CINE-SERVO 50-1000mm T5.0-8.9 PL
- Ultra Telephoto 50-1000mm (75-1500mm with Built-In 1.5x Extender)
- Amazingly High Zoom Ratio of 20x
- 4K Optical Performance Throughout the 20x Zoom Range or Even When the 1.5x Extender is Used
- Designed for Super35mm Large-Format Single-Sensor Cameras (Dia. 31.4mm)
- Designed for Both Cinema Style and Broadcast Applications
- 11-Blade Iris for Natural Out of Focus Background
Return Policy
Overview
The Canon CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens provides 4K performance for Super35mm large-format single-sensor cameras and accommodates either broadcast or cinema-style production due to its removable Digital Drive unit. Available in EF- or PL- mount versions, the lens, with a 75-1500mm focal length with the built-in 1.5x extender and 20x magnification, is great for sports, nature documentaries and other types of long-zoom field production. Yet it's easy to carry, has a relatively compact form factor of only 15.9 inches in length, and a weight of just 14.6 lbs. It can be used with major brands of single-sensor Super35mm cameras and conforms to industry-standard camera-to-lens communication protocols including 12-pin serial communication (common to major broadcast camera brands) and Cooke's /i Technology.
The CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens allows for the close-up 4K imaging of wildlife subjects while still maintaining the physical distances necessary in such shooting situations. Ruggedly built, its removable Digital Drive unit allows for broadcast-style operation with a convenient zoom/rocker switch, programmable zoom and focus settings, and data connections for use with broadcast-type field/studio zoom and focus servo-demand controls. Removal of the Drive unit enables Cinema-style operation; the lens includes clearly engraved barrel markings, an 11-blade iris to help achieve smooth "bokeh" backgrounds, and compatibility with lens-support rods, matte boxes, and other cinema accessories.
Converting the lens to an EF-mount version can be handled by authorized Canon service facility.
Features
The CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens delivers the long focal length performance demanded by today's users of single-sensor large-format cameras for broadcast sports, nature cinematography, and digital filmmaking. With a long focal length (57-1500mm with the built-in extender engaged) and 20x optical magnification, the CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens offers new creative opportunities possibilities for today's growing community of 4K, UHD, and HD image makers.
The CINE-SERVO 50-1000mm lens' 20:1 zoom range extends from a wide 50mm to 1000mm on the telephoto end. The increased use of single-sensor large-format (super 35mm) cameras for such broadcast applications as sports may require an even longer focal range, so this lens also features a built-in 1.5x extender, lengthening its focal length to 75-1500mm. New creative opportunities include enabling single-sensor large-format camera users to obtain close-up 4K imaging of wildlife subjects or sports players while still maintaining the physical distances necessary in such shooting situations.
The CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens is the product of years of Canon expertise in such areas as large-diameter aspherical lens technology, optical layout optimization, and the latest optical simulation technologies. Developed using Canon's leading-edge optical and optomechanical design tools and advanced glass materials, the CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens corrects nearly all optical aberrations, and delivers high image quality that extends from the image center to all edges. The result is the maintenance of superb 4K optical imaging performance throughout its 20x zoom range, and even when the lens built-in 1.5x extender is employed.
The CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens perfectly covers a 31.4mm image format and delivers this amazing 4K optical performance across its entire zooming range, which ranges from 75mm to 1500mm with its built-in 1.5x extender. The minimum object distance (MOD) of the lens is 11.5 ft. (3.5 m); the lens front diameter is 136mm.
Designed for Both Cinema and Broadcast Applications
The CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens features a removable Digital Drive unit to accommodate either broadcast or cinema-style production. The Drive unit integrates a convenient zoom/rocker switch, programmable zoom and focus settings, and a 12-pin connector that carries standard broadcast lens serial communication. Compatible cameras can supply power to the Drive unit via this connection and support remote iris operation. Three 20-pin connectors on the Drive unit enable the zoom, focus and iris to be remotely controlled by using broadcast type servo-demand controls. The 20-pin connectors also output 16-bit precision data that enables the lens to be used with virtual studio systems. Removal of the Drive unit enables traditional full manual cinema-style operation, and the lens also features clearly engraved barrel markings, an 11-blade iris to help achieve smooth bokeh and gearing that is fully compatible with lens-support rods, matte boxes, and other cinema accessories.
The manual focus control of the lens has a total rotation angle of 180 degrees. If the Drive unit is removed for a specific production and then re-mounted, it can be done in any rotation position and there is no need to adjust gear positions (zoom, iris, and focus).
Although it's an extremely high-performance lens, the CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens weighs only 14.6 lbs. (6.6kg) and has an overall length of only 15.9 inches (405.2mm) a carryable combination that can readily support portable documentary and sports shooting.
11-blade Iris
The odd number of iris blades within the CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens provides a softer image by suppressing reflection of opposing beams of light. This 11-bladed iris is designed to enable cinematographers to achieve smooth "bokeh" effects that exploit the beauty of the shallow depth of field that can be captured with today’s large-format (super 35mm) single-sensor cameras.
Enhanced Servo Drive Unit with Various User Setting Capabilities
The removable Digital Drive unit on the CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens is ergonomically designed for operator comfort and integrates a newly developed encoder that provides users with immediate start-up and control of the lens. The Drive unit includes a convenient zoom/rocker switch that enables camera operators to smoothly zoom at a variety of speeds, from a very fast 1.5 seconds to a very slow 180 seconds from full-wide to full-telephoto. The Drive unit also includes a compact LCD display that enables camera operators to easily access other lens functions, including fully programmable zoom, iris, and focus position/speed settings. The Drive unit's encoder technology is also capable of relaying accurate analog and serial data for zoom, focus and iris settings through a 20-pin connector, allowing for the lens to be incorporated into most existing virtual imaging systems.
Multiple Communication Capability with Compatible Cameras
The CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens is compliant with industry-standard camera-to-lens communication protocols to help ensure compatibility and maximum performance with multiple brands and models of 4K, UHD, and HD cameras. These standards include 12-pin serial communication (common to major broadcast camera brands), Cooke's /i Technology, and Canon EOS-LENS data communication technology (employed by several Canon Cinema EOS cinema cameras). Specific types of data-management functions involving focus, zoom, iris and other settings can vary, depending on camera brands and models. In the case of the Canon Cinema EOS system, precise lens data including aperture setting is displayed in the EOS camera's viewfinder, as well as recorded in the video file as metadata along with the model name of the lens and the given focal-length setting.
For broadcast-style use, a 12-pin connector on the Digital Drive unit of the CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens carries the standard serial communication for broadcast lenses. Broadcast cameras can also supply power to the Drive unit for support of remote iris operation via this connection.
16-Bit Precise Metadata Output for Virtual Studio Systems
The removable Digital Drive unit on the CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens integrates a 16-bit high-resolution encoder that generates precise positional data zoom, iris, and focus on all lens settings. This highly accurate lens data can be relayed via any of the Drive unit's three 20-pin connectors, allowing for the lens to be incorporated into most existing virtual imaging systems.
High Durability and Ruggedness
The entire lens employs a tough, optimal chassis structure, is weather and shock resistant, and features the environmental-performance capabilities needed to stand up to typically unforgiving broadcast sports and wildlife shooting environments. Sturdiness, durability, weather-proofing, integrity of lens element mountings, and mechanical strategies all help ensure maintenance of optical precision over wide environmental ranges.
Available in PL or EF Mount, or Can be Swapped at an Authorized Service Facility
The CINE-SERVO 50-1000mm T5.0-8.9 ultra-telephoto zoom lens is available in either PL or EF mount. The PL mount version is model number CN20x50 IAS H/P1; the EF mount version is CN20x50 IAS H/E1. The mounts are interchangeable at an authorized Canon Service facility.
Main Unit Spec
Informational Documents
Broadcast & Cinema Lens Catalog - Spring 2026
04.15.26
44.6 MB
