Color imageCLASS MF652Cw
- Wireless 3-in-1 (Print | Scan | Copy)
- Print up to 22 Pages Per Minute (BW and Color)
- Uses Toner 067 / 067 High Capacity Toner
- 250-sheet Standard Cassette, 1-sheet Multipurpose Tray
- Single-sided Printing and Scanning
- Chromebook Compatible
- 3 Year Warranty
In the box
Return Policy
Overview
Multifunction, Wireless, Laser Printer
The imageCLASS MF652Cw has print, copy, and scan capabilities and can print up to 22 pages per minute.
Compatible Toners
Features
Easy WiFi Setup
Connect your printer to a wireless network in four simple steps:
- STEP 1 - Press WIRELESS LAN
Actual display screen may vary
Easy WiFi Setup
- STEP 2 - Select NETWORK
Easy WiFi Setup
- STEP 3 - Enter Encryption Key / Password
Easy WiFi Setup
- STEP 4 - Finalize
MF652Cw Uses Canon Genuine Toner Toner 067 / 067H
High capacity toner options keeps up with your printing needs and limits toner replacement interruptions.
Compact Design
Consider how your device will fit in your workplace.
Print Speed
Print 22 pages-per-minute with a quick first print of approximately 10.3 seconds.Footnote1
Customizable 5-Inch Color Touchscreen
Navigate through all the features and access the icons you use most.
Color Scanning
Scan colored documents in high resolution up to 600 dpi.
Mobile Connectivity
Print on-the-go with CANON PRINT Business, Apple AirPrint® and Mopria® Print Service.Footnote2
Compatible with Windows, Mac, Chromebook
Main Unit Specifications
Reviews
Brochures
imageCLASS MF652 Brochure
04.29.24
3.1 MB
Product Disclaimer
- Approximate speeds, letter-sized, both black and color output.
- Mopria® Print Service, available for free at the Google Play Store, requires a compatible Android 4.4 or later smartphone and tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network. Learn more.
