Color imageCLASS MF641Cw
IC MF641CW
As low as $319.00
Out Of Stock
  • Print up to 18 ppm
  • Print up to 8-1/2" x 14"
  • 250-sheet maximum paper capacity
  • Three-year limited warranty standard
Show more
Printer Overview
Designed for home and small offices, the Canon Color imageCLASS MF641Cw printer offers feature-rich capabilities with high-quality imaging and minimal maintenance. A 5" color touchscreen delivers an intuitive user experience and can be customized by a device administrator to simplify many daily tasks.
The MF641Cw has print, scan and copy functions, prints up to 18ppm and has a 3 year limited warranty.
Learn more about the MF641Cw and how it can fit into your workspace.
Image Alt Text
Application Library Image
5" Color Touchscreen
Organize your homescreen to access the features you use the most.
Mobile Phone and App Images
Mobile Connectivity
Print on-the-go with Canon PRINT Business, Apple AirPrint® and Mopria® Print Service.
3 year Warranty logo
Excellent Service and Support
Canon's friendly and knowledgeable Customer Service team provides expert assistance for every level of experience.
Screen
Application Library: Easy to Use, One Touch Solution
Discover how easy it is to use Application Library on the MF640 Series. Customize your home-screen to access the functions you use the most. Finally, a printer that's programmable to meet your needs.
PERFORMANCE
v2 color
V2 (Vivid and Vibrant) Color Technology
Improved saturation makes color pop from the page, providing documents and color photos with sharp color detail.
MF641Cw footprint
Compact Design
Consider how your device will fit in your workpace.
GENUINE Products. Maximum Results.
Canon GENUINE ink and toner are engineered to achieve optimal performance with Canon printers. The exceptional design results in better operational success and end results, including higher yields, outstanding output and greater consistency, vibrancy, reliability and performance.
Photo of a desk with people at laptops exchanging printed papers.
Color imageCLASS MF641Cw Spec Sheet
MAIN UNIT
CORE FUNCTIONS
Print, Copy, Scan, Send (Lite)
ITEM CODE
3102C019
PROCESSOR
Canon Custom Processor
CONTROL PANEL
5" Color Touch Panel
MEMORY
1 GB
STANDARD INTERFACE CONNECTION
USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
250 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 250-sheet Paper Cassette, 1-sheet Stack Bypass
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
75 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Color, Thick, Coated,
Label, Letter, Envelope (10 Envelopes)
Manual Feed Slot: Thin, Plain, Recycled, Color, Thick, Coated,
Label, Letter, Envelope (1 Envelope)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DL
Custom (Min. 3" x 5" to Max. 8.5" x 14")
Manual Feed Slot: Letter, Legal, Statement, Executive
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
Manual Feed Slot: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
WARM-UP TIME
From Power On: 13 Seconds or Less;
From Sleep Mode: 6.1 Seconds or Less
DIMENSIONS (W x D x H)
Standard (Desktop): 16.9" x 16.5" x 14.3" (429 mm x 419 mm x 363 mm)
Box: 23.4" x 23.0" x 21.3" (594 mm x 584 mm x 541 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 17.8" x 33.3" x 26.8" (451 mm x 847 mm x 681 mm)
WEIGHT3
Unit: Approx. 39.6 lb. (18 kg)
Boxed Weight: Approx. 53.9 lb.(25 kg)
SUPPORTED OS
Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 / Mac OS X v10.9.5 (or later)
WHAT COMES IN THE BOX
MF641Cw Product, Cartridge 054 CMY Starter: 680 Yield/Black Standard: 1,500 Yield, Power Cord, Starter Guide, User Software DVD-ROM, Warranty Card5
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED4
Up to 18 ppm (Letter/Legal)
FIRST PRINT-OUT TIME
Approx. 10.3 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
150 - 2,500 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II
DIRECT PRINT
Available from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1
Apple® AirPrint,® Canon PRINT Business, Mopria™ Print
Service
COPY SPECIFICATIONS
COPY SPEED
FIRST COPY-OUT TIME (LETTER)
Platen: 11.2 seconds/13.1 seconds (BW/Color)
COPY RESOLUTION (dpi)
600 x 600
COPY SIZE
Platen: Up to Letter
MULTIPLE COPIES
Up to 999 Copies
MAGNIFICATION
25% - 400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
COPY FEATURES
Paper Setting, Favorite Setting, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
SCAN SPECIFICATIONS
TYPE
Color Contact Image Sensor
SCAN SIZE
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book
PULL SCAN
ScanGear MF for TWAIN, and WIA
SCAN RESOLUTION (dpi)
300 x 600, 600 x 600
SCAN TO MOBILE DEVICES
MEMORY MEDIA
Standard USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATION
Email/Internet FAX (SMTP), SMB, FTP
ADDRESS BOOK
LDAP (50)/Local (300)/Speed Dial (281)
SEND RESOLUTION (dpi)
600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other)
COMMUNICATION PROTOCOL
File: FTP, SMB
Email/iFax: SMTP, POP3, iFax (Simple)
FILE FORMAT
Standard: TIFF, JPEG, PDF (Compact, Searchable)
Optional: PDF (Encrypted, Digital Signature)
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID Authentication
NETWORK
Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X(Wired Only), IPv6, SMTP Authentication, POP Authentication, POP Authentication before SMTP
DOCUMENT
Standard: Secure Print
WI-FI® AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES) WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS
AC 120-127 V:6.5 A, 60 Hz
POWER CONSUMPTION
Maximum: Approx. 900 W
Standby: Approx. 10.5 W
Sleep Mode: Approx. 0.8 W
Typical Electricity Consumption (TEC) Rating: 0.19 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver2
FOOTNOTES
1 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
2 For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
3 Includes consumables.
4 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
5 Warranty program is subject to certain conditions and restrictions. See warranty card for details.
Color imageCLASS MF641Cw Compatible Products
Toner
Toner
