CN-R135MM T2.2 L F
CNR135
As low as $3,920.00 Regular Price $4,420.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
  • Native RF Mount & communication on fully manual lens
  • Peripheral illumination, chromatic aberration and distortion correctionFootnote1
  • Dual Pixel Focus GuideFootnote1
  • Full-Frame sensor coverage
  • 8K optical performance with HDR support
  • Fast T-stops deliver shallow, cinematic depth of focus
  • 300-degree Focus Rotation with phosphorescent markings
Show more
Returns Policy
This item is not eligible for return
See Return Policy for complete information.
Overview
The RF Prime series of cinema lenses from Canon has been designed for outstanding optical performance rendering crisp images with natural, rich contrast. This series includes seven lenses, ideal for shooting 8K as well as HDR, and represent Canon’s first cinema lenses to have a native RF mount. This lens series ushers in the RF lens communication to fully manual cinema glass, ideal for shooting with RF-mount cameras including third-party cameras that utilize a native RF mount.
The RF Prime series covers seven focal lengths, with lenses at 14, 20, 24, 35, 50, 85, and 135 millimeters and share a common gear positioning and diameter across all seven lenses. The entire lens series provides for reliable and consistent usability including a smooth focus rotation and sizing, with the same front diameter and rotation across all focal lengths.
Features
RF Mount Cinema Lenses for Professional Productions
Step into cinematic filmmaking with a range of RF Prime lenses that offer ultra-fast, real-time metadata capture plus all-new features such as in-camera electronic distortion correction.
Cinema DSLR Surrounded by CR Lenses
8K Optical Performance with Canon Cinema EOS Color Science
Rated for 8K HDR image capture the lenses produce amazing color rendition and detail, with sharp resolution from the center to the outer edges. An 11-blade iris creates soft, beautiful light rays and stunning depth-of-field falloff. The lenses render the beautiful and warm color tones synonymous with Canon’s cinema lens family.
Canon’s advanced optical technology and lens coatings have combined to achieve 8K optical performance. Various types of aberrations have been corrected to achieve beautiful imagery from the center of the image out to all edges.
All of Canon’s cinema lenses have been designed with a consistent warm color balance that expresses skin tones beautifully, making them ideal for capturing subject textures.  Color reproduction is also consistent when lenses are interchanged, which can help minimize corrections in post.
HDR video offers an expanded tonal range that represents the visual expression close to its natural image.  Our 8K-compatible chromatic aberration correction which can reduce color bleeding, and the light-shielding design and optimized coatings reduce ghosting and flaring.
The inner focus system can reduce focus breathing, giving great stability when framing a shot.
The 11-blade iris gives the lenses a natural bokeh effect that is almost circular from maximum to the minimum aperture.  The odd number of blades diffuse the glow of high luminance subjects for softer imaging.
Model With a White Dress Smiling
Full-Frame Creativity
The RF Prime lenses are designed for Full-Frame, Large-Format cameras, enabling impressive images using bokeh with a shallow depth of field.
CR Lenses Lined Up
Mechanical Precision in a Compact Design
With a smooth and consistent 300-degree focus rotation, consistent gear positions / front diameter and a compact, robust and drip-proof design, the RF prime lenses offer a no-compromise, lightweight solution for professional productions.
CR Lens on a Cinema Camera
Refined ergonomics, redefined handling
Confidently secure your lenses without the need for an adapter when utilizing RF mount Cinema EOS cameras or compatible third-party cameras. With a newly-developed fixed ring design, RF Prime lenses make handheld operation more comfortable, intuitive, and efficient.
Person Using a Cinema Camera with a CR Lens
Distortion Correction
High-speed data transfer makes it possible to instantly transfer lens metadata to the camera, enabling distortion correction according to lens characteristics when shooting video with compatible camerasFootnote2.
Apartment Buildings
Blurry Apartment Buildings
View Full Technical Specs PDF
Specifications
RF Cinema Prime LensCN-R14mm T3.1 L FCN-R20mm T1.5 L FCN-R24mm T1.5 L FCN-R35mm T1.5 L FCN-R50mm T1.3 L FCN-R85mm T1.3 L FCN-R135mm T2.2 L F
MountRF MountRF MountRF MountRF MountRF MountRF MountRF Mount
Focal Length14mm20mm24mm35mm50mm85mm135mm
Max. Relative Aperture
(T-Number)
T3.1T1.5T1.5T1.5T1.3T1.3T2.2
Iris Blades11111111111111
Angle of View
1.5:1, 36x24mm
104.3° × 81.2°84.0° × 61.9°73.7° x 53.1°54.4° × 37.8°39.6° × 27.0°23.9° × 16.1°15.2° × 10.2°
Angle of View
1.78:1, 24.6x13.8mm
82.6° × 52.5°63.2° × 38.1°54.3° × 32.1°38.7° × 22.3°27.6° × 15.7°16.5° × 9.3°10.4° × 5.9°
M.O.D.
(Minimum Object Distance)
0.20m / 8in.0.3m / 12in.0.30m / 12in.0.30m / 12in.0.45m / 18in.0.95m / 3ft. 2in.1.0m / 3ft. 3in.
Object Dimensions at M.O.D
1.5:1, 36x24mm
24.8 × 16.5cm 33.8 × 22.5cm 28.8 × 19.2cm 20.1 x 13.4cm 24.9 x 16.6cm 34.3 x 22.9cm 21.1 x 14.1cm
1.78:1, 24.6x13.8mm
16.9 × 9.5cm23.1 × 13.0cm19.7 x 11.0cm13.7 x 7.7cm17.0 x 9.5cm23.4 x 13.1cm14.4 x 8.1cm
Front Diameter114mm114mm114mm114mm114mm114mm114mm
Filter DiameterN/A105mm105mm105mm105mm105mm105mm
Approx. Size (WxHxL)4.66 x 4.66 x 4.64 in.
(118.4 × 118.4 × 118.0 mm)
4.66 x 4.66 x 4.94 in.
(118.4 × 118.4 × 125.5 mm)
4.66 x 4.66 x 5.49 in.
(118.4 × 118.4 × 139.6mm)
Approx. Weight2.87 lbs
(1.3kg)
3.08 lbs
(1.4kg)
2.87 lbs
(1.3kg)
2.87 lbs
(1.3kg)
2.65 lbs
(1.2kg)
3.3 lbs
(1.5kg)
3.. lbs
(1.5kg)
Informational Documents
File Name
Broadcast & Cinema Lens Catalog - Spring 2026
Date
04.15.26
File Size
44.6 MB
Videos
Product Disclaimer
  1. With compatible cameras
  2. Supported cameras (as of September 2023): EOS C70, EOS R5 C (Movie Mode only)
