Texas LT3 Series
As low as $0.00
Out Of Stock
  • Durable, large format UV printer
  • Linear drive systems and embedded encoders on carriage and bridge for maintenance free, precision movement.
  • X axis accurate across the bridge to 1 micron, Y axis is accurate to 1 micron on both sides of the gantry.
  • TruFire PPS to give the operator complete control.
  • Software aided print head alignment process for easy, accurate alignment.
Show more
Overview
High Productivity, Precision, Quality
The large format UV printing market is continually growing with increasing print volumes but also lower turnaround times and a steadily shrinking workforce that's skilled in large format digital print production. This perfect storm creates a perfect opportunity for print providers to see exceptional value in the Texas LT3 series UV flatbed printers by DigiTech.
The Texas UV flatbed printer series addresses this head-on with a highly productive, stationary flatbed that is capable of up to 7,489 Ft2/hour. The printer can run semi-automated using the auto-unloader feature that transfers the finished print to either a pallet, or onto an integrated conveyor unit feeding to a compatible digital finishing system. Now with just one operator, boards can be loaded on the printer and the finished product quickly and efficiently comes off the cutter ready to be packaged and shipped. Shifting the focus from “boards per hour” to “finished boards per hour.”
Built Smart for Production Environments
DigiTech set out to develop and manufacture a complete print system to be durable and reliable, but also incredibly accurate. The result is the TruFire Precision Print System (PPS) by DigiTech that encompasses a range of design refinements that deliver exceptional dot placement accuracy, reliability and productivity and offers “print on demand” capability all day with minimal maintenance.
Automation-Ready
Fully Automated Print to Cut Production
The Texas LT3 Series now supports a fully automated print-to-cut workflow, boosting productivity by eliminating manual intervention typically required to complete jobs. This streamlined process reduces labor demands while enhancing speed, efficiency, and overall production capabilities.
Key Features of the DigiTech Texas LT3 Series UV Flatbed Printers
  • True, stationary flatbed architecture for a wide range of applications
  • Print substrates up to 5 feet by 10 feet and up to 6 inches thick
  • Auto-unloader transfers printed boards directly to an integrated digital finishing system or pallet’
  • Uninterrupted ink system. No dropouts in any print mode.
  • 3-level grayscale printing with breathtaking quality and efficiency.
  • Efficient, environmentally friendly LED UV lamps and an enhanced ink formulation for expanded color capabilities.
  • The LT3/X2 is available in a two-row 8, 10, or 12 printhead configuration, utilizing CMYK with options of Orange, White, Gray and Varnish.
  • The LT3/X3 is available in a three-row 18 printhead configuration, utilizing CMYK, Orange with option of White, Gray, or Varnish.
  • Hardware and software made in America.
Rigid Media Size Zoned for 4' x 8' and 5' x 10'
Rigid Media Thickness Up to 6.0"
3-Level Greyscale Printhead Technology Staggered, dual-row or three-row Kyocera printheads utilizing 4, 6, 10, and 14 pl drops
Maximum Print Speed 4,376 Ft2/hour (LT3/X2) and 7,489 Ft2 (LT3/X3)
Ink Channels LT3/X2: (2x) CMYK, (2x) CMYK+White or Or, Gray, or Varnish, (2x) CMYK+White and option of Or, Gray, or Varnish LT3/X3 (3x) CMYK+Or, and option of White, Gray, or Varnish.
Resources
File Name
Canon Flatbed Automation From Print to Pallet Brochure
Date
10.06.26
File Size
3 MB
Sort By:
Canon Colorado Feature Innovations
Untitle Video
For GCI Digital Imaging, productivity and cost savings are essential to staying competitive in the grand format printing space. When the Cincinnati, Ohio-based company needed to maximize efficiency across flat stock printing, adhesive vinyl production, and large-format banner printing, it turned to Canon and advanced technologies like the Canon Colorado M-series and the DigiTech Texas LT/X2. Watch this video to see how these innovations helped increase efficiency, boost print speeds, and streamline overall workflow.
