CJ20ex5B IASE T
As low as $0.00
Out Of Stock
  • UHDxs lens delivers Canon's highest optical performance
  • 4K Optical Performance and Improved HD Imaging
  • 5.0mm Wide Angle with Powerful 20x Zoom
  • Built-in 2x Extender increases the maximum zoom range to 200mm
  • Compact, Lightweight and Ergonomic Design
  • BT.2020 and HDR/WCG Support
  • New e-Xs V Drive Unit with Angled 20-pin, USB-C Connector and Improved Menu Functions
Show more
Overview
Canon's CJ20ex5B is Part of Our 4K UHDxs Family of Broadcast Lenses
The UHDxs series provides outstanding optical performance, including sharp resolution from image center to edge and minimized chromatic aberration in virtually any shooting condition. The CJ20ex5B has a wide-angle focal length of 5 mm and 20x zoom, a versatile focal length that offers broadcasters several shooting options. In addition to enhanced operability and durability, this portable lens delivers 4K UHD optical performance in a light and compact body.
cj20ex5b 3q angle
Features
With a wide-angle focal length of 5 mm and powerful 20x zoom, the CJ20ex5B can deliver a beautiful panoramic image, as well as tight shots with amazing detail, making it a great fit for a wide variety of applications including television news, sports (especially computer-controlled, stabilized, cable-suspended camera systems above stadiums), and studio shooting.
20x Optical Zoom Lens
Surfer Surfing with a Friend
Wide
Tele
4K Optical Performance and HDR Imaging Quality
HDR images offer excellent gradation representation and enhanced realism and dimension, including texture, for image representation close to the real thing.
Canon's 4K UHDxs lenses deliver the advanced optical performance that Canon considers essential for a 4K+HDR system lens, helping to enable shooting of more realistic and immersive images.
Outstanding Optical Performance Designed for 4K+HDR Shooting
Person Sitting on a Couch - Zooming in on a Lamp
Chromatic aberration along contours with high-luminance subjects
Lens not optimized for HDR
Emphasized outlines cause color bleeding
CJ20ex5B
Canyon Being Zoomed In
Flare in low-illumination areas
CJ20ex5B
UHDxs Lenses Deliver Canon's Highest Optical Performance
UHDxs lenses provide our highest optical performance as they exhibit higher sharpness and lower chromatic aberrations relative to other broadcast lenses.
profile view of the cj20ex5b
The portable CJ20ex5B  lens features correction data that supports BT.2020, which offers a wider color gamut than the conventional BT.709 broadcasting standard. This enables excellent color reproduction from edge-to-edge when attached to a 4K camera. Like the other UHDxs series lenses, the CJ20ex5B provides optimized chromatic aberration correction based on BT.2020 correction data, helping to enable more lifelike high-resolution video shooting with outstanding tonality and realistic texture and depth.
① BT.2020 (4K/8K Broadcast)
② BT.709
BT.2020 Chart
Zooming in on a Window
HD Lens
BT.709 - Correction data installed
4K Camera
BT.2020 - Based 4K camera chromatic aberration correction function
4K Lens
BT.2020 - Correction data installed
4K Camera
Despite its impressive 5.0-100mm focal range, the lens weighs in at only 5.07 lbs. The portable CJ20ex5B 4K UHDxs lens is similar in size to Canon's other 2/3" HD lenses, while delivering 4K UHD performance and offering the mobility demanded in the reporting and documentary fields.
The lens grip allows the center of gravity to be close to the mount, lessening strain on the hands and elbows of the camera operator. The ergonomic grip design allows for a comfortable feel during operation, helping to reduce fatigue and making it easy to move the camera about. The lens is sure to satisfy with its impressive combination of robust specifications, enhanced optical performance, and usability.
illustration of camera operator holding lens
Built-in 2x Extender Increases the Maximum Zoom Range to 200mm
The built-in 2x extender expands the lens to an impressive 200mm on the telephoto end, while maintaining 4K UHD optical performance throughout the entire range.
front of the cj20ex5b
Compatibility with Existing Canon Focus and Zoom Demands and Accessories
The CJ20ex5B IASE T allows for full-servo zoom and focus control and is compatible with Canon's broadcast focus and zoom demands. It allows for the use of zoom and focus control accessories (such as the ZDJ-G01 and FDJ-G01).
With an angled 20-pin connector and a built-in USB-C connector, the e-Xs V gives users a better experience with equipment setup and maintenance and improves operability with an updated display menu.
  • Angled 20-Pin Connector - Allows the camera to be placed on a flat surface with a 20-pin cable connected.
CJ27ex7.3B IASE T - Left View
  • New USB-C Port - Allows Drive Unit settings to be saved and loaded into other lenses. End users would be able to update firmware and can record and save maintenance history.
CJ27ex7.3B IASE T - USB Port View
  • New Information Display - Conveniently located on the top of the drive unit​ with a simplified menu.
  • Focus Breathing Compensation - A feature which minimizes image distortion when racking focus. This setting can easily be turned on or off depending on preference.
  • Ergonomic Design - Designed to reduce arm fatigue.
  • Improved Servo Control - Faster iris speed.
CJ27ex7.3B IASE T - Top View
Remote and Virtual Support
The high-resolution, 16-bit absolute value encoder enables high-precision location detection, making calibration easier when creating virtual content. The 20-Pin connector can be switched to a virtual terminal to output zoom, focus, and iris position information.
CJ27ex7.3B IASE T - Strap View
Virtual Output
Soccer Field
12-pin Serial Communication
The CJ20’s serial connection with a remote control-compatible camera transmits focus, zoom, and iris position information and allows remote control of the camera.
Supports ARIAFootnote1 Camera Feature
ARIA (Automatic Restoration of Illumination Attenuation) adjusts illumination so that light is more evenly distributed between the wide and the telephoto ends of the lens. First, the Camera-lens communication at initialization identifies the lens attached. When zooming, the camera’s gain is increased starting at the F-drop/ramping point. Simultaneously, Peripheral Illumination Correction corrects light fall-off from the center of the frame to the periphery, This correction more evenly distributes light throughout the entire image.
Friends on the Back of a Truck
ARIA OFF - Wide End
ARIA OFF - When zoomed in, the whole image is darker, especially the edges
ARIA ON - Correction makes light more even throughout image
Main Unit Spec
Informational Documents
File Name
Broadcast & Cinema Lens Catalog - Spring 2026
Date
04.15.26
File Size
44.6 MB
CJ20ex5B IASE T Compatible Products
Controllers
Controllers
Product Disclaimer
  1. Sony ARIA is a camera function established by Sony, and the ARIA name was determined by Sony.
