Color imageCLASS MF663Cdw - Multifunction, Wireless Laser Printer
As low as $479.99
Out Of Stock
  • Color, Wireless 3-in-1: Print, Scan, Copy
  • Print up to 26 ppm
  • Easy Wireless Setup
  • 5-inch Color Touchscreen
  • Mobile Device Printing
Show more
Overview
Designed for small / home offices and hybrid work environments, the imageCLASS MF663Cdw model balances speedy performance and minimal maintenance. The MF663Cdw is easy to set up and has a customizable, 5" color touchscreen that delivers an intuitive user experience. Produce crisp, colorful documents with fast print speeds of up to 26 pages per minuteFootnote1, using high quality Canon Genuine Toner 075 / 075 H. Use Poster Artist Online to create professional-posters, banners and signage. The MF663Cdw offers a plain paper capacity of up to 250 sheets, 1-sheet multipurpose tray, and 50-sheet simplex (1-sided) automatic document feeder. Easily connect wirelesslyFootnote2 from computers or mobile devices. Print using a variety of mobile apps, including the Canon PRINT appFootnote3 using your compatible mobile device. The MF663Cdw comes with a 3-year limited warrantyFootnote4 and is backed by Canon's Service and Support network.
imageCLASS MF663Cdw Front View on a Desk
1. Automatic Document Feeder: Holds up to 50 sheets
2. Customizable, 5" Color Touchscreen
3. USB Device Printing Slot
4. Uses Canon Genuine Toner 075: Prints up to 1,300 pages black/color
5. Uses Canon Genuine Toner 075 High Capacity: Black prints up to 3,500 pages, Color prints up to 2,500 pages
6. Generous Paper Capacity: Holds up to 250 sheets
Features
Easy Wi-Fi Setup
Connect your printer to a wireless network in four simple steps.
Step 1: Press WI-FI Settings
Easy Wi-Fi Setup
Step 2: Select Network
Easy Wi-Fi Setup
Step 3: Enter Encryption Key / Password
Easy Wi-Fi Setup
Step 4: Finalize
Person Using Touchscreen on imageCLASS MF663Cdw
MF663Cdw Uses Canon Genuine Toner 075/075 H CMYK
High capacity toner option keeps up with your printing needs and limits toner replacement interruptions.
  • Toner 075 High Capacity Up to 3,500 black/2,500 color pages
  • Toner 075 Up to 1,300 black/color pages
Toner 075 and 075 H Boxes Next to Each Other
Mobile Connectivity
Print on-the-go with Canon PRINT app, Apple® AirPrint® and Mopria® Print Service.
Person Connecting Mobile Phone to imageCLASS MF663Cdw
Compact Design
Compactly designed for convenient placement in your home office or small business.
Get Connected
Wi-Fi® Direct Connection enables easy connection to compatible mobile devices without a router.
Color Touchscreen
Navigate through all the features and menu options using the customizable, 5” Color Touchscreen.
50-sheet (1-sided) Automatic Document Feeder
Save time while copying or scanning a large volume of pages. Scan in color, and convert files into searchable documents.
imageCLASS MF663Cdw with Dimensions
imageCLASS MF663Cdw - Front View
Person Using the Touchscreen on imageCLASS MF663Cdw
Person Using the Top Paper Feeder of the imageCLASS MF663Cdw
Main Unit Specifications
Model Name
Functions
Print, Scan, Copy
Print Speed
Up to 26 ppm (Letter)
First Print Out Time
Approximately 10.3 Seconds (Black / Color, Letter)
Print/Copy Resolution
Up to 1200 x 1200 dpi
Scan Resolution
Up to 600 x 600 dpi
Print/Copy Memory
1 GB (Shared)
Printer Language
UFR II
Network Security
IP/MAC Address Filtering, IPSEC, TLS 1.3, SNMP V3.0, IEEE 802.1X, IPv4/IPv6, SMTP Authentication, POP3
Connectivity
USB 2.0 High-Speed, 10/100/1000Base-T/TX Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
Operating Systems
Windows® 11 / 10 / 8.1 / Windows®Server2012 / 2012 R2 / 2016 / 2019 / 2022, Mac OS X (10.11 or later)
Paper Capacity
250-Sheet Standard Cassette, 50-sheet Simplex Automatic Document Feeder, 1-Sheet Manual Feed Slot
Min / Max Paper Size
Standard Cassette / 1-sheet Manual Feed Slot: 3" x 5" to 8.5" x 14"
USB Direct Print
JPG, TIFF, PDF
Display Panel
5 Inch, Color Touch LCD
Print Volumes
150-2,500 Pages
Energy Consumption
Approx: 1080 W (Max.), 1 W (Standby), 0.3 W (Sleep Mode)
ENERGY STAR Certified
Yes
EPEAT
Silver
Box Dimensions
21.9" (W) x 20.7" (D) x 23.6" (H)
Box Weight
60.7 lbs.
Unit Dimensions
16.8"(W) x 18.2"(D) x 15.7"(H)
Unit Weight
48.5 lbs.
Brochures
File Name
imageCLASS MF663Cdw Brochure
Date
10.22.25
File Size
1.4 MB
Color imageCLASS MF663Cdw - Multifunction, Wireless Laser Printer Compatible Products
Toner
Toner
Product Disclaimer
  1. Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
  2. Wireless performance may vary based on terrain/distance between printer and wireless network clients.
  3. Canon PRINT app is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
  4. Warranty program is subject to certain conditions and restrictions. See warranty card for details.
