Color imageCLASS LBP712Cdn
IC LBP712CDN
As low as $899.00
Out Of Stock
  • Color
  • Compact
  • User-Friendly
  • Print up to 40/40 (BW/Color)
  • Print up to 8-1/2" x 14"
  • 2,300-sheet maximum paper capacity
Show more
Main Unit Spec
Printer Specifications
Printer Type
Color Laser Single Function Printer
Print Speed
Up to 40 ppm (Color/BW: 1 and 2-sided, plain paper letter)1
First Print Time
6 seconds or less (letter)2
Printer Language
UFR II, PCL 5c/e, PCL6, Adobe® PostScript®
Print Resolution
600 x 600 dpi, 9,600 equivalent x 600 dpi
Maximum Print Size
Up to Legal (multipurpose tray)
Duplex Print
Yes
Print Modes
Watermark, Page Composer, Toner Saver, Poster, Booklet, Collate
Print Memory
1 GB
Direct Print from USB
Print File format: JPEG, TIFF, PDF, XPS
Paper Handling Specifications
Standard Paper Source(s)
Standard Cassette: 550-sheet; 16 to 43 lb. bond (plain paper); Letter, A4, A5, B5, Statement, Executive (Min: 4 x 5.8 / Max: 8.5 x 11.7)3
Multipurpose Tray: 100-sheet; 16 to 57 lb. bond (plain paper); Letter, Legal, A4, A5, B5, Statement, Executive (Min: 3 x 5 / Max: 8.5 x 14)3
Optional Paper Source(s)
550-sheet cassette; 16 to 43 lb. bond (plain paper); Letter, Legal, A4, A5, B5, Statement, Executive (Min: 4 x 5.8 / Max: 8.5 x 14)3
Document Feeder
NA
Paper Output
Approx. 200 sheets (face down)
Media Types
Thin paper, Plain paper, Recycled paper, Thick paper, Colored paper, Label, Post card, Envelope, Rough paper
Envelope Capacity
10
Envelope Types
Com 10, Monarch, C5, DL
Connectivity and Software Specifications
Standard Interface(s)
USB Device High-Speed 2.0, Shared 10/100/1000 BASE-T Ethernet (Network)
USB Functions
Print
Mobile Functions
Canon PRINT Business4, Apple® AirPrint®5, Mopria™ Print Service6
Web Browser Support for Remote UI
Microsoft Internet Explorer 7.0 or later
Supported Network Protocols
SNMPv1, SNMPv3 (IPv4,IPv6)
TCP/IP Set of Application Services
Bonjour(mDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6), DDNS
OS Compatibility
Windows® 10, 8.1, 8, 7, Vista®, Windows Server® 2012 R2, 2012, 2008 R2, 2008, 2003 R2, 2003, Mac® OS10.6.8 & up
Cable Included
Power Cord (USB not included)
Environmental Specifications
Power Consumption
During Operation: 600 W or less,
Standby: 33 W or less,
Energy Saver: 2.2 W or less (USB) / 1.2 W or less (wired)
Typical Energy Consumption
0.48 kwh
General Specifications
Dimensions
18.1" (W) x 18.3" (D) x 15.3" (H)*
For full configuration options and dimensions, please refer to this document.
Unit Weight (without/with cartridge)
54.7 lbs. (w/o cartridge), 62.7 lbs. (w/ cartridges)
Package Weight
Approx. 77.2 lbs.
Cartridge Type
Cartridge 040 Black (yields approximately 6,300 pages), CMY (yields approximately 5,400 pages) / Cartridge 040 Hi-Capacity Black (yields approximately 12,500 pages), Hi-Capacity CMY (yields approximately 10,000 pages) *Yields based on ISO/IEC Standard
LCD Display
5 Line LCD Panel
Duty Cycle
Up to 80,000 pages per month (RMPV (Recommended Monthly Print Volume): 1,000 - 7,000 pages)
Security
SNMPv3, IP / MAC address filtering, HTTPS/IPPS, IEEE802.1x (wired LAN)
Warranty
1 Year Onsite Service (Extended warranty available)7
N/A8
EPEAT Silver Rating, Energy Star Rated
What Comes in the Box: LBP712Cdn Product, Standard Cartridge 040, Power Cord (USB not included), Starter Guide, User Software DVD-ROM, Warranty Card, Canon Drivers
*Configuration and Dimensions
LBP712Cdn Only: 18.1" (W) x 18.3" (D) x 15.3" (H)
LBP712Cdn + 1 Optional Cassette: 18.1" (W) x 18.3" (D) x 20.5" (H)
LBP712Cdn + 2 Optional Cassettes: 18.1" (W) x 18.3" (D) x 25.7" (H)
LBP712Cdn + 3 Optional Cassettes: 18.1" (W) x 18.3" (D) x 30.9" (H)
Color imageCLASS LBP712Cdn Compatible Products
Rollers, Feeders & Cassettes
Product Disclaimer
1. Copy/print speeds are measured based on internal testing using letter size paper copied/printed with 100% copy/print ratio to original on one-sided paper. Internal testing involved continuously copying/printing the same one page of content on plain paper (copy speed is tested by copying on the platen glass). Copy/print speeds may vary depending on paper type, paper size or paper feeding direction. The device may automatically pause or slow down in order to adjust printer condition such as controlling temperature of a certain unit or limiting impact to image quality during continuous copying/printing.
2. May vary depending on the output environment.
3. Based on 20 lb. bond paper.
4. Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
5. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
6. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
7. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
8. Warranty program is subject to certain conditions and restrictions. See the warranty card for details.
