CN-R14MM T3.1 L F
CNR14
As low as $3,820.00 Regular Price $4,220.00
In Stock
  • Native RF Mount & communication on fully manual lens
  • Peripheral illumination, chromatic aberration and distortion correction*
  • Dual Pixel Focus Guide*
  • Full-Frame sensor coverage
  • 8K optical performance with HDR support
  • Fast T-stops deliver shallow, cinematic depth of focus
  • 300-degree Focus Rotation with phosphorescent markings
Return Policy
View Full Technical Specs PDF
Specifications
RF Cinema Prime LensCN-R14mm T3.1 L FCN-R20mm T1.5 L FCN-R24mm T1.5 L FCN-R35mm T1.5 L FCN-R50mm T1.3 L FCN-R85mm T1.3 L FCN-R135mm T2.2 L F
MountRF MountRF MountRF MountRF MountRF MountRF MountRF Mount
Focal Length14mm20mm24mm35mm50mm85mm135mm
Max. Relative Aperture
(T-Number)
T3.1T1.5T1.5T1.5T1.3T1.3T2.2
Iris Blades11111111111111
Angle of View
1.5:1, 36x24mm
104.3° × 81.2°84.0° × 61.9°73.7° x 53.1°54.4° × 37.8°39.6° × 27.0°23.9° × 16.1°15.2° × 10.2°
Angle of View
1.78:1, 24.6x13.8mm
82.6° × 52.5°63.2° × 38.1°54.3° × 32.1°38.7° × 22.3°27.6° × 15.7°16.5° × 9.3°10.4° × 5.9°
M.O.D.
(Minimum Object Distance)
0.20m / 8in.0.3m / 12in.0.30m / 12in.0.30m / 12in.0.45m / 18in.0.95m / 3ft. 2in.1.0m / 3ft. 3in.
Object Dimensions at M.O.D
1.5:1, 36x24mm
24.8 × 16.5cm 33.8 × 22.5cm 28.8 × 19.2cm 20.1 x 13.4cm 24.9 x 16.6cm 34.3 x 22.9cm 21.1 x 14.1cm
1.78:1, 24.6x13.8mm
16.9 × 9.5cm23.1 × 13.0cm19.7 x 11.0cm13.7 x 7.7cm17.0 x 9.5cm23.4 x 13.1cm14.4 x 8.1cm
Front Diameter114mm114mm114mm114mm114mm114mm114mm
Filter DiameterN/A105mm105mm105mm105mm105mm105mm
Approx. Size (WxHxL)4.66 x 4.66 x 4.64 in.
(118.4 × 118.4 × 118.0 mm)
4.66 x 4.66 x 4.94 in.
(118.4 × 118.4 × 125.5 mm)
4.66 x 4.66 x 5.49 in.
(118.4 × 118.4 × 139.6mm)
Approx. Weight2.87 lbs
(1.3kg)
3.08 lbs
(1.4kg)
2.87 lbs
(1.3kg)
2.87 lbs
(1.3kg)
2.65 lbs
(1.2kg)
3.3 lbs
(1.5kg)
3.. lbs
(1.5kg)
Product Disclaimer
*With compatible cameras
