Canon IVY Mini Photo Printer
PV-123 MG
As low as
$79.99
Regular Price
$129.99
In Stock
$50 Instant Savings
- Print and customize your photos directly from your smartphone or tablet via the Canon Mini Print App.1
- No ink needed! The IVY Mini Photo Printer uses ZINK™ (Zero Ink) technology, which features colorful dye-based crystals embedded inside the paper.
- Don’t worry about finger prints! ZINK Photo Paper is durable and smudge-free.
- Place your photos anywhere, thanks to a Peel & Stick backing that adheres to your favorite surfaces.
- Use Tile Print to craft a larger version of your image by printing up to 9 tiled sections.
Need to order more than 10?
Learn More
Need help making a purchase? Contact a Sales Expert at 800-385-2155>
Return Policy
View Full Technical Specs PDF
Techs. Specs. Detailed PDF
Main Unit Spec
Printer
Printer - General
Other Features
2 LED light system
Bottom LED (Charging): Red: Charging , Green: Charging Complete
Power LED (Status): White: Power On, White flashing: Printing /Processing /Cooling, Red flashing: No Paper/Low Battery/Other Error Battery Information
Battery Type: Rechargeable Lithium-ion (2 cell, 7.4V, 500mAh)
Battery Life: 20 Sheets per Charge (approx.)
Battery Charge Time: Full Charge in Approx. 90 Minutes (Measured at 5V/1A charging speed)
OS Compatibility
Compatible OS
1
iOS®: 9.0 or later
Android™: 4.4 or later Mobile APP 1
Canon Mini Photo Print App 1
iOS®: 9.0 or later
Standard Interface
Bluetooth™ 4.0
1
Operating Temperature:
59 - 89.6°F (15 - 32°C)
Storage Temperature:
Zink Photo Paper Storage Environment: 34 - 77°F (1 -25°C)
Operating Humidity:
Up to 40-50% Relative Humidity
Storage Humidity:
40 - 55% Relative Humidity
Warranty
1-Year Limited Warranty with InstantExchange Program. 1-Year toll-free 100% U.S.-based technical phone support.
3
Certification
Battery Charging (BC) Systems - California Energy Commission (CEC) Compliant
ZINK Photo Paper Information
2"x3" Photo Paper Size
Peel-and-Stick Back
Smudge Free
Tear Resistant
Peel-and-Stick Back
Smudge Free
Tear Resistant
Printing Method
ZINK™ - "Zero Ink"
Print Speed (up to)
50 Seconds or less
2
Print Resolution (Up to)
314 x 400 dpi
Borderless Printing
Yes
Connectivity
Bluetooth 4.0
Printer Connection
Bluetooth - using the Canon Mini Print app
Automatic Paper Sensor
Yes
Battery
Built-in Rechargeable Lithium-ion
Display
2 LED Light System
Control Panel
Power Button
Memory
64 MB
Wi-Fi Capable
No
Memory Card Compatible
No
Supported Media Type
ZINK Photo Paper
Paper Sizes
2.0" x 3.0"
Paper Capacity
Up to 10 Sheets of ZINK™ Photo Paper & 1 SMART SHEET™
Paper Compatibility
ZINK™ Photo Paper
Reviews
Product Disclaimer
SPECIFICATIONS ARE SUBJECT TO CHANGE WITHOUT NOTICE. ALL VIEWSCREEN AND OUTPUT IMAGES ARE SIMULATED.
- Requires mobile device to be connected to the Canon IVY Mini Photo Printer via Bluetooth® and the Canon Mini Print App, available for free on the App Store and at Google Play. Compatible with mobile devices running iOS 9.0 or later, and Android devices running Android 4.4 or later.
- Depending on operating temperature.
- Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
