imageFORMULA CR-120N Check Transport
Discontinued
- Compact design - perfect for areas with limited workspace
- Direct network connectivity interface
- Scans up to 120 checks per minute
- Magnetic Ink Character Recognition (MICR)
- Optical Character Recognition (OCR)
- Both physical and virtual endorsement, and imprinter, capabilities included
- EPEAT silver
- Backed by a one-year warranty
- Country of Origin: Japan
- TAA Compliant Device
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Overview
Enhance traditional check processing with the easy-to-operate, compact Canon imageFORMULA CR-120N check transport. With high-speed, high-quality, precise processing capabilities plus reliable item handling and now with direct network connectivity interface, the CR-120N check transport can help promote adaptability and productivity for financial applications.
WIDE RANGE OF USES
The CR-120N check transport can help assist in moving paper checks and related documents in front-counter teller settings, merchant/remote deposit capture (RDC) applications, and remittance processing, as well as higher-volume tasks such as back-office/branch settings, and lockbox applications. It enables users—in environments such as banks, credit unions, and retail—to improve their point-of-presentment applications by helping to automate funds deposits for quicker transaction times, decrease errors and fraud, improve customer service, and lower capital and processing costs.
RELIABLE ITEM HANDLING
Scanning up to 120 items per minute* with a 150-item Automatic Document Feeder (ADF), the CR-120N check transport can perform high-speed scanning for a wide range of document types, such as business and personal checks. It also includes a built-in ultrasonic sensor to help prevent misfeeds. To handle these, the cover of the CR-120N check transport can be opened, which also allows users access to the scanning glass and feed rollers for routine maintenance.
SIMPLE, COMPACT DESIGN
Optimal for teller counters and merchant desks, the CR-120N check transport’s small footprint can fit comfortably on countertops with limited workspace. The scanner is designed for easy use and has multifunction compatibility, combining the functions of many peripherals found at the teller station into one single device, thereby reducing counter space requirements and helping to improve efficiency.
ROBUST, SCALABLE FEATURES
The CR-120N check transport is equipped with features for efficient check processing. To help meet strict audit regulations, the built-in, five-line imprinter prints and captures endorsement information on checks. The CR-120N check transport is also modular and scalable, with functionality that can be added as required. With a dedicated card-scanner, users can scan plastic or embossed cards. The CR-120N check transport also supports the most commonly used check scanning software, including the industry standard, Ranger Transport API. For network capability, the CR-120N contains an Ethernet port to allow the use of the scanner from other computers connected to the network.
PRECISE IMAGE CAPTURE
To deliver high image quality, the CR-120N check transport is equipped with image processing features such as Fine Text Filtering to allow for sharper image capture with less distortion, delivering better Optical Character Recognition (OCR) accuracy. Magnetic Optical Character Recognition (MOCR) is also used, combining Magnetic Ink Character Recognition (MICR) reading with OCR processing to capture accurate MICR data. These capabilities ensure high read rates that mitigate risks associated with digitizing checks.
ENVIRONMENT IN MIND
The CR-120N check transport is ENERGY STAR® certified and complies with both the EU RoHS and WEEE directives for the reduction of hazardous substances and waste products. CR-120N is EPEAT Silver.
CUSTOMER CARE
For investment protection, eCarePAK options are available to extend service beyond the initial one-year advanced exchange warranty period. This helps to save on costs associated with post-purchasing maintenance and maximize uptime throughout the product life.
DEVELOPMENT AND CUSTOMIZATION
The CR Software Development Kit (CR-SDK) is available for those who wish to create applications that take advantage of the CR-120N scanner‘s array of additional capabilities. These include an advanced imprint function, an add-on function that enables printing on images only, an image quality assurance (IQA) function that checks image quality, and the ability to control applications using the buttons on the machine. An application can also be developed for the .net environment.
Main Unit Specs
Length: 3.5" - 9.6"
Brochures
imageFORMULA CR-120N Check Transport Compatible Products
Product Disclaimer
- Examples based on typical settings, rated in checks per minute with 6 long U.S. personal checks at 200 dpi in black and white or grayscale.
- The facts and product statistics about EU RoHS and WEE were obtained from Canon Electronics Inc. as of 2017.
- In order to be eligible for the CR SDK, Canon U.S.A., Inc. must approve.
