Color imageCLASS MF656Cdw
MF656CDW 110-127V US
As low as $486.99
Out Of Stock
  • Wireless 4-in-1 (Print | Copy | Scan | Fax)
  • Print up to 22 Pages Per Minute (BW and Color)
  • Uses Toner 067 / 067 High Capacity Toner
  • 250-sheet Standard Cassette, 1-sheet Multipurpose Tray, 50-sheet Automatic Document Feeder
  • Auto 2-sided Printing, One-pass 2-sided Scanning
  • ENERGY STAR® Certified, EPEAT Silver
  • 3 Year Warranty
Show more
Overview
imageCLASS MF656Cdw - Front View
imageCLASS MF656Cdw Logo
All-in-One, Wireless, Laser Printer
The Color imageCLASS MF656Cdw has print, scan, copy, and fax capabilities and can print up to 22 pages per minute.
imageCLASS MF656Cdw - Printer Around Toners
1. 50-Sheet Two-Sided Automatic Document Feeder + One Pass Scan
2. 5" Color Touchscreen
3. 1-Sheet Multipurpose Tray
4. 250-Sheet Paper Tray
5. Black Prints up to 3,130 Sheets; Color Prints up to 2,350 Sheets
6. Black Prints up to 1,350 Sheets; Color Prints up to 1,250 Sheets
Compatible Toners
Features
Easy WiFi Setup
Connect your printer to a wireless network in four simple steps.
  • STEP 1: PRESS WIRELESS LAN
Actual display screen may vary
Easy WiFi Setup
  • STEP 2: SELECT NETWORK
Easy WiFi Setup
  • STEP 3: ENTER ENCRYPTION KEY / PASSWORD
Easy WiFi Setup
  • STEP 4: FINALIZE
imageCLASS MF656Cdw - WiFi Setup Step 1
imageCLASS MF656Cdw - WiFi Setup Step 2
imageCLASS MF656Cdw - WiFi Setup Step 3
imageCLASS MF656Cdw - WiFi Setup Step 4
MF656Cdw uses Canon Genuine Toner 067 / 067 H
High capacity toner option keeps up with your printing needs and limits toner replacement interruptions.
imageCLASS MF656Cdw - Toner 067 High Capacity and Toner 067
Compact Design
Consider how your device will fit in your workplace.
imageCLASS MF656Cdw - Dimensions
Get Connected
WiFi® Direct Connection enables easy connection to mobile devices without a router.
Navigate through all the features with the customizable, 5" Color Touchscreen.
imageCLASS MF656Cdw - Screen
50-Sheet Automatic Document Feeder
Save time while copying or scanning large volume of pages. Scan in color, and convert files into searchable documents.
imageCLASS MF656Cdw - Automatic Paper Feeder
Mobile Connectivity
Print on-the-go with Canon PRINT Business, Apple® AirPrint® and Mopria® Print ServiceFootnote1.
imageCLASS MF656Cdw - Mobile Printing Wirelessly
Compatible with Windows, Mac, Chromebook
Main Unit Specifications
Model Name
Model Description
All‐in‐One, Wireless, Color Laser Printer
Functions
Print, Scan, Copy, Fax
Print Speed
Up to 22 ppm (Letter)
Document Feeder
50 Sheet
First Print Out Time
Approx. 10.3 Seconds (Black / Color, Letter)
Print/Copy Resolution
Up to 1200 x 1200 dpi
Scan Resolution
Up to 600 x 600 dpi
Print Memory
1 GB (Shared)
Printer Language
UFR II
Network Security
IP/MAC Address Filtering, IPSEC, TLS 1.3, SNMP V3.0, IEEE 802.1X, IPv4/IPv6, SMTP Authentication, POP3
Connectivity
USB 2.0 High‐Speed, 10/100/1000Base‐T/TX Ethernet (Network), Wi‐Fi 802.11b/g/n, Wi‐Fi® Direct Connection
Operating Systems
Windows® 11 / 10 / 8.1 / Windows®Server2012 / 2012 R2 / 2016 / 2019 / 2022, Mac OS X (10.11 or later)
Paper Capacity
250‐Sheet Standard Cassette, 1‐Sheet Manual Feed Slot
Min / Max Paper Size
Standard Cassette / 1‐sheet Manual Feed Slot: 3" x 5" to 8.5" x 14"
USB Direct Print
JPG, TIFF, PDF
Display Panel
5 inch, Color Touch LCD
Print Volumes
150 ‐ 2,500 Pages
Energy Consumption
Approx: 900 W (Max.), 10.5 W (Standby), .8 W (Sleep Mode)
ENERGY STAR
Yes
EPEAT
Silver
Box Dimensions
23.1" (W) x 22.4" (D) x 21" (H)
Box Weight
63.9 lbs.
Unit Dimensions
17.8" (W) x 18.2" (D) x 16.3" (H)
Unit Weight
48.5 lbs.
Reviews
Brochures
File Name
imageCLASS MF644Cdw Brochure
Date
03.24.25
File Size
2.7 MB
Color imageCLASS MF656Cdw Compatible Products
Paper
Paper
Product Disclaimer
  1. Mopria® Print Service, available for free at the Google Play Store, requires a compatible Android 4.4 or later smartphone and tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network. Learn more.
