cartridge (MC-32)
Ink Tanks (PFI-050)
Reviews
Brochures
File Name
imagePROGRAF TC-20M MFP
Date
04.11.23
File Size
3.2 MB
File Name
Large Format Full Line Brochure
Date
04.30.25
File Size
11.5 MB
imagePROGRAF TC-20M Compatible Products
Ink
Ink
Large Format Printer Accessories
Paper
Other Accessories
Ink
Product Disclaimer
Recycled Paper and Chlorine-free Paper can be used.
*Requires Android mobile device with Android 4.4 operating system or later with the Mopria® Print Service pre-loaded with that device and the compatible imagePROGRAF printer on the same wireless network. Mopria® is also available on Android 4.4 mobile devices with a download of the Mopria® Print Service from Google Play.  Learn more.
  1. The maximum printable length varies, depending on the application, OS, and RIP used.
  2. Internet connection required during software installation.
  3. Optional Canon eCarePAK Extended Service Plan is available to support your needs. For more information, call 1-800-423-2366 or visit our shop.usa.canon.com. Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  4. Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
