CINE-SERVO 15-120mm T2.95-3.95 PL
CN8X15PL
As low as $33,770.00
Out Of Stock
  • 8K, 4K, HDR
  • Super 35mm and Full Frame Sensor Coverage
  • EF/PL Mount
  • 11 Iris Blades
  • 15-120mm focal length (22.5-180mm with Extender)
  • Enhanced Servo drive unit (Removable)
  • Focus, Zoom, and Iris dials
Show more
Overview
Outstanding Optical Performance
The CINE-SERVO 15-120mm T2.95-3.95 lens is HDR compatible, and represents the very latest in Canon’s optical design. It achieves 8K optical performance throughout its entire zoom range, with 8K-compatible chromatic aberration correction and optimized coatings, reducing ghosting and flares inside the lens. As with all Canon Cinema EOS zoom lenses, the CINE-SERVO 15-120mm T2.95-3.95 has a consistent warm-color balance to beautifully render skin tones and textures, reduced focus breathing and an 11-blade iris that produces a creamy natural bokeh.
CINE-SERVO 15-120mm T2.95-3.95 PL Cinema Lens 3 Quarter View
Outstanding Quality, Outstanding Clarity
Capture your subject in exquisite edge-to-edge detail in combination with Super 35mm or Full-Frame Cameras while an 11-blade iris produces beautiful specular highlights with cinematic depth-of-field.
Bokeh Example with Girl in White Dress
Wide-angle with Extra Reach
The CINE-SERVO 15-120mm T2.95-3.95 is Canon’s widest CINE-SERVO lens, ideal for live events and creative productions. With a built-in 1.5x Extender, full frame sensor cameras achieve edge-to-edge coverage for large format productions.
Advanced Communication & Efficiency
The PL mount lens supports Cooke /i Technology™ and ZEISS eXtended Data™ communication.
PL Mount
Integrate into Virtual Systems
With two 20-pin connectors reserved for zoom and focus control, a third 20-pin connector on the lens’s drive unit provides 16-bit encoded data for positional information and outputs Cooke /i Technology™ and ZEISS eXtended Data™ (PL Mount only) for use in virtual studios and VR applications.
Lens Connectors
Cinema EOS Color Science
All Cinema EOS lenses have Canon’s renowned color science in their DNA and deliver warm, pleasing skin tones with accurate and consistent color from lens center to edge.
Robust, Reliable & Built to Perform
Remove the drive unit to operate the CINE-SERVO 15-120mm T2.95-3.95 like a traditional cinema lens. With a front diameter of 114mm, the CINE-SERVO 15-120mm T2.95-3.95 can use industry-standard accessories such as matte boxes and follow focus units. The focus ring sports 0.8 and 0.5 pitch gears with clear-to-read markings and engravings.
Gear Pitch demonstration
View Full Technical Specs PDF
Main Unit Specs
Informational Documents
File Name
Broadcast & Cinema Lens Catalog - Spring 2026
Date
04.15.26
File Size
44.6 MB
CINE-SERVO 15-120mm T2.95-3.95 PL Compatible Products
Adapters, Chargers & Couplers Stations
