Out Of Stock
CE7000-60+SW
CE7000-60+SW
As low as $0.00
Out Of Stock
  • Datalink Barcode: save time and reduce the chance of production errors by using barcodes to automatically process multiple jobs at the touch of a button.
  • Contour Cut: separate tool positions ensure the longevity of your blades and cutting strip when creating decals and graphics that are effortlessly popped out of sheet and roll media.
  • Arms 8.0: a new and improved Advanced Registration Mark Sensing System can easily generate barcodes as part of the design, creating a hands-free operation.
  • Network Connection: now possible through a network interface enabling the use of TCP/IP protocols to transfer cut data.
New
Return Policy
24" Graphtec Cutter and Colorbyte Software Bundle
Configuration
Grit roller with digital servo drive system
Maximum cutting area (W x L)
24" x 164'
Cutting area of guaranteed accuracy (W x L) (when using the basket)
23" x 79"
Mountable media width
2" and 28"
Number of push rollers
2 rollers
Maximum cutting speed
36"/s, at 45º direction
Maximum acceleration
69.6' (21.2 m/s2), at 45º direction
Maximum cutting force
4.41 N (450 gf) in 38 steps
Minimum character size
Approx. 5 mm (0.016") alphanumeric (varies depending on character font and type of media)
Programmable resolution
GP-GL: 0.1 / 0.05 / 0.025 / 0.01 mm, HP-GL™: 0.025 mm
Repeat-ability
Max. 0.1 mm in plot up to 2 m (*1)
Mountable number of tools
1 tool
Blade type
Supersteel
Pen type
Oil-based ballpoint, Water-based fiber-tip pen
Media type
Self-adhesive marking film (vinyl, fluorescent, reflective) excluding high-intensity reflective film, up to 25 mil (.63mm) cutting Graphtec Rhinestone Stencil material GRS1510-m
Interface
USB 2.0 (Full Speed), Ethernet 10BASE-T/100BASE-TX
Buffer memory
2 MB
Command sets
GP-GL / HP-GL™ (Set by command or auto-detect)
Display
Graphic type LCD with back-light (240dots x 128dots), supports 10 languages
Registration mark sensing system
Marks are scanned by an optical sensor (ARMS8.0), Segment area and Multiple marks compensation, 4-points axis alignment, Auto mark detect
Alignment accuracy
Maximum 0.3 mm with printed image (when reading registration marks specified by this machine)
Power source
100 to 120, 200 to 240 V AC (Auto switch), 50 / 60 Hz
Power consumption
120 VA
Operating environment
10 to 35 ºC, 35 to 75 % R.H. (non-condensing)
Guaranteed accuracy environment
16 to 32 ºC, 35 to 70 % R.H. (non-condensing)
External dimensions (W x D x H)
Approx. 39.6" x 23" x 43"
(with Basket): (39.6" x 36.9" x 43")
Weight (Approx.)
51 lbs (23 kg)
(with Basket): 55.6 lbs (25.2 kg)
Compatible OS (*2)
Windows 10 / 8.1 / 7
Mac OSX 10.6 - 10.11 - 10.12 - 10.15
Included software
Cutting Master 4, Graphtec Pro Studio (for Windows), Graphtec Studio (for Mac), Windows driver
Compatibility Standards
Safety: PSE, UL/cUL, CE mark
EMC: VCCI Class A, FCC Class A, CE mark
